The laptop reads Service error 5100 when I try to print. The light on the Canon printer also blinks 2x. I tried turning them off and off as the book suggests. I would like for it to print but I was actually trying to find out if the printer can be set up to print checks written from Quicken? thanks, Lisa Moody
  • 2 more comments
  • lmoodyan Oct 20, 2008
    In step 5 of first solution, the green lights do NOT blink. Instead, one orange light is solid. Tried turning off/on, unplugged several times and no change.
  • lmoodyan Oct 22, 2008
    Changed the data cable and printer blinks 2x, green then orange. Turned laptop on and off and printer on and off. Same blinking.
    After following Steps 1-8 by THafa, the printer blinks 2x, green then orange. The paragraph following the steps does not make a lot of sense because the first step is to unplug the printer. That does not work for me.
    Model PIXMA
    Serial FCPJO1054
    Brigadier General:
  • 6,966 Answers
The error message indicates a hardware fault or more specifically as others have pointed out, Carriage Home Position Error for a Canon printer.
If a DIY (do-it-yourself) is being considered (mechanical work involved), any or all the following would have to be checked/cleaned:
  • long thin plastic encoder strip with bar code like marks;
  • print head/carriage unit path;
  • print head parking area (pls include the purge cap, sliding mechanism, purge base/mechanism),
  • might as well include the paper rollers.
Incidentally, this page may shed additional insights.
Should you be uncomfortable performing a hardware repair, perhaps your best bet then would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 22, 2008
    Sergeant:
    Champion:
  • 331 Answers
Check the printers devices i.e the roller and specially the cartridges .
fix them in place ..after removing them and cleaning their contact and then try
printer might start working
    Genius:
  • 1,011 Answers
Dear sir/madam,
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swa
Thanks
good luck
  • Asfiya Ahamed
    Asfiya Ahamed Oct 22, 2008
    Even though the lever for the catridge was locked, the catridge wasn't
    sitting properly in the carriage and it was hitting the side of the
    front cover when it moves. Pushed the catridge in place to solve the
    problem.
    thanks
    good luck
  • 507 Answers
Have you dropped it?
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
I think waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
or try this:
1. clean **** strip film
2. clean **** strip film sensor (back of head carriage)(use contact cleaner)
3. fix purge unit
  • William Nabaza
    William Nabaza Oct 22, 2008
    the **** means s-l-i-t
    Master:
  • 538 Answers
I work on printers a lot. can you supply the model number, so that I may review my service manuals?
  • A Womans Computer Man
    A Womans Computer Man Oct 22, 2008
    maybe there is something amiss here..you gave me a TFT although all I asked for was a model number? that is NOT how one gets good service..let me know if you change your mind..
    Scholar:
  • 84 Answers
Problem having in your printer data cable try a new one
Posted on Oct 20, 2008
    Sergeant:
    Champion:
  • 200 Answers
HI
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
thank you
Posted on Oct 19, 2008
  • Thafa Oct 20, 2008
    hi
    Unplug printer, press and hold "resume" button, press "power" button
    and hold down, release "resume", press "resume", release and press
    again. Release both buttons and now press "resume" 4 times. Power off.
    Re-start.
    thank you
    Genius:
  • 1,550 Answers
Reinstall the driver for printer and check are you able to print .
If it does not work let me know .
  • SAM ANDERSON Oct 19, 2008
    The service error is displayed because the cartridge is not placed properly .
    You have a check over the positioning of the cartridge .
No printing and "service error 5100" the "triangel
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer
Try this solution
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Jan 12, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Regarding service error 5100 in canon ip1880 printer
1. Try to reset the ink counter by iptool software (sometimes it help)
2. Unplug the usb cable and then turn off and on your printer for a few times.
service error 5100 seems like indicating of mecanism exhausted or out of buffer ram in the printer. You should reduce the amount of pages to print at one time.
Good luck.
Jan 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Service error 5100
Hello it only a try but could be
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 28, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Service error in canon pixma ip 1200??
Hello,My problem its Pixma IP 1200 for Windows Vista PLZ Help!!!
Jun 16, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon i860 - Service Error 5100 I have tried the reset procedure several times (Resume, then power and hold power, resume 2x, release power) but the light never stops blinking to go on. Any...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME (while still holding down the POWER)
3. press RESUME twice, then release POWER
4. The green light will blink and the printer will make some noise. Wait until this is finished, you are now in the printer's diagnostic mode.
To select one of the functions below, use the RESUME button and then press POWER to execute:
# of RESUME Presses - Light Color - Function
0 - green - Power Off
1 - orange - Service Test Print: Extended nozzle check pattern
2 - green - EEPROM information print
3 - orange - EEPROM initialize
4 - green - reset waste ink counter (For the Canon waste tank full error)
Remember... ATTEMPT THIS AT YOUR OWN RISK!!!
May 03, 2008 | Office Equipment & Supplies
CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
55 people viewed this question
jasbo
jasbo
