Question about D-Link AirPlus DI-524 Wireless Router
Cant run 2 laptops from router
As soon as we log on second laptop Number one looses signal.I have two PCs hard wired to router but cant run a third PC plus 1 laptop OR the 2 laptops mention.Ehy cant the router cope with four connections? Thankyou
  • happyvall959 Oct 22, 2008
    Thanks guys,tried both solutions and found tthat settings were OK but then I moved router and everything worked.Darned thing was being shielded by my monitor and signal reduced.
  • Carl Navarro
    Carl Navarro May 11, 2010
    Look for a conflict in IP addresses. Right click on network properties and check that each machine is set to Obtain IP address automatically. The router is going to give out at lest 50 IP addresses and they all can work at once. The other thing you might try is bring the second laptop up first and then see if the first forces out the second.
    Hope you understand what I just said :-)
  • 37 Answers
Check your dhcp scope in the router, make sure that you have 4 or 5 dhcp leased ip to allow maximum of 4 connections. thanks
Posted on Oct 21, 2008
Wireless capability turned On but still not connecting
Maybe the maximum Number of devices are connected to the router
Check router settings
Apr 30, 2014 | Toshiba Red Horizon 17.3" Qosmio...
Keep losing the wireless signal on my laptop.Checked the Router everything is fine,the laptop has a built in reader.stops working even if it is next to the Router,and sometimes goes altogther.
1. Disable or remove Norton Security (usually the problem with intermittent wireless).
If that doesn't work:
2. Disable any wireless TV transmitters you have in your house. 3. Turn off all PCs, then restart the router. Wait until all the lights have stopped blinking, then start up the PC(s).
Aug 29, 2010 | Acer Aspire 5100 Notebook
I need help connecting a second computer to a Intellinet 5-port fast ethernet office switch. I have one computer up and running by setting up a new connection, how do i connect a second or third computer...
1.Log into router. Using either 192.168.0.1 ot 192.168.1.1 in a browser window that is ( internet Explorer or firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 26, 2010 | Computers & Internet
Lose router signal everytime i restart my laptop
This seems to be an issue with the router itself. As the laptop is able to connect to other networks easily, the trouble seems to be with the router.
Try updating the firmware on the router. Also, change the wireless channel on the router and check if that helps. If the issue persists then I believe you will have to get the router replaced.
Jun 21, 2009 | Zyxel (91-004-361002) Wireless Router
Unable to re-connect laptop to internet via wireless router
Reset all again.
Power off the modem, router, and PCs and wait 20 seconds or so.
Then power up the Modem first, then the router, and finally your PCs, wait a couple of minutes and try to connect.
Apr 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
I cant connect my laptop to my DI-524 router after I reset router
To configure wireless:
1. Open browser, type "192.168.0.1" under the URL and press Enter
2. Username & password will be prompt
Username = admin
Password = by default is empty
3. Once entered inside the router config, on your left u can see a wizard tab, just click on it and follow the on screen instruction.
Mar 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Eee PC 900 has problem with wireless connection
Hi terryandy,
I am using the Eee PC from Taiwan also. It is running good.
Based on your scenario, have you tried changing another new router?
Your description of having "out of range" is highly probable due to router hardware failure.
Try replacing the router and update us again.
Thank you.
Jan 06, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Two routers
you cannot have 2 routers on the same system, you will cause ip address conflicts as each router is a gateway and gives your pcs their ip addreses
Sep 07, 2008 | NetGear Computers & Internet
Netgear wireless router
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
Router and aol
Connect the Router to the modem using Ethernet wire and then connect the laptop with an ethernet cord also and run the set up cd. make sure you get the right cabling.
and if you wnat to go wireless , then after running the set up cd, and was successful to make the wired conenction worked, then you can unplug the laptop now from the router and check if able to detect signal form router. usually you will get the prompt on the lower right hand cormer of the laptop.
then if is able to detect the signal, then log -on to that network.
Oct 10, 2007 | Dell TrueMobile 1184 Wireless Broadband...
D-Link AirPlus DI-524 Wireless Router Logo
82 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
