Question about Philips 60PP9352 60" Rear Projection Television
Red convergence problem
After installing a HDTV cable box on in4 the tv went bad and I can not manually set the red converge,I have a triple image in the left and right side of the screen with cian,red and yellow colors.All input has the same problem.
I had the same problem and called comcast support, they told me to change the HD receiver settings from 1080i which is the default to 480P (not 480i) and the image shows up perfectly now. Also, The TV is by default set to 480p but using the service menu, you can change it to 1080i. i would advice keep the TV setting as it is and find out from your cable company how to change the output type from your HD receiver. Comcast Support was very helpful to resolve my issue.
Posted on Jun 07, 2007
    President:
  • 3,130 Answers
The problem you have has nothing to do with the cable box installation! The convergence fault was going to happen anyway. Im sure you think the install had something to do with it? My freind, problems do arise with these electronic devices all the time , and just out of the blue. Sorry for your troubles ,BUT if your not a service tech or know the safety issues involved with the repair of tvs now a days, I would call a pro to assist you with servicing this set. As theres Hi voltage inside of sets even when they are unplugged. Good Luck
Posted on Jun 20, 2006
The colors are distorted and there is triple images
triple images show failure of convergence out ICs in TV, these are two big black ICs mounted with aluminum heat sink on D board, replace these ICs with same number STK392-560 and problem in your Sony KP-46WT510 will be solved.
Required ICs are available in Part Store.
Let me know any further question, if any.
Thanks.
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Auto focus and manual focus(red+will not move left
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 17, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
3-d like picture
  • Screen looks 3D
Apr 14, 2009 | Hitachi 57F500 57" Rear Projection...
Phillips 55'' rear projection tv model #55pp970104
That is a convergence problem, it may be because of a faulty defective IC.
Feb 09, 2009 | Philips Televison & Video
Double Image
need to change convergence ICs
If you need more info., let me know and I can go over the details
mahi@pacbell.net
Sep 08, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Having problems with projection image on tv
Ok let me get started by saying this is What is known as CONVERGENCE Your projection tv has 3 projection tubes Red Green and Blue. They all have to hit the same spot to create different colors they all have to come to a CONVergence as it were. Someone mentioned deguessing this only works with crt type tvs... Ok i see these set very frequently at the shop, I need to first ask you a few questions. FIrst one.. Can you go into customer setup menu. When you do can you see a option called "convergence" Very important if you do not see this option it might be a good thing. there is a common problem with these sets FL231 it is a very small special fuse that blowns due to poor connections.. IF you know how to solder and can get this fuse it will save you hundreds of dollars. Now if you do see this option then sorry the troubleshooting continues,,, next go into this option there should be 3 options autoconvergence red convergence and blue convergence first try auto convergence the screen should go black and start flashing little red blue and green boxes aroung the edge of screen. this takes a few minutes and hopefully it will end in a full green screen, if it ends in red then next try manual red and blue options u get a cross in center and when you up and down left and right it should move the red or blue cross with it.If it does move then it might need a service convergence. if it doesnt then you have trouble with ether what is known as convergence power supply or convergence amp board. and at this point i would suggest a tech. WARNING THIS SET GENERATES DANGEROUS VOLTAGES AND RETAINS THESE EVEN WITH THE SET UNPLUGED. I do not recomend inexperience person to remove the back cover of this set. BOy I did not realize i could get so long winded(lol) just be carefull and good luck and if you need any help just get back with me ill try to be reponsive
Aug 13, 2008 | RCA HD52W59 HDTV Projection Television
Red - green and blue seperation after a storm
The convergence Issue is caused by your convergence ICs needing replacement you will need to replace both convergence ICs they are STK392-110 and you can get replacements at the following link and they provide free instalation instructions with the ICs and if you leave them an email indivating the problem with your remote and your model number they will also have the small sensor that your TV needs and they can tell you how to test wether the remote is at fault or if its the sensor itself that you need.Heres the link.
http://servicemanuals.vstore.ca/
Jun 14, 2008 | JVC AV-56WP74 56" Rear Projection...
Samsung hdtv has a problem
this points to a convergence amp problem. in customer setup do you have and control or movement on convergence adjstment
Mar 25, 2008 | Televison & Video
Phillips rear projection tv model #60pp9202/17f
  • Screen looks 3D
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Samsung HCM5525W 55" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
