Question about Kodak EasyShare LS443 Digital Camera
No pictures recorded/black screen
Camera appears to be working correctly but when the button the take the pictures is partly depressed, a red light flashes indicating you cannot take a picture. If you fully depress the button to take the picture anyway, the flash goes off but no image is recorded. Only a black screen is visible on the camera and on the computer if this "picture" is downloaded. Shutter is fully open. Batteries have just been replaced. Memory card and internal memory have both been formatted. I have been through the entire menu onscreen and everything appears to be in order. Camera was used one day and worked great, next day this problem occurred.
  • 188 Answers
It seems that shutter blades are stucked and are not working. when you say shutter is fully open i think you are talking about the lense cover, not the internal shutter assembly. the red light is the indication of OUT OF FOCUS SUBJECT OR FLASH NOT READY. if the shutter blades aare not open the camera would not be able to do the focusing and will flash the red light thus you would not get any image. contact the repairer.
Posted on Jun 21, 2006
Why does my canon eos rebel t3 not take a picture when the shutter button is depressed but tje red eye reduction button keeps flashing and the video still works?
Usually, it means that the timer function has been turned on, and the camera is going through a countdown to trigger the shutter.
After that, it means that something else is not working correctly. If video works and records, then you know that the sensor and memory are functioning correctly. At that point, check to see whether your camera and lens are set for the form of autofocus or manual focus you want and that the aperture is still functioning correctly.
At some point, switch the camera to an all manual settings mode and try the shutter switch. If it still does not take a picture, the switch may have a problem.
Aug 18, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
Lumix DMCTZ2 Problems
DFid you try to shoot a picture, even not seeing what you are shooting? Try it. Then ale check what happens if you press the display button, (left one under the Menu / set buttons)
Let me know how you and your camera are doing now.
Jul 07, 2014 | Cameras
How do i shoot a video on this camera? I set it on Video and depress button but it only shoots a picture. I have no manual.
You have to push the button with the red dot directly behind the camera and you will see the record selection on the top right hand side of the screen and the time couner will start to progress on the bottom right side of the screen.
If you depress the shutter button you will only take one snapshot of what you are trying to video.
hope this helps
Jul 09, 2009 | Canon PowerShot S51S Digital Camera
When shutter depressed "AF" and "SB" LED's flash
My camera's shutter will not depress all the way due to a red flash light coming up all the time in the Flash-Ready indicator lamp (refer to pag 28 in the Nikon manual). It can be full sun outside but it will not work due to the red flash light coming on.
A work around is to select a flash mode of 'cancel'.
There is a button toward the front of your camera called the flash mode button. Click that until you see strike mark on the flash icon of your monitor screen (see page 32 in the Nikon manual).
The camera must have a malfunction of determining the lighting so it always thinks you need to have a flash on the picture. Of course this is not 'fixing' the flash/lighting issue but you can take typical day pictures for now with this work around.
Dec 17, 2008 | Nikon Coolpix 5400 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
A95 LCD screen black and unable to take photos
There are quite a few of us with symilar problem, but the screen is not completely black: it has some purple or pinkish color when facing light. Old pics and menu can still be viewed. I noticed 4 symilar threads on Canon A95 within the last 5 mins without any search, just looking at the top questions.
Aug 09, 2008 | Canon PowerShot A95 Digital Camera
LCD screen black, no viewed image displayed.
Hold down the display button for a few seconds...
It worked on my Caplio R7 which was doing this all weekend...
hope this helps
Jul 31, 2008 | Ricoh Caplio R30 Digital Camera
Shutter wont' release
Well either the relase switch has failed or another projection device has stalled it. Check through you menu of the back screen to be sure and then call Pentax technical support on thier web site.
May 27, 2007 | Pentax Optio 30 Digital Camera
Kodak EasyShare LS443 Digital Camera Logo
195 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
