Question about DeLonghi DEBIG24SS Gas Single Oven
Temperature calibration of DEBIG 24 SS
Oven seems to run about 30-50 cooler than setting.
  • 1 more comment
  • mdpaul Oct 20, 2008
    Only adjustment there (per the manual) is the "lowest level" adjustment for keep-warm setting.  Nothing there for overall calibration.
  • mdpaul Oct 22, 2008
    Band new oven - - - pretty clean probe.  Thanks anyway.
  • Anonymous Jan 27, 2009
    same problem. where do i get parts?
  • 6,674 Answers
Did you pull oven dial off & look for adjustment there?
Posted on Oct 19, 2008
  • Mike Butler
    Mike Butler Oct 22, 2008
    Did you clean thermostat probe in oven? Scrub good with steel wool?
Oven will not reach temperature set
Get an accurate thermometer. Look on the oven control, there will be a calibration screw. It takes a while, but with small adjustments and accurate temp measurements, you can calibrate the control.
Nov 22, 2013 | Kenmore 30172 / 30174 / 30179 Gas Single...
Blomberg BEP 906. After power went out a couple
Hello.
When baking or cooking common foods in your oven, it is important that the oven heats to the proper temperature. Otherwise, the food in your oven could become over- or undercooked. The electric ovens are able to be calibrated if only slightly off, however, if the temperature is 25 degrees off or more, you should replace the oven sensor. The oven sensor is the device in the oven the detects the temperature. The control board increases or decreases the oven temperature, depending on the oven sensor reading. Before calling a repair technician, attempt to calibrate your oven or change the oven sensor.
Instruction
1 Turn on the oven and set the temperature to a medium-heat setting, such as 350 degrees.
2 Allow the oven to preheat and then open the door and insert the oven thermometer.
3 Allow the oven thermometer to remain in the oven for a few minutes and the look at the temperature reading, comparing it to the oven temperature setting.
4 Recalibrate the oven if the temperature is only slightly off, or replace the oven sensor if the temperature is greatly off, such as 25 degrees or more.
Calibrating the Oven
1 Turn off the oven to prior to calibrating.
2 Press and hold the "Bake" button until the calibration settings are displayed on the display.
3 Use the arrow buttons or "+" and "-" buttons to adjust the temperature the number of degrees that the oven is out of calibration.
4 Press the "Start" button to save the calibration settings.
Replacing the Oven Sensor
1 Unplug the oven from the wall or cut the power to the oven in your breaker panel.
2 Open the oven door and remove the oven racks.
3 Locate the oven sensor, located at the top-center of the rear oven wall.
4 Remove the mounting screw securing the oven sensor to the wall and then pull the oven sensor away from the wall.
5 Remove the cable connected to the terminal on the rear of the oven sensor and then discard the oven sensor.
6 Connect the cable to the terminal on the new oven sensor and then reposition the oven sensor and secure it using the mounting screw.
7 Replace the oven racks and then restore power to the oven.
Thanks.
Dec 23, 2011 | Ovens
Temperature does not always reach set point of 425 F.
Oven will not hold correct temperature:------- This can be caused if temperature probe not working.Resistance across temperature probe leads at room temperature (70°F) should be approximately 1096 ohms.----------- Other possibility for this problem is :--- Temperature control not calling for heat.When heat is required, there should be continuity between terminals 6 and 7 on temperature control.-----------Inadequate or improper ventilation.Check ventilation hood. Verify draw and make up air adjustment.-----------If all this checked out ok then its calibration problem.For calibration follow this procedure:--
It can be problem with temperature controller. TEMPERATURE CONTROLLER (Standard-Control Models Only) The calibration of the temperature controller should not be changed until sufficient experience with cooking results has definitely proved that the temperature controller is not maintaining proper oven temperatures. Before any recalibration is attempted, the oven temperature should be checked by the following procedure: 1. Remove all trays and pans from the oven. 2. Place a thermocouple or a reliable mercury oven-type thermometer at the center of the middle rack. 3. Turn the oven ON and set the temperature control knob to 400°F. 4. The amber "heat on" light will go out when the oven temperature is reached. 5. Allow three cycles for the temperature to stabilize. 6. Read the thermocouple or thermometer immediately after the light goes out for the third time, and again immediately after it comes on the next time. 7. If the average of these readings varies by more than 10°F from the dial setting, recalibrate by the following procedure. Recalibration should be attempted only by a competent service technician. Use the following procedure to recalibrate the oven: 1. Loosen the two set screws that secure the temperature-control knob to the temperature-control shaft. 2. Remove the knob from the shaft, being careful not to rotate the knob or shaft. 3. Replace the knob on the shaft so that the indicator mark on the knob points directly at the temperature that was measured at the center of the oven. 4. Re-check the oven calibration. ----------- Part number for temperature probe is 1181996 and you can order if from the Southbend service center. -------- If you want the manual and wiring diagram for your oven.Please click the link directly:-- http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man ----------- after you click the link,a page will open in that you fill the 5 letter number.And click the "download now " option.It will ask you to save or discard.Click the save option and download will start.It will take 2 mins to download.Then click the download file to open it.And go through the manual.------------This will help.Thanks.Helpmech.
Jan 28, 2011 | Southbend ES10SC Electric Single Oven
Temperature is wrong
Many ranges show a beginning temperature that is higher than actual temperature, then the gap closes as it heats up.
Use a accurate oven thermometer to check your temps.
If it is faulty, it will not recalibrate to offset 200 degrees. You will have to replace the ERC.
Mar 20, 2009 | GE 24" Built-In Single Gas Wall Oven
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Thermostat calibration?
It's on page 32 of the manual for Thermador's built in convection ovens. 1. turn off the oven 2.touch and hold the start pad and then touch the bake pad 3. 0 (zero) appears in the temp digits. release all pads 4. touch bake and 0 changes in increments. max adjustment is 35 degrees F. 5. to complete change touch start for lower oven on double ovens do this: touch the roast pad instead of the bake pad continue with steps 3-5.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
DeLonghi DEBIG24SS Gas Single Oven Logo
191 people viewed this question
Top DeLonghi Ovens Experts
ashburton
Jason Harris
Jason Harris
Naftali Haskell
Level 1 Expert
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
