Question about Garden
Will not start, briggs & stratton 3.75
I have spark ,compression,new spark plug.
still not working can you help please
  • Anonymous Mar 31, 2014
    it act like a starter or battery but both are good.
  • 84 Answers
Put a small amount of gas in carb from top and try it. if still not starting make shure choke is in closed position . check the safty switch handle . you do have spark/ and gas
Posted on Oct 19, 2008
B & R 3.75 engine, NO SPARK, or I can't see one
Posted on May 30, 2010
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
I have a briggs and stratton 18 hp vanguard mod 356447 that will not start when trying to start it backfires through the carb, It seems to have good spark on both cyclinders using a sprak plug test light....
I would still say it's a timing issue. Check the spark plug leads go to the correct cylinders. Was there a woodruf key locating the flywheel and did you replace it? Check points and any cams or anything to do with the ignition.
Oct 29, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman gold 6.0 hp. walk behind lawnmower wont start
Back to basics, is the fuel in the tank good?( fill with fresh fuel ) does it have a spark at the plug?(remove the plug, earth against the cylinder, is there a spark,if not, replace the spark plug and try again ) does the plug wet with fue lafter pulling?( clean/service carb ) is the spark occuring in the correct place ( flywheel key sheard ) has the engine got good compression?
Aug 19, 2013 | Briggs & Stratton Briggs Stratton...
Low power when under load lt1024 cub cadet 24 hp els 725 ohv
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb also check muffler for carbon build up clogged muffler means no power
May 16, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton pressure washer will not start. I have a 6.75 hp pressure washer that is only a year old. when I pull cord it turns over but does not start. I changed plug and checked it, I have spark...
hello dave, the problem is compression to low,you need 60 to 130 lbs to run engine,check for blown head gasket,or bad rings,or a stuck open valve,hope this helps,,
Feb 22, 2012 | Briggs & Stratton Garden
Cleaned the Briggs & Stratton Riding Lawn Mower's head and valves. Put it back together and it refuses to start, get good starting try, no joy. Checked the spark, great! Checked the gas- great!...
did you usae a new head gasket and clean the old gasket off? does the plug get gas? you must have spark, fuel, compression and timing in order for it to run. also did you gap the coil to flywheel spacing?
Jul 08, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Briggs and Stratton 28N700 series 15 hp mower motor
do you have spark at the plug - remove it and ground it while you crank the engine . is this an overhead valve engine ? have you checked compression .
Oct 24, 2008 | Garden
Garden Logo
829 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
