Question about Viking VGSC306-4B Gas Kitchen Range
Burner 3 of my burners work fine, but when the 4th one is on it keeps clicking I tried to clean it but nothing what is it?
  • Viking Master
  • 5,568 Answers
I think your problem is with the switch that is activated by the turning of the knob to supply power to the ignition transformer.
You may have to remove the entire top assembly to gain access to switches and whatever cam arrangement used in your range to activate the switch.
Posted on Oct 19, 2008
Grillmaster burner no gas
Check and see if burner is blocked or injector to the burner is blocked
If you swap 1 of the buners over this will show you what is blocked
Jun 24, 2012 | Sunbeam Grill Series 760
On my gas stove, 3 out of 4 burners light correctly. The 4th however will not light- doesn't show a spark. Though you can use a match to light the burner and it works fine. what gives? Can I do the repair?
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Feb 10, 2010 | Frigidaire FGF326AS Gas Kitchen Range
We have a Thermador Mod SGCS365RW 5-burner that was new in 2001 and installed for Propane. It has worked fine until yesterday - the top center burner does not get gas to the burner. The igniter works fine....
Hi, if the other 4 burners are working fine, the problem must be in the valve stem. There is a linkage inside the valve body which may have stripped itself. If this is the case you would need to replace the valve.
Feb 04, 2010 | Thermador SGS36GS Gas Cooktop
My ipod 4th generation keeps frezzing
Try reseting it once an try
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Feb 10, 2009 | Apple iPod nano 4th Generation
Low flame on gas top burner
Hello Husky!! We can help you get the correct parts to repair this wonderful range. You sin=mply need another burner head to be replaced. We have parts and will make sure we get this out to you asap so you get back up and running soon. How many burner heads would you like to order? Please call or email us asap and we'll get these parts right out to you. We look forward to working with you. 972-859-0929
Feb 01, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Burner on Thermador stove top does not light
Switch for burner 4 is not working properly - could have a bad contact resulting in just one spark and nothing more.
May 03, 2017 | Thermador SGS36GS Gas Cooktop
Kenmore 4 burner grill only lights 3 burners
Looks like your regulator is not venting properly to relieve the back pressure. The best thing you can do here is replace the regulator.
May 27, 2008 | Kenmore 490 sq. in. Cooking Area Gas Grill...
Viking VGSC306-4B Gas Kitchen Range Logo
81 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
