Question about Akai LCT3701AD 37 in. LCD Television
Mono/stereo sound My akai 37 inch t.v. never sounds right. It always switches from mono/stereo sound and it never stays stable in one spot. I place the setting on "surround and that sometimes helps but it just sounds terrible sometimes and the volume is just not very loud. I've checked all the treble, bass and all the settings but it just sounds terrible sometimes.
  • rajsinghny Oct 19, 2008
    same problem.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 65 Answers
Try the settings button and then hit audio and turn the sound to either mono or stereo or your speakers may be blow
Posted on Jun 23, 2009
Product: Ion Tape Express - Tape-To-Mp3 Converter/Player (with EZ Tape Converter software) Problem: I'm able to record my tape tracks as mp3's on the computer, but the sound is always in mono...
In all likelihood, you issue is in your recording software settings. If check the help files included with the program (hit the F1 key to pull these up) and search for stereo, I bet you find a setting on the software is set to mono.
The second spot to look is in Control panel> Sounds and Audio devices> Audio tab. Click Advanced... under Sound Recording. See what control options are available to you since they differ from one audio app to another. This should bring up the setting for your audio input, look for a setting that says stereo or mono.
Hope this is helpful to you.
Jul 27, 2011 | Computers & Internet
I've been having this audio issue with my LG 19LG30 for awhile now. Only recently discovering what exactly was going on. My audio would go in and out on some channels. There would be sound then muted for a...
to eliminate the problem just select the mono sound disable the stereo signal.so that your tv sound will be stable.this happens because not all tv stations are broadcasting on stereo signal thats why your tv keep on switching to mono and stereo base on what signal it receives.plus the signal being feed by the cable provider sometimes they are not stable enough to give the stereo signal so better select only the mono sound...tnx hope i helped you..
please rate my help!
Jun 05, 2010 | LG 19LG30 19 in. LCD HDTV
I have the 2442 fx behringer ''XENYX'' mixing console, and while trying to operate channels 13/14 and 15/16 (these are both stereo channels with mono capabilities, and do not have XLR inputs) I only get...
Check you assign buttons and bottom (three black square buttons) and play with them. It sounds as if you are not sending to that side. You should use mono cables into left and right. I set pan on left all the way left and right, all the way right. Hope this helps.
Jul 06, 2009 | Music
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
No power to right channel
if your reciver has a mono switch that could be a possibilty to check cause mono is one stereo is two mean left an right, if you have to unplug it while its on that could damage the unit, it could cause things to short out, thats another possibilty to check
Oct 30, 2008 | Audio Players & Recorders
Mono/stereo sound
you should read the owners manual, as im not familiar with this model. It should tell you what you need to know there.
Oct 19, 2008 | Akai LCT3701AD 37 in. LCD Television
Akai LCT2070 Stereo Sound
This tv is kind of got a mind of its own the only time you can adjust it on mine is on cable that comes in stereo actually it usually switches by itsself after it reads the broadcasted sound. Hope this helps.
Nov 09, 2007 | Akai LCT2070 20 in. EDTV-Ready LCD...
Akai lct2785ta Sound Problem
Bear with me...I will start talking about CC, but I think my solution may work for you, too. I noticed that every time I turned on Closed Captioning, when I changed channel, it went off.
I went into the on-screen set-up, and turned on the CC there. Now, when I turn OFF CC, then change channels, it comes back on.
So, it may just have to do with your set up. Go there and set the default sound to stereo and see if that fixes it.
Good luck.
Oct 05, 2007 | Protron PLTV-37 37 in. LCD Television
Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Sep 04, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai LCT3701AD 37 in. LCD Television Logo
231 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
