Question about GE DCSR483EA Electric Dryer
My dryer is just making the loud alarm noise, but not working at all
The alarm that usually comes on to let you know the load is complete now comes on when you turn the start switch - but nothing happens. any suggestions
  • bill bouvier Oct 25, 2008
    When trying to turn on the dryer the buzzer sounds and dryer does not start.
  • thill67 Dec 18, 2008
    I have the same problem, only the buzzing sound sounds more like the switch isn't completely engaging...
  • 87 Answers
SOURCE: Dryer making loud noises
You need a new drum roller in the back of drum housing.
Posted on Jun 17, 2007
Washer_tech
  • 164 Answers
SOURCE: My Electric dryer will not start.
you might have something stuck in the impeller. if there isn't anything stuck, you might require a new motor
Posted on Jun 29, 2007
docjohn174
  • 943 Answers
SOURCE: Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Posted on Sep 25, 2008
  • 41 Answers
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Posted on Nov 18, 2008
  • 50 Answers
SOURCE: dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Posted on Jan 25, 2009
LG Tromm electric dryer model DLE5977B is making an extremely loud humming noise.
Humming is caused when the slow start capacitor on the motor fails. Better to buy a new dryer as the motor is usually around $160. Yours is $145. I suggest you take professional advice on such a high outlay rather than risking the advice of someone who hasn't physically checked the machine. I have two pro dryers in my hotel fail, and they buzzed.
LG Dryer Model DLE5977B Parts
Feb 02, 2017 | LG Dryers
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Washer making loud noises, but still works... For now. Just completed a normal hot/cold wash and spin/rinse cycle with no problems other than it making a number of cyclic noises throughout, until the
Good morning Mike
The thought that comes to mind is, there are some coins,nails or screws rattling about in the machine. I have not emptied all pockets. It would be wise to take a look at the troubleshooting ages in the manual. Kolbrun
Feb 05, 2015 | Kenmore 700 6972 Dryer
My Frigidaire heavy duty dryer stopped working. It has worked fine for 15 years. Now when I push the START button it makes a noise but does not start as usual.
The loud noise could be a faulty or worn out motor. Or if the motor is good, the drum bearings might be worn and motor cannot turn drum. You will most likely have to remove some access panels to get a closer look at where the sound is coming from. There is excellent videos and information on howstuffworks.com that will explain the workings of a dryer and troubleshooting and more.
But please feel free to ask any other questions you may have.
Oct 14, 2009 | Frigidaire FEX831CS Top Load Stacked...
LG DLE2516W Dryer suddenly making loud vibrating noise
Until you know how serious a problem you have, I'd advise against continued use. If you are in the USA, go to http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
to find a service provider for in warranty service, or call LG USA at 800-243-0000.
Aug 18, 2009 | LG DLE2516 Electric Dryer
Front loading kenmore 86983110 makes loud noise when turned on. Think that there is a problem with the belt. I am tryng to take it apart now and do not know how to find the belt
The belt is located at the back of the appliance.
To remove belt you have to remove a panel at the back, on some model you remove top panel first.
The belt does not make loud noise. Loud noise when spinning is usually caused by bad drum bearing, located at the back of the drum.
Regards.
Jul 13, 2009 | Kenmore Dryers
Dryer makes loud noise, long time to dry.
This is joyce
Go to maytag.com and put in your model# and dowload your manuel. get some info on your type machine and the scamatics on it. I dont know the age but it sounds like its in the drum. may want to calll a technichian out to look at it. if I can help please let me know
thanks
joyce
Feb 13, 2009 | Maytag LSE7806A Top Load Stacked...
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer noise when burner comes on
The noise you are describing is coming from the gas valve solenoid coil assembly. This is usually indicative of weak coil.
If this is a warranty situation, request a factory authorized certified technician to replace the solenoid assy. at no charge.
If you want to fix it yourself, be sure and ask us for instructions on replacing the part safely.
Thank you for contacting us at FIXYA.com
May 28, 2008 | Maytag HYG2460AWW Gas Dryer
GE DCSR483EA Electric Dryer Logo
140 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
