Question about Heavy Machinery
Poulin chainsaw I put bar oil in the gas tank
  • 48 Answers
No big deal people do it all the time - drain the oil out best you can then put some gas in and shake the saw to mix it up . now drain that fuel and put in fresh - if the saw doesnt fire up you may need to remove spark plug and crank over to remove any oil if it got into the cyl - try to start again - if still wont fire up remove air cleaner and put some fuel directly into carb . I use a pump type oil can to put fuel in carb - once it fires keep it running on high till it stops smoking then reassemble air cleaner - this should solve your prob . keep me informed enginedoc
Posted on Oct 27, 2008
I have a chain saw homelite and the bar leaks oil in my case what do i do
Drain oil back out of tank B 4 you put away , its also a very good idea if you drain and purge gas tank as well , as either of these fluids left in saw will cause u problems if you leave in inside for long periods(< week) when you restart saw
Jun 17, 2014 | Homelite Garden
I filled the gas tank in my chain saw with bar oil. Is there an easy way to remove the oil from the carburetor and get it started?
Dump out the bar oil and put in some pure gas and shake the saw to thin the bar oil. If it has a primer bulb push it a few time to flush the oil through. Dump this out and put in the proper mixed fuel and try starting.
Nov 03, 2013 | Husqvarna Garden
Which port do i put the gas mix in and what do i do if i put bar oil in the gas side and gas in the oil side. Its an M S 170
on your stihl ms170 your bar and chain oil goes on the left side nearest to the bar and gas-oil mixture in the right side nearest to the throttle handle. if you put the wrong things in the wrong tank just flush them out with the right stuff.
Sep 23, 2011 | Garden
Dont know what type off oil to put in the bar and chain tank on the chainsaw
Hi and welcome to FixYa, I am Kelly
All Bar oils are SAE 30W non-detergent oil. Go down to the local auto parts supply and buy the cheapest SAE 30W you can find.... SAE 30W is SAE 30W regardless of what brand is on it and for bar oil it is not an issue.
Thanks for choosing FixYa,
Kelly
Aug 08, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a HOMELITE XL-12 chain saw. Web sites say it takes a mix of oil and gas. But mine has a place to put oil in. Which should I do?.
The mix of oil and gas should be a 32:1 ratio which is 4 oz. of oil to every gallon of gas. I am assuming that what you are seeing is the oil tank for the bar oil. You need to use bar and chain oil for this tank as it is what keeps the chain lubricated. Do not use two cycle oil for the tank marked oil.
Apr 15, 2011 | Homelite Garden
My saw simply will not pump chain oil. Iv'e run it with the bar and chain off and the pump works.Put it back together and nothing. Before reinstalling the bar I blew the saw clean. I had a Sears Poulin a...
Check that the bar oil ports are clean; there should be a small hole or slot on each side of the bar and these can become pluged with sawdust. Also clean the groove in the bar with a small screwdriver or bar cleaning tool every 8 hrs of operation.
If this does not fix the problem check the oil sump screen in the oil tank(usually on the end of a rubber hose); if no screen in tank: remove oil pump and clean(screen is sometimes in oil pump assembly).
Oct 06, 2010 | Poulan Pro Chain Saw 46cc 20"
DONT HAVE PROBLEM JUST NEED TO KNOW MIXTURE OF GAS/OIL FOR POULIN PRO 20 INCH
The correct mix is 40:1. That is 3.2 oz 2 cycle engine oil to 1 gallon regular unleaded gas 87 octane. Use ethanol free gas if you can. Ethanol will damage your fuel lines in time.
Oct 03, 2010 | Poulan Garden
I have a poulan micro s25d 33ccm super xxv deluxe model chainsaw and am wondering how much slack should be in a brand new chain that I just put on and have used once?
As to the proper amount of slack in the chain, new or otherwise, is you should only be able to left the chain from the center of the top bar, so that you can only see the drive tooth of one (1) of the links.
Now with a new chain, the trick is to check the slack after the first tank of gas has been consumed, as new chains tend to "relax/stretch" after being put into service.
But with that being said, I always check the chain at each fueling and filling of the bar lube tank too. Better to be safe and get the maximum performance from your chainsaw, and there is no better way than to keep everything in proper working order.
A good rule of thumb is to:
  1. check and readjust/tighten the bar/chain after the fuel tank runs out of gas/oil mix. (wait for the chain/bar to cool before grabbing it with your bare hands!)
  2. Refill the bar/chain oil
  3. Refuel the chainsaw with the proper gas/oil mix, (typically 40:1)
  4. I always add fuel stabilizer to my fuel tank after I'm done using it for the day (who knows when you'll use it again!)
  5. Take a hand file and give the cutting chain a quick "touch up" sharpening before putting it away.
If you follow these steps, you'll always have a working chainsaw, ready and sharp enough to cut when you need it, without any surprizes, etc.
I hope you find this Very Helpful and best regards!
Oct 21, 2009 | Garden
I have a older remington gas powered chainsaw (model SL16)- I rebuilt the carb (new diaphragm and gaskets), started it , did some adjustments and it ran great- When adding bar oil to the bar oil tank and...
An impulse line from the crankcase pressurizes the oil tank to force oil to the chain. On the bottom of this line in the oil tank is duck (one way) valve. I think it has failed (open) and you are sucking bar oil into the crankcase. Loosen the oil cap before putting her to bed to help stop the bar oil from weeping. Key word Help. LOL HTH
Lou
If this doesn't solve your problem try here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Do a search for your saw it has probably been asked and answered. They will help if my suggestion doesn't work and you can't find an answer.
Oct 20, 2009 | Remington Garden
Chainsaw is using way to much bar oil
there should be an adjusting screw usually at the front of the saw, on most saws. usually located on the lower front. the screw puts tension, or less tension controlling the flow of oil. also if that did not help then you might have a broken oil line or it might be diconnected all together.
Feb 19, 2009 | Homelite Garden
Heavy Machinery Logo
272 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
