Question about MSI PM8M-V Motherboard
No image input and pc makes weird sounds on start up
Hey guys, please help me out on this. For some reason, my pc wont start up anymore. When I press the power button I get a different sound than normally. Now I hear one long tone and then 2 short ones. After that, I can see the floppy drive running some test, like normally, but nothing else happens. There isnt even any HD activity.
Solutions are well appreciated. I need my pc working again for my graduation!!! Thank you
  • krizkraz Oct 19, 2008
    Before I forget, if it's of values: im dealing with a MSI PM8M-V mainboard. Thanks!
Q: Can you access the BIOS at all?
Check that the RAM is securly in and all cables are too.
Worst case scenario: Processor or RAM is Fried
Best case: just a cable loose.
Also, If you recently added some new hardware, make sure your PSU can support it.
Posted on Oct 19, 2008
Weird sound coming from my fridge
Probably the automatic defrost cycling
Sep 30, 2014 | Refrigerators
Cimbali M2 wont deliver coffee
Coffee may be to fine. To Check, open pill door and press any blinking button. If water comes out then for sure the coffee is to fine.
Nov 30, 2011 | Espresso RMI La Cimbali Espresso Machine
Hello please help. These speakers were working just fine and they right over a year old. For some reason I get no sound at all anymore, and when I unplug and plug it back into the computer it detects new...
turn the power on, then unplug it to computer and touch the input, if there is no crackling sound the amplifier is defective, a technician guy like me can fix the problem
Jun 19, 2010 | Dell A215 Computer Speakers
Cooler too noisy
If the fan was working correctly, and is now making a noise it's probably a bearing/lubrication issue on the fan itself.
If the laptop is only 1 month old I would take it back.
Apr 02, 2009 | Sony Computers & Internet
Remove & reinstall all the memory sticks (reseat). If that did not fix the problem, remove all the memory sticks and reinstall them one at a time to test them in an effort to determine if one of them has gone bad. Use this same methodology to test all of your device cards.
Check to make sure the CPU fan wire is connected to the fan header on the motherboard and that the fan is operational. Most motherboards (especially AMD) require the CPU fan to be operational and connected to the motherboard to avoid frying the CPU. However, this requirement can be disabled in the bios to accomodate CPU fans that do not run off of the motherboard fan header.
Can you get into the bios? If so, I would suspect the CPU and memory are ok. Does the clock have the right time? If the time on the clock is wrong it could indicate your bios settings are not being maintained after you power down and you may need a new CMOS battery.
Usually a beeping motherboard is an indication of a hardware issue. The data on your hard drive is probably intact. If you need to retrieve some files from the drive for your graduation, you can always install the hard drive into a USB external hard drive enclosure and connect it to an oprational computer.
Hope this helps - good luck!
Nov 01, 2008 | Computers & Internet
AKAI Rear projection TV
Try using different inputs besides the RF input. Connect your PS2 and DVD player using component inputs. With two component inputs, there's no reason in the world not to do this.
Feb 28, 2008 | Akai PT4298HD Rear Projection Television
Monitor Image Partially Freeze and PC Stop working
Hey, sounds like your videocard is about to fail. the only option now is to replace the card with another.
The card is damaged. Possibly overheating have you cleaned your pc recently? Might be full of dust and burned.
Feb 13, 2008 | ATI RADEONĀ® 9600 Pro, (256 MB) AGP Graphic...
I lost all my data in the phone after i pressed the reset button!
try using data recovery software for mmc... if the stuff was there on memory card..
Dec 20, 2007 | Griffin Technology iMate - Universal ADB...
MSI PM8M-V Motherboard Logo
55 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
