Question about Toshiba Satellite 1405-S151 Notebook
Toshiba Satellite 1405-s151 display problem
I have a Satellite 1405-s151 which has served me well from may 2002. Two days ago the display went off. I closed and reopen the lid and the display lighted again for a while, and went off again. Tried the same several times and the same. After the tenth time it did not came on and it has been the same since. I kooked it up to a desktop monitor, closed the lid, let it hibernate, open the lid again and I had the laptop display in the monitor, so I could work with an external monitor. Then I checked the display switcher to see if it will handle both the laptop display and the monitor, the monitor worked and then I found out the laptop display was working by looking it at a glance angle. So, I figure the backlit module is gone then. My question then is: is the lcd display inverter the problem? Should I replace it? Or there are further tests I should do? I know how to disassemble my laptop, and saw some inverters from $80 to $100, will they work? By the way the CD writer unit also stop working a while ago, will there be a compatible DVD writer for such an old laptop? Any help on this is appreciated, Azael.
  • santore Dec 13, 2008
    I have this same problem with a toshiba satellite a105-s4064.
    Could look at it with the screen opened at a certain spot. been using it like that for several months. This week it got to where it opens up gives a ghosting look, then goes out to black.
    Will the inverter fix this?
How do i factory restore toshiba 1405-s151? Is there a restore partition?
Yes, there is one. The hard drive is split into two patitions. Have a look.
If it is still intact then F8 will guide you there.
Hope that helps.
Feb 17, 2011 | Toshiba Satellite 1405-S151 Notebook
My Toshiba Satellite 1405-S151 is indicating that it is receiving power, when I push the power button it indicates that it is powering on. The screen does nothing :-( help?
if your TOSHIBA laptop is doing this then check the RAM(memory)
if the problem persist check the Processor,
Likewise If it continues use WorkStation on the VGA Chip;
thats all
Dec 21, 2010 | Toshiba Satellite 1405-S151 Notebook
Am not able to get drivers for Thoshiba satellite 1405-S151 laptop
sanathanchan,
Here is the website for driver support for your model of Toshiba Satellite:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=191872&rpn=PS140U&modelFilter=1405-S151&selCategory=2756709&selFamily=1073768663
Hope this helps.
-S
Oct 19, 2010 | Toshiba Satellite 1405-S151 Notebook
Toshiba satellite laptop 1405-S151 HDDDPassword lock
'flash your bios' Google "How to flash Toshiba Laptop Bios" and you should get your answer.
Genenerly it's just a start up hoding a button down (on the rear of your computer).
Chur.
Sep 20, 2009 | Computers & Internet
Question about the toshiba satellite 1405 s151
This is an older model and should have a celeron chip in it.
I dont think you can update the processor.
Check the manual
Aug 30, 2009 | Toshiba Satellite 1405-S151 Notebook
Toshiba 1405 s151 will not turn on. the green light for the plugin is on. i let it sit overnight but it will not do anything when i hit the power button.
remove the battery and power .CLEAR THE bios by removing the small battery on the mainboard for 10 hurses and power it on.
Aug 05, 2009 | Toshiba Satellite 1405-S151 Notebook
Manual
To download Toshiba Satellite 1400/1405 manual, please click the link below:
Thank You
Nov 10, 2008 | Toshiba Satellite 1405-S151 Notebook
Toshiba Satellite 1405-S151 Notebook Logo
296 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
