Question about GE Spacemaker JVM1640SJ Microwave Oven
Not heating Microwave not heating. Every thing is working, except there is no heat.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises? Is it louder or quieter than usual?
    Do you have the model number?
    These answers will help me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • mgosiyc May 11, 2010
    Model: GE 1650BB manufactured July 1999.
    Yes, the light comes on and the turntable works. Everything seems to work normally except for the fact that the unit does not heat anything.
    The noise I refrerred to is VERY subtle...with power set to high (PL-10), it comes on a second or two after the unit starts, which is when the magnetron would normally start. And n PL-10 it stays on....the humming is what I would normally except it sounds a little different....likes its "humming" at a sligthly louder and lower tone ( best I can describe it).
    I have also noticed that running the unit for 30 seconds to 1 minute starts to produce a "something electrical". Its not very strong, but with fan running, it definitely sends smell around unit.
    Putting the unit on a lower power setting like PL-1 cuases this humming noise to go on and off. I presume this is how the unit would normally warm (instead of cook) food, by intermittently sending microwaves on then off, instead of constantly ON. This is why I thought the issue migth be the mag tube....hope this helps clarify....
  • GE Master
  • 19,396 Answers
If there is no power at all then check also the door switch and thermal cutoff.
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 27, 2009
SOURCE: GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
Posted on Apr 15, 2008
  • 9098 Answers
SOURCE: My Maytag MMV4205 Microwave Oven runs but does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you or someone you know can use for test help, but read their safety warnings first: (if it's not shorted, it's probably okay)
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 15, 2008
  • 1214 Answers
SOURCE: Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Posted on Jan 24, 2009
  • 87 Answers
SOURCE: Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
Labor to replace it would be about $125
Posted on Mar 04, 2009
  • 1689 Answers
SOURCE: everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
Posted on May 15, 2009
Everything working but no heat
Timer working but not heating - Microwave - iFixit
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
Aug 31, 2012 - Uploaded by
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
My haier microwave oven is not working every thing is ok except heating
please make this test and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Nov 19, 2013 | Microwave Ovens
Everything on microwave works except it doesn't heat or cook. what is the problem?
Jan 09, 2013 | Microwave Ovens
Not heating
Usually one of three things and not in any order:
The diode commonly used in most microwaves= it cannot be shorted and work.
The inverter board which powers the Magnetron.
The magnetron itself which does the work and can only be tested for sure by replacing.
12_12_2012_1_10_05_am.jpgtypical Microwave diode.
12_12_2012_1_10_45_am.jpgtypical Magnetron
Dec 11, 2012 | Sharp Microwave Ovens
Kenmore microwave model# 401.8504 will not heat
There are 3 likely causes, the magnetron "heats food" the high voltage diode "sometimes cracks" or the high voltage capacitor "usually shorts"
Mar 13, 2012 | Microwave Ovens
Microwave not working (generating heat)
Please check the door switch for proper operation.
May 19, 2010 | Frigidaire PLMV168 Microwave Oven
Microwave works except not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
May 08, 2010 | Bosch HMV9305 Microwave Oven
Over Stove Microwave, all works except doesn't heat
Hello. The problem you are having with your microwave is due to either a shorted rectifier or a shorted magnetron.
Regards, Joe
Dec 23, 2009 | Microwave Ovens
A child burnt popcorn in our GE Spacemaker microwave. Now, everything works except for the heat. Panel works, light works, turn table heat. Help pls.
Sadly popcorn kills more microwave ovens than peiple imagine. You can get an estimate on a repair but I believe you will probably decide in the end to replace it. Same exact thing happened to me............expensive popcorn!!
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
81 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
