Question about Samsung HP-R4252 42 in. Plasma HDTV
4 inch thick black vertical line down the middle of the screen
My samsung is about a month old. It was working great until one day I turned it on and out of nowhere appeared this 4-5" thick black line down the middle of the screen. I use the wide screen mode and don't have any burn problems. Any thoughts on what the problem might be? I've tried everything short of having a samsung technician come out to the house to fix. Could it be the DVD/VCR combo that's hooked up to it? I haven't tried unplugging it yet... Thanks for your help.
Same problem i am having a black horizontal line middle of the screen appears from no where..... just one and a half months old. this seems a common problem with samsung. then why they called themselves the world no one TV. Sony is the leader no doubt. what should i do? i am thinking to buy a sony rather than again using the Samsung ****
Posted on Sep 22, 2012
    Scholar:
  • 137 Answers
Hello JayZ,
Let me explain whats going on here. Your lite engine (inside the TV which shows the light) has a part called the lite tunnel. They use a special glue to put four rectangular glass together to make a small tunnel. This glue falls apart inside and cause a shadow. This can be fix by replacing the lite tunnel which cost a few dollars. or you can replace the entire lite engine which cost over $1000. This is covered by the manufacture because your set is still under warranty. Samsung would rather replace the lite tunnel because its cheaper for them. The problem with replacing the lite tunnel is that it takes a special trained tech to do that. If the part is not installed correctly you may end up with a tilt picture or top of the picture is mis aligned.
Best regards
circuitcity
Posted on Apr 09, 2008
  • Mervin Guy
    Mervin Guy Apr 09, 2008
    My mistake, thought you had a DLP tv
  • 513 Answers
A month from purchase you shouldn't even bother yourself with this. Their problem.... give the shop/samsung a call. If you have no reason to suspect any cable problem, and a different input device(other than the DVD) doesn't affect it, don't waste time and get on the phone. Good luck
Posted on Jun 22, 2006
How to i fix my Samsung Plasma TV which has a 3" wide black vertical bar down the middle?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 29, 2015 | Samsung Televison & Video
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
Oct 10, 2008 | Televison & Video
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
I also have the same problem I phoned Samsung today to explain the tv was only 14 months old, they didn't wanna no because it was out of warrenty by 2 months. I am getting a black solid line down the left hand side of the screen. I ended up phoning Dixons were we bought it from, they have told me to get an independent engineers report done & send the report to them within 14 days. Dixon told me it was a known problem with Samsungs. They said they will fix it free of charge if they can if not they will send vouchers to the same value of the television. So beware stay clear of Samsungs.
Feb 03, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Samsung HP-R4252 42 in. Plasma HDTV Logo
307 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
