SOURCE: DRYER NO LONGER HEATING UP
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
SOURCE: broken switch
You can email Customer Service at Braun www.braun.com, give them you model number, and see if they will sell you a switch, but these unit's are made to be throwaway.
I just looked at the unit at Braun's website, and they don't show any replacement parts except for having to do with the caraffe.
I know, it's hard to let go of a perfectly good coffee maker like this, but, it's how the world has become.
SOURCE: I believe this is on recall model PTB1952GRW
you need to call maytags canadian customer service line listed in your owners manual and they will confirm that your unit is part of the recall and shedule service for you. alternativley you can go to maytag.com and you can get service set up there as well. thanks Peyton
SOURCE: bose cd changer is broken
Sorry, but we are not a repair facility. Here is a link to the Bose service/repair page ;
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/faq/product_faq4.jsp
Bill B.
