Question about Cameras
Dead Philips picture frame
I am trying to resuscitate a dead picture frame for my father-in-law. It is a Philips model 7FF1, and was purchased a few years ago. It is totally dead. I have tried hooking it up to my computer and turning the on/off switch repeatedly but the screen is blank. I inserted a new photo card with some test pictures to see if it might help but still the screen stays dark. I tried resetting the frame by pushing a pin in the little reset hole, but no luck. None of the FAQs seems to address this problem so I am writing you. Let me know if you can breathe life into this machine.
Thanks,
Robert Griffin
407-414-8130
  • 4 more comments
  • GriffDawg Nov 22, 2008
    Same problem... just went blank.  Can't get a picture at all.  I know it has power cause the little green light is on there.  Has anyone found a fix?
  • richzmail Nov 23, 2008
    Same problem, I guess its either a dead backlight or the backlight power supply. went just as the warranty expired.
    Richard
  • HeinzIII Jan 17, 2009
    Exactly the same Problem (by the way also for the father in law ;-)
    Just died (supply seems to work, however)..
    Beat
  • mrsulu Apr 15, 2009
    @baronng
    Don't think you had the same problem. To upgrade the firmware you need to be able to connect to the device, in this case however the device is not detected and you can't connect to it via the PC. It's DEAD>
  • maxdpl
    maxdpl Mar 03, 2013
    same here...red flash screen with logo Philips on boot and then black sreen. I see a shadow of menu but lamp is not on. Upgraded with last firmware, but same problem. It's the last Philips product I'll buy.
  • maxdpl
    maxdpl Mar 03, 2013
    same problem, upgraded with last firmware, Vivid Red screen on boot with logo Philips, then black screen. I see the shadow of the menu and I can still operate in, but not results at all. It's the last Philips product I'll buy, for sure.
The user manual is rubbish, picture books are not user friendly for my 91 year old father in law, written instructions are needed as well
Hi jeff nunn584,
I found a User Manual for the Philips Norelco HQ7310 (I couldn't find HQ7300 on the product support site @ www.philips.com/support).
The User Manual for the HQ7310 is at:
http://ow.ly/64oL9
If you have any additional questions or issues, a Consumer Care agent can be reached at 1-800-243-3050 (US).
Hope this helps. If so, let me know by rating this solution.
Thanks!
Aug 16, 2011 | Philips HQ7300 7300 Series Shaver Electric...
Hi there. My mother and father in law purchased a camera
Can't you load the cd on to your pc and print off the manual?
Just an idea.
Mar 15, 2009 | Cameras
The EasyShare SV811 will not start up
please try these troubleshooting steps:
1. Turn the frame off.
2. Unplug the power cable from the wall outlet.
3. Remove any memory card or flash disk from the frame.
4. Connect the power cable directly to a wall outlet.
5. Turn the frame on.
6. Use a paper clip to press the button inside the pinhole on the back of the frame.
If after trying the above steps and the frame still have the same problem, then we need
to send the frame in for a repair as per warranty guidelines.
Your frame will be repaired per warranty guidelines. A product is warranted for 1 year from the date-of-purchase. For an In-Warranty repair, a “Proof-of-Purchase” is required. If the repair center finds any customer induced damaged, the warranty will be voided and you will receive a notification from the repair center in such cases.
Process the repair at www.kodak.com/go/itg
Jan 06, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Was given digital picture frame . have no cd manual. haS 22 PICTURES ON IT .CAN I PUT MORE? MODEL NO. 7FF1
It depends on how big the existing pictures are. It has a 14MB internal memory, but it says about 12MB for storage. You can buy memory card to insert into the frame but it will not display internal memory once you insert a new memory card. If you bought a 512MB card, you could put hundreds to thousands of pictures in JPG format. You can hook the frame to your computer or directly to a digital camera. From the computer it takes a few seconds to convert the pictures. The frame will show up on your PC as a mass storage device and you will be able to delete photos as well.
I hope this helps
Dec 05, 2008 | Philips Televison & Video
Philips Projection TV Bulbs need changing
Buy a new television. The "bulbs" are actually small picture tubes, also referred to as CRT's or guns. There are three of them, Red, Green and Blue. The cost for the tubes alone will probably exceed the original purchase price of the television. If the new tubes do not have the lens assembly attached, then you will need to transfer the old ones. This involves draining, cleaning, and refilling the coolant chambers. Once installed in the set, there is a series of mechanical and electrical adjustments required, to get the picture aligned or converged. This procedure is not recommended for the inexperienced. If cost and time are not an issue, then everything can probably be found on the Internet. Simply search the web for your model number. You will need the remainder of the model number first. There are at least eight models starting with 46PP9302. You are missing three additional characters.
Discouraged yet?
Nov 15, 2008 | Philips 46PP9302 46" Rear Projection...
TV Volume goes up when channel is changed Philips 20S240
I don't think the IR sensor has anything to do with it. It sounds like a surface mount micro processor to me...
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Cameras Logo
2,243 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
