Question about Dewalt DW744 Factory Reconditioned Heavy Duty 10" Portable Table Saw
DW744 table saw
The motor sounds like it speeds up and then down, there is quite a
lot of movement up and down, I really like the saw but am afraid to use
it in this condition I bought it in 2002 can you help it through a few more
years
Thanks Jim
    Novelist:
  • 99 Answers
Balde movement up and down? If so, that would suggest worn bearings in teh gearbox. If they are worn there then they might also be worn in the motor. If this happens the armature will float up and down causing it to rub against the stator. You may be able to get the bearings sorted without needing any new motr parts. I beleive this saw uses an induction motor so beware if it does need replcing you might want to be sitting down when you get the quote.
Posted on Nov 01, 2008
Hi. I have a dw744 and the motor started to sputter/vibrate and spark a lot. How doe I know if I need to replace the brushes?
Not Much on saws but it is alot like a starter motor and if the Brushes wear down it will cause metal to metal contact with the armeture and will cause them to spark and soon wont work.
Oct 22, 2013 | Dewalt Saws
What is the field resistance on a dw744 xe 240v
if your field coil is dead,most of the time when you run the motor 1 brush spark more
inspect visually for the blackened area or darker on the windings
the resistance is too low to be mesured with dvm
Oct 14, 2012 | Dewalt DW744X 10" Heavy Duty Portable Tab...
Brand new bosch 4100 jobsite table saw
there are no adjustments on the movement you described. If this is a new saw as indicated I would return for warranty repair/replacement.
Feb 09, 2012 | Bosch Saws
The motor sometimes starts right away and at other times I have to use a wood stick to spin the blade and it starts
the brushes in a dw744 have a ledge when they get too short that hangs up. replace the brushes and you should have no problem. the brush holder comes right out with a little coaxing with a screwdriver after the end cap is removed. it just plugs right in.
Dec 22, 2010 | Dewalt DW744S 10" Portable Table Saw with...
I was cutting 2" dense foam insulation board,
The problem you have is a faulty field coil, the Bosch saws unfortunatly have a bit of an issue with this. The coil can be replaced separatly so you won't have to replace the whole motor. Bosch has a 1 yr warranty on thier table saw so this is a warranty replacment provided the saw was purchased within the year. If not the coil replacment is still cheaper than buying a whole new saw, but should really be done by a service center because of the level of difficulty of the repair.
Nov 10, 2010 | Bosch 4100 10" Worksite Table Saw
How can i get a guard for this table saw the dw 746
You can order them at www.dewaltservicenet.com.
The DW746 and DW744 use the same guard assembly, if you're talking about the hinged guard over the blade.
Mar 29, 2010 | Dewalt DW746 10" Woodworker's Table Saw
Dewalt DW744 Factory Reconditioned Heavy Duty 10" Portable Table Saw Logo
419 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
