Question about Kenmore Elite 45986 Front Load Washer
We have a slow water flow the water wont come out fast its just drinpping out
Its a kenmore washer and the water is just dripping out when its suppost to fill ot there is no fast water pouring out at all just dripping slowly
  • 958 Answers
Could be a clogged filter to the water pump.
check the filter. it is in the water pump inlet assembly.
unscrew the cover and pull the filter. it could be clogged with dirt and small particles.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
I have a Kenmore 110 26912690 washer that has a dripping leak from the bottom front midline area.
DO NOT USE FLEX SEAL !!!!! If you put it in the washer you will destroy the pump and housing. Your door seal has gone bad, replace it$25-40$
Apr 30, 2014 | Kenmore Washing Machines
Slow hot water fill on speed queen washer
the valve filter is blocked up
turn off the hot water supply and remove the hoze from the machine end valve inlet
in the inlet is a small filter remove it and clean it
if its not too bad perhaps the valves solinoid coil has shorted turns
and wont open fast or fully
check the outlet preasure of hot water from the hoze to a bucket
see it flows fast ..
Apr 03, 2014 | Speed Queen AWS45NW Top Load Washer
My Kenmore Elite Oasis Ht Top Load washer has a slow drip from the drain pipe. How to stop?
If not during a wash it is standing water.
Remove tube and check for cracks. If so, replace. Does/did the washer "walk"? May have rubbed the discharge tube and caused the leak.
Is the down pipe in a cold external wall? May be condensation from humid air hitting cold.
If the sound is the problem, attach a string to the drain pipe so water drips directly to side of vertical pipe.
Oct 23, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
No cold water
Check the strainer in the hose where it connects to the faucet.  If it is clogged it will slow the water flow.  There may also be a strainer at the end of the hose that connects to the washer.
May 30, 2009 | Washing Machines
Hot water flow
Check the water pressure, Are you having pressure problems anywhere else? IE shower, sink anything like that?
Feb 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite washing machine will not fill as fast as usual.
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Dec 17, 2008 | Washing Machines
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Kenmore Front Loading Washer - Water in drum
please hold my rating till were done i need your model number to give you the proper procedure for checking your drain pump as i believe something in it is restricting your drain flow and three different companies build kenmore
Jan 11, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
67 people viewed this question
Sal De
fordexpert
Robert Rankin
