Question about Microsoft Xbox 360 Console
System error it says. a red line appears at bottom left of the console green light. A messege appears with black backround telling me to contact customer support what do i do to fix it?
  • 1 more comment
  • lgfrem Oct 19, 2008
    I dont know if i did it wrong or not but it didnt work i unpluged all cables took out the hard drive pluged the 360 back in but it still appeared and i did this several times and it didnt work. ):
  • Anonymous Nov 29, 2008
    xbox360 memory system error no 0110 do you have a solution
  • Anonymous Jan 18, 2009
    one red light
  • 26 Answers
NOTE: I did this with my X-Box with the E74 Error. However, it is usually the source for all of the Red-Ring problems with one or three red lights.
Send it in to Microsoft if you don't want to risk breaking it. Remember the 3 year warranty for any Red Ring affected X-BOX 360.
I had the same problem and fixed it myself as an educational experience.
SUPPLIES YOU NEED To fix it you are going to need a T10 and T8 screwdriver. (Torque) and a very small flathead screwdriver. In addition you will need a drill, 8 bolts, 24 steel washers, and 8 nylon washers and 4 suitable nuts. Also you need Arctic Silver and Heat-sync Puddy. And a heat gun plus a few scrap towels and tin foil.
1) The first step is to take it apart. You can find a lot of tutorials on YouTube. Then, remove the X-Clamps holding on the heat-sinks. Clean off the grey puddy with Arctic Silver. Find the GPU, CPU and HANA/ANA chips. Take Towels and cover every part on the mother board except for those chips. Put tin foil over the towels. Take the HeatGun and go in curcular motions for 4 minutes over all of the chips. Wait long enough for all of the melted solder, (if any) to solidify. After, say 5 minutes. Remove the Towels and the Tin Foil. Reapply the heat sinks with the new washers and bolts and nuts.
2) You will have to drill 8 holes in the Chassis large enough for the bolts to go through. After you have it all together, try it out without the outer casing or disk drive. MAKE SURE YOU HAVE THE FAN ON. Don't play it in this state. Just test it to see if it works.
3) If it works, put the case back on. If not, tough luck. You can no longer send it in to Microsoft. You just killed the warranty opening the case.
I AM NOT RESPONSIBLE FOR DAMAGES TO PROPERTY OR PEOPLE DUE TO THE FOLLOWING OF MY INSTRUCTIONS.
Posted on Mar 02, 2009
    Scholar:
  • 44 Answers
This problem is typically caused by a hardware failure. Turn off your Xbox 360 console, disconnect and then reconnect all cables. Turn your Xbox 360 console on again. If an Xbox hard disk is attached to your Xbox 360 console, turn off your Xbox 360 console, and then remove the hard disk. Turn on your Xbox 360 console, and then test for the error message. If you don't see the error message, turn off your Xbox 360 console, and then reattach the hard disk. Alternate testing with the hard disk attached and removed to see whether the error message occurs only when the hard disk is attached. If an Xbox Memory Unit (MU) is plugged in to your Xbox 360 console, turn off your Xbox 360 console, and then remove the memory unit. Turn on your Xbox 360 console, and then test for the error message. If you don't see the error message, turn off your Xbox 360 console, and then reinsert the memory unit. Alternate testing with the memory unit inserted and removed to see whether the error message occurs only when the memory unit is inserted. If you continue to experience this problem, contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
Posted on Oct 19, 2008
Erroe message on screen "system error contact xbox support
Is there an error code on the bottom of the screen?
E73?
E74?
E68?
E69?
Or another code?
May 28, 2010 | Microsoft Xbox Console
Red flashing lights
If you have 4 lights, check your A/V cord. 3 lights is the Red Ring of Death. Call Microsoft. They have an extended 3 year warranty for this problem. hope this helps AJ
Nov 16, 2009 | Microsoft Xbox 360 Console
One red light no error
generally this defines a general hardware failure, one red light does not mean anything in specific. if your console is under warranty you should contact microsoft. if your xbox is not under warranty you can try the "RROD FIX", or send it to a company who will fix it for you. alternatively you can sell the broken xbox on ebay, they seem to go for a good amount to someone who is willing to fix it.
Mar 21, 2009 | Microsoft Xbox 360 Console
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
2 red lights w/green light
The problem is the black screws on the bottom of the frame that screw into the X-Clamps. Most of the time, you usually don't have to even put the black screws back in. However their can be exscruciating headache inducing problems with fine tuning the black screws. If you do end up needing to put the black screws back in, I suggest to start with one @ a time, starting with the bottom right screw. ( thats with the 360 standing vertical with the dvd drive faced toward U.) The tightness can range from almost as tight as you can possibly get to soooo!!!!!! loose u can't possibly imagine how its doing anything at all. The best way to do this is, with the 360 hooked up, (and the case left off) take the small white plastic frame off that covers the power button, start with the screw loosened and then proceed to turn slightly like an 1/8th of a turn, then power on and then turn off if 2 red or 3 red ring proceeds and then repeat. You shouldn't have to put all the black screws back in, mine only has bottom right bottom left and top left, and are incredibly loose. My friend however has bottom right only and is tightened only about 1/2 way.
Sep 21, 2008 | Microsoft Xbox 360 Console
I Just dont know!!!!!!!
E74 is an AV cable error/ GPU hardware failure error. If you left your system on all night and all day there is a very good chance you overheated it. If you have a warranty i would use it If not call MS to see if there Manufacturing warranty will cover it. Just tell them that you have E74 error and then youll have to give them the S/N off the Xbox and they will let you know if it will cost you anything. You can look up this error on
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.html
Jan 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
475 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
