Question about 2wire (1000-400108-001) Router
AT&T 3800HGV-B Gateway by 2 Wire - Seen an 8 Port Version
I have nothing plugged into my 2Wire router except a switch.
This is because I need 8 ports (mostly talking to each other, not going out to the Net).
This means the fastest way is to plug them all into an 8 port switch and then feed it from the router.
I could reduce this if 2-Wire (or someone) made an:
8 Port switch
uPnP.
Anyone know of one of these?
SOURCE: How to port forward th 2 wire router from web port 80 and tcp/ip port 6100..?
Hi, Here is a manual explaining how to do it... lorexstore.lorextechnology.com/ pdfs/SG19LD804-161_CLIENT_MANUAL_EN_R2.pdf -
Posted on Aug 04, 2007
SOURCE: port forwarding? 2wire 2701hg-T
access your gateway homepage by opening your internet browser and typing this on the address bar: 192.168.1.254/management. then key in your system password and click on Settings under Firewall. there's option#2 (allow individual applications), click on "Add a new-user defined application", input the data and click submit another way is to enable DMZ plus mode. that option would actually make all the ports open. use this if option#2 is not working. after making the above changes refresh your router, just unplug then replug it from the power.
Posted on Feb 19, 2008
One Piece
  • 53 Answers
SOURCE: Connecting a netgear wireless router to a 2wire
before you connect the netgear router to your 2wire modem, you have to get the modem configured first. you did not include the firmware version of your modem (firmware version is found at the UI, go to gateway.2wire.net, click on the system icon.) for firmware version less than 3.7, go to homeportal/management, click on configure services, uncheck enable routing, then click on submit. for version 3.7 or higher, go to homeportal/management, click on configure under broadband link, put a dot in disable pvc search, set VPI to 0 & VCI to 35, the connection type box should be direct IP, then click on submit. then go to configure services, uncheck enable routing box, then click submit. you will notice the broadband link on the 2wire modem turn orange/amber, then you have successfully set the modem to bridged mode. that way you can now connect the router according to manufacturer's instructions (or just read the manual for the netgear router....)
Posted on Apr 03, 2008
dhruv765
  • 53 Answers
SOURCE: Connecting to Ichat
Please click on this link you will find exactly what you need to do exactly(with pictures) ,,
http://portforward.com/english/routers/port_forwarding/2wire/2701HG-B/iChat.htm
Posted on Jun 10, 2008
SOURCE: i have a 2wire 2701HG-B
i belive the default pw is your dsl tele #
Posted on Oct 26, 2008
How do I hook up my 2wire router?
Run a 2-strand or 4-strand telephone-wire from your telephone wall-jack to the telephone-port on the router.
Run an 8-strand "straight-through" (not "cross-over") Ethernet cable from one of the 'LAN' ports on the router to the network port on your computer.
Connect the AC power to the router, and turn it on.
You now should have Internet access.
Or, telephone the Technical Support department of your Internet Service Provider, and get them to help you, step-by-step.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
I bought second hand 2wire 3800hgv-b and looking for 2wire Generic Firmware or this version 5.29.135.47 so the gateway could be use with different provider.
Hi i dont think you need to change the firmware for the 2wire to support a different provider. all you need to do is to change the activation keys
Check this link : http://support.2wire.com/index.php?page=view&article=789
Dec 31, 2010 | 2wire 2700HG-B Router (2700HGB)
2-Wire 3800HGV-B bridge mode
Hello my friend,
You can disable all routing functions for your Home Portal. I never advise this as a course of action as it typically causes more issues than it resolves - so procede at your own risk.
- use the button on the back to reset to factory state (hold for 30 seconds)
- browse to gateway.2wire.net/mdc
- click on configure under broadband link
- set ATM PVC search to disabled
- set connection type to direct IP
- click on configure services under the advanced heading
- take note of the text under "If you want to connect to the gateway when it is in bridged mode"
- un-check the enable routing box
- submit your settings
Good Luck!
Oct 30, 2009 | 2wire HomePortal® 1800HW Router...
1 modem connected to 2 computers
Wireless is not the best thing to do heavy online gamming with. He he wants to keep a solid connection wile playing, ethernet is the way to go.
Feb 18, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2 wire 2700 hg-b
The 2Wire 2700 is a residential gateway, a modem and router in-one. There is an RJ-11 jack in the back of the gateway and this is where your dsl phone cord plugs in. There are four RJ-45 jacks in the back for connecting devices using ethernet cable. As a router is can operate both wirelessly and wired. For wireless operation you'll need the WEP key which is located on the tag on the bottom of the gateway. It's the number enclosed in brackets, between the two bar codes.
Redneck Geek
Sep 09, 2008 | 2wire 2700HG-B Router (2700HGB)
What equipment do I need?
here you go, the short answer. Just a simple re-wire and reconfigure (see attachment).
For the hub I recommend one of these (I have one and it's pretty much plug in play):
http://cgi.ebay.com/TP-Link-8-Ports-10-100-Fast-Ethernet-Network-Switch-Hub_W0QQitemZ330239125851QQihZ014QQcategoryZ51268QQcmdZViewItem?refid=store
May 22, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Can i connect a 2wire 2701hg-b with roadrunner cable internet ? I had the 2wire dsl with at&t but recently disconnected the service
It is possible but it may not work as a router (2 wire 270). The 2wired router only has a phone port and ethernet/usb for computer connection. So if you will connect the roadrunner modem to the 2wired, you can connect it to the ethernet port of the 2wire, but the 2 wire will not function as a router any more. It will work just like a wireless bridge. This one setup that you can.
May 02, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Trying to use port forwarding
hi!
i tried to remote access your modem using the serial nos. but it didn't give me anything, pls try to run system setup wizard from your computer by accessing gateway.2wire.net or homeportal/setup, once you have configured the modem with your own settings, please let me know and i'll try to open some ports for you
Mar 23, 2008 | 2wire HomePortal 1100 Router...
I have a 2wire 2701HG-B
gateway.2wire.net... try that, it should work
Dec 19, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire (1000-400108-001) Router Logo
2,223 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
