Softener dispenser Is it possible to remove the softener dispenser from the top of the agitator to facilitate cleaning?
  • 2 more comments
  • jwgallager Oct 19, 2008
    This machine doesn't want to let go of it. I have tried to pull it off. Do you think it's just really stuck or does the Legacy model not allow it to come off?
    Got it, thanks you very much.
  • jwgallager Oct 20, 2008
    I managed to get it off, thanks very much for your help.
    Did it. Thanks again.
  • 958 Answers
Yes. just pull it off from the top.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
  • 2 more comments
  • francis rivero Oct 19, 2008
    what is the exact model number and i will look at it 2morrow and see if there is special instruction on how to remove the dispenser.
    tnx,
    drcool
  • francis rivero Oct 20, 2008
    what is the exact model number please?
    drcool
    ow..ok. so you were able to pull it off. glad to hear that you fixed it.
    ratings are just as important to us as answering your questions, can i ask you to rate me please.
    tnx in advance, appreciate it.
    drcool
    tnx 4 the rating,
    drcool
I am looking to buy a used Frigidaire GLWS1233AS2 Top Load Washer and GLER331AS2 . They are supposed to be 3 years old. Are they good machines or do they have lots of problems?
Mine is 10 yrs old and I am just now having a problem. Clothes are too damp after last spin cycle. Hopefully, I'll get an answer here soon. Another problem I noticed a few months after I got it, with this model, is the fabric softener dispenser on top of the agitator. You have to remove it every single time and clean it. I added a little water to it before adding fabric softener and thought that would help to stretch the cleaning to maybe once or twice a week. Don't do it! I started to smell mildew and found out why. The agitator shaft that this dispenser sits on was caked with old fabric softener. I just use the blue Downey ball now. The fabric dispenser stinks but I have had 10 yrs of good washing.
Feb 14, 2013 | Frigidaire GLWS1233A Top Load Washer
Fabric softener ends up around rim of washer.
When you say you've cleaned both parts - have you poured hot water in and seen it actually drain out of the top peice while it was removed from the agitator? Have you poured hot water into the agitator with the top peice removed and seen it drain out of the holes? If not, repeated flushing (of the agitator) and soaking (of the top peice) with hot water as needed until is drains may be required. Until you can get water to drain out of both peices alone, it will work automatically. Once you have the water draining try again with a regular load of laundry and fabric softener. If it still doesn't work...
Since you've cleaned both parts (the non-removable and removeable top portion) of the agitator - it would suggest that the fabric softener dispenser's actuator inside the agitator is not functioning properly. The fabric softener isn't being released in the rinse (or at all really) and as a result of the centrifugal forces during the high speed spin cycle - it is causes the fabric softener to move up the sides of the dispenser and spray out of the top of the agitator onto the rim. This may be caused a mechanical or electrical failure in the washer or washer control. It will continue to work like this until it is fixed - so I suggest that you do not use the dispenser.
You will likely need to have the washer professionally serviced to have it begin working again. You can save the repair costs and either add the fabric softener yourself during the rinse cycle - or use "dryer sheets" in the dryer instead.
Feb 05, 2013 | Washing Machines
Lost manual to maytag legacy series. how do i remove softener dispenser and/or agitator for cleaning and what is the "finger faucet" switch for?
Methinks you need a manual again;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Good luck,
John C.
Apr 08, 2011 | Washing Machines
Where do I add softener?
If your model doesn't have an automatic softener dispenser on top of the agitator, then you just add it directly to the rinse water
i.e. if the top cap on your agitator is flat, there's no optional automatic softener dispenser, if it looks like a cup, you have the dispenser, and that's where you would add your softener.
Hope this answers your question
kcomp1863
Dec 31, 2010 | Roper RAX4233PQ Top Load Washer
Fabric softener dispencer not working properly, we are getting softener stains on our clothes. at the end of the cycle, there is undiltued softener in the bottom of the drum.
I just had this problem with our 5 year old Atlantis. The key I found was to lift the fabric despenser off. Then you will need to clean it really well. It get builfd up of the Fabirc softner over time. You wil also need to clean the interior of the agitator which will be easy after you have the dispenser off. I used a flat head crew driver and light scraped all the "Gunk" off the inside of the agitator. Take your time and get it as clean as possible all the way down to the bolt that hold the agitiator on. After you are all clean run a hot water load and disefect with a bit of bleach in the dispenser. Put the agitator back on and it should be solved. You will be amazed and possibly grossed out at how much stuff you clean out of it.
Feb 09, 2010 | Maytag Atlantis MAV6000 Top Load Washer
KitchenAid Stylemaster 622784 cleaning the fabric softener dispenser. I can't get the fabric softener apart to clean it. I don't have a manual. I bought it, used, with no manual. Suggestions?
Hi
Thanks for using FixYa. Remove the dispenser and spray with white vinegar. Then spray the agitator with it too. You can pretty much wipe it right out. Vinegar dissolves softener very quickly. The dispenser just wash out with warm water after the vinegar sits on it for a minute, and you hardly have to wipe at it at all. try adding bleach to the dispenser and clean it with a small brush.
The dispenser will pull off from the agitator and you can run hot water in it from the sink. The agitator is not as easy but has a 1/2" bolt holding it to the shaft. remove the bolt and pull up. but you can clean the whole washer with a cup of bleach and that will also clean the agitator. Now run a full tub of hot water and then add a cup of bleach with no soap. After the washer has filled up, then add another gallon of hot water and that will help to rinse out the residues that cause odors. then after that dont use too much soap and you wont have residue build up. Only use the smallest amount of soap that the cup has marked in it.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 07, 2009 | KitchenAid KAWS850L Top Load Washer
Fabric softener dispenser not working
If the model number you have this listed under is correct, you should have the softener dispenser on the center post of the agitator. If this is the case, you need to remove it by popping it off the center post and take it apart. Soak it in some hot water to dissolve the softener residue and reassemble. Most dispenser related problems are attributed to softener that hardens and clogs up the dispenser. Liquid softener is essentially a wax and will do this over time. You will need to clean it from time to time.
Apr 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag MAV7000 AWW washing machine agitator won't spin freely.
When you grab the fabric dispenser and move the agitator "counter "clockwise you should hear the rachet noise,once you try and move it back "clockwise" the fabric dispenser should slide inside the agitator and the agitator should NOT move.
Apr 02, 2009 | Maytag Atlantis MAV7000
Gunk in middle of agitator
the fabric softener spins out of the cup after the wash cycle when spinning the water out of clothes, then the washer fills back up for the rinse w/ your softener having been dispensed. is there a nut at the bottom of your agitator where you see the gunk? If so you can take the agitator out by removing the nut but be careful of the little parts that make the agitator agitate. Do not disturb these little parts if you don't know about them. Does the gunk smell like grease or a mechanics garage? If so chances are it is a lubricant and should not be removed replace the cap and your softener cup and continue enjoying your machine.
Jan 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Fabric softener doesn't dispense
Fabric softener dispensers are notorious for getting all gummed up and clogged. Remove the dispenser cup and soak in some hot water to dissolve all residue. While you have the dispenser removed check under the dispenser cap in the agitator for gummy residue as well. Clean with hot water. There should also be an agitator seal cap under the dispenser. Make sure the cap and rubber o-ring are seated properly. Last of all, if the dispenser has a cone shaped cup inside, make sure it is inserted cone-side UP. The cup is designed to allow fabric softener to roll down the sides of it, NOT hold it. I hope this helps.
Apr 09, 2007 | Kenmore 24982 Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
