Home theater system hook up.are both tv and home theater are playing at same time
Having trouble swithing from tv to home theatersystem tv and dvd will both be on at the same time
5 Suggested Answers
ungatt0
  • 32 Answers
SOURCE: home theater system
have you tried the wiring or if your fuse for the speakers are broken
Posted on Jun 12, 2008
SOURCE: hooking up home theater
In order to run sound out of the reciever, you must wire your reciever via optical cable or RCAs to your Cable/SAT reciever. In other words, think of it this way.
For Video:
Samsung HTS ---> HDMI CABLE ---> HDTV HDMI #2
Cable/SAT Reciever --> HDMI Cable ---> HDTV HDMI #1
For Audio:
Samsung HTS ---> OPTICAL CABLE ---> Cable/SAT Reciever
*OR*
Samsung HTS ---> RCA (Two for Stereo) --> Cable/SAT Reciever
You want your HTS connected directly to your TV in order to prevent piracy software restrictions limiting or hassling your viewing of different media. Without connecting either RCAs or a TOSLINK (Optical Cable) to your Cable/SAT Reciever from your Samsung unit, you won't be able to hear it's audio output. HDMI Takes care of Audio/Video together, unfortunately the Samsung unit limits you to a single HDMI Output and no inputs for your other units to plug into.
With a TOSLINK, press the AUX button on your Samsung remote to Digital Input. When using RCA cables, set it to AUX 1 or AUX 2. You must lower your TV volume and use your Samsung remote to increase the volume of your Surround system.
Hope this helps!
Posted on Oct 04, 2008
ButtFuzz
  • 463 Answers
SOURCE: How do I hook up coby 5.1 300watt to my rca flat screen
audio out on the TV to audio in on the "home theatre system"
Posted on Feb 27, 2009
  • 21 Answers
SOURCE: Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Posted on Sep 14, 2009
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
The audio will not play through the tv from the home theatre unit
because you do not have the dvd player hooked up to the tv, if you want it to play through the tv then you need to have the dvd player connected to the tv.
Mar 21, 2009 | Samsung HT-Z310T Theater System
Hooking up audio video to cable box with home theatre
From Cable Box to Input on DVD Player, from DVD Player Out, to TV in, from TV Audio Out to Home Theater Audio In.
That should work.
Will have to have the VCR on to watch cable. Plus make sure that you use A/V cables as much as possible. Coax works ok, but not as good as R/W/Y.
Feb 13, 2009 | Panasonic Home Theater System System
Can't get the tv to play through the home theater
No they all are compatible with eachother no matter what brand tv,surrround sound. It is all in the hook up & without you stating how you have it hooked up,no way to tell because one siimple connection is all you r missing. You have it most way there if sound is ok on dvd.If you explain how you have it hooked up i can surley help you!!
Jan 23, 2009 | RCA L32HD31 32 in. LCD HDTV
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
I have a HTS6500 DVD Home Theater System that is hooked up to a
I have a HTS6500 DVD Home Theater System that is hooked up with the hdmi cord but it will not pick up audio from the HDTV.
Lynn
Dec 27, 2008 | Philips DivX Ultra HTS6500/37 Theater...
How do i switch a jvc home theater system from pal to ntsc. model # rx-dv3sl
How do I switch a JVC home theater system from pal to NTSC.
Please e-mail this information to (shamarmec@yahoo.com)
Best Regards
Sharie
Dec 18, 2007 | JVC THC3 Home Theater System System
Samsung HT-TX72 Home theater system - Disk Error
Try updating your firmware... samsung.com Or have you tried that?
Dec 05, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
21 people viewed this question
 Grubhead
Grubhead
