Question about Sony Cyber-Shot DSC-U30 Digital Camera
Focusing problem The lcd screen displays dark colors with vertical white streaks when I turn on the camera. It will playback previously taken shots correctly. It will playback current shots as they look on the lcd screen. It seems to take the pictures normally. All other functions seem to work.
  • Anonymous Dec 12, 2007
    lcd screen has purple and white streaks cannot take photo flash works
  • 513 Answers
Your camera model was included in the general recall issued last year for the CCD factory defect. Here's a link to the announcement, you can also see a screenshot there for comparison - http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCV1&news_id=118 If for some reason sony tells you that it's not the same problem with your camera - it could still be a CCD defect, or the camera's main PCB. Try not to take a no for an answer and get it fixed through sony. Good luck
Posted on Jun 22, 2006
There is something wrong with my Nikon D3000. It turns on but doesn't show anything on the screen and when I look through the lens it's shows a grainy dark film. It can't be the lense because I...
There seems to be two separate issues here. I'm going to assume you have a charged battery pack in the camera.
First, the screen. Turn the camera on. Do you see the menu when you press the MENU button? Does the shooting info show when you press the Info button? Can you see previously taken photos when you press the Playback button? If none of those show up then something is wrong with the screen (or the battery is dead).
Second, the viewfinder. First, make sure the viewfinder in the back is clean. Now turn the camera on and look through the viewfinder. Do you see the eleven focus marks? Do you see the info at the bottom? Now turn the camera off and remove the lens. Don't touch anything inside the camera! Do you see a mirror at a 45-degree angle? Is it clean? Look at the focusing screen above the mirror. Is it clean? Now look through the viewfinder and point the camera out a window. Do you see a more-or-less white blob, or the same grainy dark film?
Apr 11, 2013 | Cameras
Why are there verital color streaks on my picture? Everything is out of focus, except the previous pictures stored
There may be the issue with the CCD (image sensor device) of the Camera.
Refer this article to confirm this:
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Check whether the LCD screen of the Camera looks similar as given on the page.
If yes, click on the "Yes" button at the end of the page to create an online Repair Request for sending the Camera to the Sony Factory Service Center.
Good Luck!!!!!!!!!!!!!!!!!
Sep 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Screen shows no image for picture taking or playback
Is this Sony DSC-T1 camera or some other model? let me know to help you out.
Jun 15, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
May 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
I can't view my pictures after the shot,it very blerr
I'm not sure if you are talking about the quick view of a picture just taken, or using playback mode to view shots taken. Either way, I suggest changing batteries so they are fresh.
There are 3 different LCD choices when in "Shooting Mode."
Press "DISP."
The display mode will change each time you press this button.
1- Standard (no info displayed, just pic)
2- Detailed (infor displayed)
3- Off
If you have tried this, then you may want to perform a reset to the cam. This will reset any screen/LCD settings that may have been changed.
Goto the Setup Menu and select "Reset All." Select "OK" and press "Func. Set."
This reset WILL NOT reset the following:
-Current Shooting Mode
-Date/Time, Language, & Video System settings
-White Balance Data (of you have custom settings changed in the custom white calance function)
Apr 30, 2009 | Canon PowerShot A450 Digital Camera
Unsatisfactory LCD preview display
Some times user doesn't care product category thats why I asked model number.
Now, problem is bad CCD imager in DSC-T3 and this part will be replaced to bring camera in business.
Part number of CCD imager is as follows...
A-1075-408-A CCD BLOCK ASSY (Supplied with CD-535 board)
Its available in Part Store and if you have expertise in camera repair, you can do it yourself, it is easy job.
Dec 14, 2008 | Sony Cyber-Shot DSC-T3 Digital Camera
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
LCD Display pschedelic colors
If there are random colour streaks moving around it can be due to defective CCD imaging IC. You need a skilled workshop to replace this and we can get you the parts from SONY and service manuals.
Jul 06, 2007 | Sony Cyber-Shot DSC-F505V Digital Camera
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Sony Cyber-Shot DSC-U30 Digital Camera Logo
107 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
