Question about Samsung HT-DB120 System
SAMSUNG HT-DB120 NO DISC PROBLEMS
Hi, when i put a disc(dvd) in it whirrs around for a while, then a mssg says no disc, i have tried to use laser cleaner dvd disc, however as soon as i put the disc in i get the same problem..... it tells me there is no disc.
Can you help.
John.
SOURCE: MP3 CD's Not working Samsung HT-DB120 System ?!!!
Try opening the zoning code. Unit must be switched on with NO disc inside. press enter,then enter the code 84269 and press enter again.unit will switch off. switch on unit and try again.
Posted on Feb 22, 2007
djnick989
  • 1067 Answers
SOURCE: Samsung HT-DB120 System
call samsung proably need whole dvd base unit repaird they dont sell them seprate yet anyware i see
Posted on Jan 10, 2008
SOURCE: dvd
The Samsung HT-Z310T is a DVD player, not a recorder, that is why you are getting an error when inserting a blank disc
Posted on Sep 15, 2008
SOURCE: Samsung HT-Z310 tries to load disc, but never does
I've had a similar problem where the disc continues spinning in the "loading" mode and then finally goes to "disc error." So, I opened the cover of the player, and noticed that the disc was not spinning as fast as I expected, and there was an extra unpleasant sound when the disc was spinning. Thus, I suspected there was an issue in the drive motor system: either the motor drive board, the motor itself, or the contact to the disc. I saw that there was dust accumulated on the rubber contacts to the disc, so I cleaned them with a q-tip. I then resetted the system, and the disc was the spinning normally again, and everything worked like before! (Other things I have tried in the past were cleaning the lens and updating the firmware, none of which worked) I hope this helps!
Posted on Nov 23, 2009
SOURCE: my samsung home cinema ht-tz212 wont play discs,
Try resetting the system turn power off then press and hold stop button on Main unit for at least 5 seconds this is main system reset it may well do the trick for you
Posted on Apr 10, 2010
Sharp DVD 'cannot read disc'
Sounds like the laser is bad.
May 29, 2013 | Onkyo HT-SR800 System
My samsung ht-x200 wont play dvds or cds it just displays no disc
Have you tried cleaning the laser with a DVD Cleaning Disc or more in depth by removing the top cover and using DVD Cleaning Fluid & QTips.
If you've tried both these without success then I'm affraid that your laser has failed and in most cases even when replacement lasers are available it's not cost effective to replace it.
Jun 20, 2011 | Samsung HT-X200 Theater System
Don't read some of the dvd?
Try cleaning the laser with a lense cleaning kit, also make sure the disc you are playing is not scratched or dirty, you can buy disc cleaners also. If these are not issues, then I suspect the laser in your unit is wearing out and it is time to get a new player. Some of these cheaper Chinese made lasers work fine for a while but they soon give out.
Nov 17, 2010 | Ace Sonic DGX-106 DVD Player
Put in disc keeps saying loading then no disc
The only things you can try are , clean the disc first then the laser (you can buy laser cleaner disks cheap) worth having one, if this fails it may nead a replacement laser drive.
pete
Nov 12, 2010 | Toshiba SD-K760 DVD Player
Whenever a disc is inserted, the macbook pro whirrs for a bit then spits out the disc. This happens everytime a disc is inserted. CD and DVD
The laser head is full of dust, try to clean it. If that fails the entire optical unit will have to be replaced.
Aug 22, 2010 | Computers & Internet
I have a tv with inbuilt dvd and freeview, the dvd player will not work, i have tried using a lens cleaner disc but dvd player just says theres no disc inserted
the laser can be contaminated with smoke (if anyone smokes around the unit or if its located in a kitchen or such) .. the lens cleaner disc will only remove loose dust and hair from the laser .. indeed that often fixes the problem but smoke requires dissassembly of the unit and hand cleaning of the laser (i usually use eye glass cleaning solution on a soft lint free paper or cloth (dont spray directly on the laser).. the laser could simply be at end of life as well .. in that case you might be able to replace the DVD drive (hopefully its standard ) .. replacing the laser usually costs more than a new drive ..
Oct 14, 2009 | Televison & Video
Readable DVD's but not CD's
That is a faulty lens. The lens reads DVD and CD on different laser beam frequencies. To read the TOC initial track the lens must focus on the laser beam reflected by the disk. If the lens is opaque, scratched or dirty, sometimes it can focus on DVD but not on CDs or the opposite.
Try using a cleaner disk, if that does not work buy a replacement drive. Today you can get a dual layer DVD RW for less than $30.
Sep 25, 2009 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Samsung dvd-v6800 not reading disc
hi..
Try buying a Laser Lens Cleaner Disc from Wal-Mart, FYE music store, or any other place that might sell DVD players. Your Laser Lens that reads the DVD'S is full of dust. Try using the laser lens cleaner disc i mentioned to clean the laser lens...
thank u
rate me
Aug 23, 2009 | Televison & Video
Samsung HT-DB120 System Logo
106 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
