Question about Pioneer Audio Players & Recorders
I have a Pioneer VSX-517K that does not powers up. I also do not get the standby led to light up. The fuses are ok and the stand by voltage is 5V. I do not understand the connections ACRY or ACWP and what voltages that they should measure for the unit to work. I have a copy of the service manual and still am confused as how to conquer the problem. Thank you for your advice!
    Problem Solver:
  • 7 Answers
There Is A Little Thyristor On The Side Of The Main Power Board look real close youl see it its on the green back side mines burnt to i cant figure out the part # to change it because its burnt if you have any luck ost it please
Posted on Jan 11, 2011
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Jan 10, 2013 | Pioneer VSX-305 Receiver
I have VSX-505S amp.Now standby LED lits but when i press power on button it wont turn on.So i removed it and checked the stand by voltages and other things but couldnt find a problem.What will be the...
Sounds like the amp has an internal fault,most likely in the power amp/driver stage.If you have a manual and know how to repair amplifiers you could do it,otherwise it is a job for a technician.
Jun 18, 2011 | Pioneer VSX-505S Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Pioneer vsx-01 receiver, standby light burned out. Button works fine, just no blue light. Pioneer sells a replacement standby button......is this easy to install and will it solve the problem? Do you have...
the light is an ledt they very rarely go bad ..to confirm its bad you must first see that the led is getting power --a voltmeter one end to the frame of the unit and the other to either lead on the led will confirm if its bad or not a typical led will run on or near 3 volts dc... if theres no power at the led than the problem is elsewhere
Aug 30, 2010 | Pioneer Elite® VSX-01TXH 7.1 Channels...
I have a pioneer vsx-501. I can't get it to turn on. When i hit the power switch I get a mechanical click and the standby light comes on, but that's it. All the internal fuses are fine. I think the power...
have you fixed it already?
I have the same receiver with the same problem as yours.
I found the fault in the voltage selector rotary switch. I'm refering to the round voltage selector switch not the other one, because you'll notice that there are 2 voltage selector switches at the back. The lock was broken so it couldn't switch the primary terminals of the main transformer.
Basically this amp has 2 power transformer, the small standby traffo and the large main traffo.
Try to press that round switch and press the front panel power switch. If it goes ON, then fix the center lock of that round switch.
Hope it helps.
Joel Herrera
Philippines
Aug 17, 2009 | Pioneer VSX-D508
Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Jul 30, 2009 | Pioneer Audio Players & Recorders
VSX-D409 - Standby Light - Does not Power On
Hi...
Make sure all the speakers are connected properly at BOTH ends.
If still **** then seek a service tech
Nov 27, 2008 | Pioneer VSX-D509S Receiver
Standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Jun 14, 2008 | Pioneer VSX-D308 Receiver
Vsx 305 surround sound
The stand-by light is supposed to go off when you power on the receiver. You should get the display light and you should have power on.
Dec 18, 2007 | Pioneer VSX-305 Receiver
126 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
