Question about Health & Beauty
AEG termometer FG 4905
A have a termometer which shows that battery is low. How can change buttery. I pushed the part where letters AEG are written, but the cover is not moving. Is there any spacial way to change the battery?
Thank you for you your help.
Branka
kobra@siol.net
    Problem Solver:
  • 10 Answers
Please search some screw was there first u remove the screw and pull it out and change the batt.
Posted on Jun 26, 2009
Termometer
you will have a temp difference between the actual ambient air temp and what the sensor is reading. it may even be ore then 2 deg.
Jul 18, 2013 | Toyota Cars & Trucks
Model WD 1140-ACEPI
Do you mean the IQ America wireless doorbell? If the product is the WD 1140 - A doorbell, then the push-button transmitter uses a CR2032 Lithium battery. You will need to unhook the push-button unit from the base and then pry the front cover up to access the battery compartment. Use a small flat-blade screwdriver.
I hope this helps.
May 01, 2013 | Simplex 4905-9914 Signaling Appliance...
AEG Lavamat 11842 Error code E66
http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
Feb 23, 2013 | AEG Washing Machines
Engine wont back off speed when foot taken off accelerator
low voltage to the Throttle Body unit causes this problem along with a dirty buttery fly . Have the throttle body cleaned asper Jaguar cars service spec and replace the throttle body motor relay located in the engine compartment center row 2nd back . Then dissconnect the battery for 30 minutes and reconnect .
Aug 05, 2012 | Jaguar X-Type Cars & Trucks
Hi there, I have a 1998 4 cylinder Toyota Camry and as soon as I start the car up my radiator fan turns on.
The termometer is no longer working that is why it is like that, it is either you leave it that way or you change the termometer. Thank you for using Fixya.
Sep 24, 2011 | 1991 Toyota Camry
How to unlock keypad of q mobile e900
Try this.
It stumped myself and some true experts once. We were having problems with the keyboard in a darkened room.
There is a Function ( "F" or "FN") key on the lower left of the keyboard. It's labeling is often blue in color. In low light conditions, you cannot see the blue coloring. It is used to turn a section of the keyboard into a calculator. That section will have dark blue numbers written on the keys that change function. For example the K may have a dark blue number 2 written on it. In other words, When you type the Alphabet you come up with some numbers substituted for letters and not all of the keys may function.
IN YOUR CASE PUSH THE FUNCTION KEY DOWN AND WHILE HOLDING IT DOWN PUSH THE KEY FOR THE CALCULATOR. IT SHOULD THEN RELEASE YOUR KEYBOARD FOR NORMAL USE. Hope this helps you.
Best Regards,
Mark
Dec 30, 2010 | Computers & Internet
Malibu 2003 remote opener does not work.
I've never seen a remote repaired successfully. I'm not sure why, it just doesn't seem to work. I wonder if the circuit board isn't flexing a little bit, and that dislodges the battery retainer. The flexing, in turn, might also cause microscopic cracks in the circuit board which causes it to work intermittantly.
Jan 26, 2010 | 4-Button Remote Start/Keyless Entry with...
Can not turn on! my garmin nuvi 200w I think it is locked,
if ther battery went totally flat place it on charge for an hour or so to revive it. Max battery life in storage is 4 days with a good battery.
Charging it even tho the charge light may not show should build up enough charge to eventually show the light and allow you to turn it on. It should remain on charge for 5hrs.
Other possibility is a collapsed cell in battery, replace the battery
Jul 24, 2009 | Garmin nuvi 250 GPS Receiver
How do I understand the dial on the dryer AEG lavatherm 335?
it should show a full sunshine for high and half a sunshine for low
Jun 23, 2009 | Dryers
Health & Beauty Logo
156 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
