Question about Compaq Presario Notebook
Screensaver shows on monitor but no Icons...
I first had the cable that had the vga on one end and the blue, green, red on other. When I hooked it up, I got a horizontal rolling colorful nothing.
I then bought the s video cable. I connected and the screensaver came up but no icons.
I only have V1 and V2. Ports on tv for the blue, green red, plus red and white. Below that is the ports for the red white and yellow, Then there is the cable connect and the s video connect.
The cursor is on one screen or the other. Take all the way to the left on computer screen it will then show up on right of monitor screen,
    Genius:
  • Compaq Master
  • 1,252 Answers
Also press Fn key along with the key that has marked monitor on your laptop keyboard
Posted on Oct 20, 2008
How do I hook my wii up to my gateway monitor?
If you are trying to hook it to a pc monitor you will have to get a converter box for the specific type of input. for example VGA,DVI,HDMI, the red, green, blue, is video out. The red and white is audio. You will also need speakers for audio. Most monitor do not have speakers. The type of cable you have for your wii is a component cable. There are also different dvi standards they are
If the monitor is hdmi you will have to make sure it has speakers if not you wont have any audio. So a converter box will be needed.
Oct 10, 2015 | Nintendo Video Game Consoles & Games
I have an Acer AL1916 monitor and I turned it on like normal yesterday and it has now got a weird green tint all over.. I've gone into the settings of the monitor and played with the red, blue and green...
sounds like a cable problem, can you find another VGA cable to try, look at the cable ends carefully for bent pins.(they are easy to bend by accident) wiggle the blue VGA connector while its on, try both ends, I think when you push the button your pushing on the cable momentarily which causes the monitor to function properly, likely the connector on the back of the monitor. if this helps, please use the thumbs up for feedback. cheers
Aug 26, 2010 | Acer AL1916B 19" LCD Monitor
My dell inspiron 530 shows a block with red, white, green, and read, can't get to the my programs????
That "red white green and blue" block is a color pattern tester. that means the monitor is on, but is not receiving a signal, so its running tests. If your monitor has Digital input and VGA input, you may just need to switch inputs. Look for 1 or VGA if youre using the blue hook up. look for 2 or digital or dvi if youre using the larger white hook up. Some monitors also have 'auto detect'. If you are in "auto detect' bbut the color box is still there, then your monitor is not receiving video signal from the computer. It could indicate a bad cable or no signal being sent by the machine. If you try another monitor, you can see if the machine is working. I would try a monitor setting for VGA-1 first, since thats most common.
Jun 25, 2010 | Dell Inspiron 530 Desktop Computer
Monitor turns green
This sounds like a problem with the cable. Monitors have Red, Green, and Blue signals. I have seen it where the cable has a short, or the plug has a bent or loose pin, and this causes the monitor to turn green.
It is also possible, but doubtful, that the video card is trying to run it as a Black and White monitor. B&W signal is sent over the green channel.
Jul 29, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
I DON'T GET A PICTURE WHEN I HOOK UP MY LAPTOP TO MY TV MONITOR.
on your laptop keyboard, press function button & monitor button at the same time .
Oct 18, 2008 | Computers & Internet
How do i hook up a tv monitor to my campaq computer
usually laptops have vga conector for external display, you may need a cable, vga cable.
vga cable varies depends on the connection that you have on the tv, if your tv supports vga connectors thats great, some tv doesnt have that option, thats where adapters go in to adapt what ever ports or connections you have on your tv.
some of the cable adapters that you might need.
vga to hdmi.
vga to rca.
vga to dvi.
hope that helps.
Oct 17, 2008 | HP Compaq Presario V2000 Notebook
Benq v772 CRT show only Blue and Green color
It has to be either a cable or an IC issue. Get your cable checked first (VGA cable)
Oct 01, 2007 | BenQ Value V772 17" CRT Monitor
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
Compaq Presario Notebook Logo
235 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
