Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Flashing 6 times
Kp53hs30 flashing 6 times??? What does that mean??
  • jkrueger10 Oct 19, 2008
    Thanks I will call one tomorrow :(
  • 320 Answers
A 6 flash shutdown indicates low B+, also known as a power supply problem. Not easily fixed or even located by an average consumer. Basically, you have to determine if the part of the power supply that supplies the voltage is bad, or is something loading it down? I know people don't like this answer, but you need a tech to narrow down the problem for you. Sorry!
Posted on Oct 19, 2008
Six blink code kp53hs30 cause and or service directions I have schametic
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Mar 20, 2016 | Sony Televison & Video
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
I have a 2001 sony 53' rear projection tv model #KP-53HS30. It seems has a wavy section on the upper left hand corner and lower right hand corner of the screen. All the bulbs are working fine but seems...
Try this. The follow was found on tv-forums dot com by Zyntar...
There is a secret service menu to converge the Sony KP53HS30.
Caution: Be careful, there are many settings that can be tampered with. Some may be hard to undo.
Procedure: (use the remote control for these steps unless noted)
1. Turn TV off with System Off (under flap on remote)
2. Press: Display, 5, Volume +, then Power. If successful, service text will appear on the screen.
3. Use 2 & 5 to select the PJE Category.
4. Press 9 to get to fine convergence adjusting.
5. Press 6 several times to get the convergence screen of choice. I like the grid.
6. Use the remote's arrow keys (joystick), move the brackets around until you have found the area to adjust. Press the center of the joystick to change the bracket from white to a color. Use the joystick to adjust the color. Press 3 to change color to adjust. When done, press center of joystick again.
Note: Try to keep the grid even and squared up.
7. Repeat steps 5 and/or 6 for all parts of the screen that need it.
8. Once done, you need to save your settings. Press: Mute, Enter. Then on the TV, press "Flash Focus"
9. Turn off power.
TV is ready to use.
Oct 20, 2010 | Sony KP-53HS30 53" Rear Projection...
No Power up. Has 3 relay clicks when you plug it in. No LEDs light up and no flashing code from the stand-by LED. Have service manual. Where do I start?
hello the best thing to do is turn the power off take the back cover off and visual inspect the boards in side get a good torch and check for any bulging capacitors burnt resistors if everythink looks ok then you will have to check underneath the boards for any try joints i hope this helps
regards
shaun
Feb 23, 2010 | Sony KP-53HS30 53" Rear Projection...
Kp53hs30 6 blink
Power Supply board is dead.Replaced the power supply board will solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
Feb 16, 2010 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Convergence problem, how to fix with my remote?
9. Turn off power.
TV is ready to use.
Jan 19, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Kp53hs30 light flashing 6 times
Hello worksofgrace,
I gave this advice earlier, but since your problems is just about the same, I hope this helps.
This problem is linked to a power supply issue. The SSB is part of the power supply chain and will cause system failure if the board is defective. I have seen to many of these type of modular power supply boards fail. The shutdown circuit is detecting excessive voltage/current, and in the process of turning off the set it may have blown something else. I am begining to suspect a design flaw, which happens from time to time. I would suggest having a qualified TV repair person take a look at the TV and work on it.
Thank you,
Shuttle83
Jul 27, 2008 | Sony KP-53HS30 53" Rear Projection...
SONY KP53HS30 rear projection TV screen suddenly turned blue....
The blinking 5 times is an error code meaning that the white balance has a failure. And because you are experiencing a blueish screen then your problem lies in the circuit of the blue picture tube or possibly the blue tube itself is starting to go bad.
C-Dog
Feb 05, 2008 | Sony KP-51HW40 51" Rear Projection...
Blinks 6 times
6 blinks mean low b error. you will ned to replace the g1 board
Sep 05, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
136 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
