Question about Toshiba 36HFX71 36" TV
Toshiba 36hfx IR
Fixed it.
Power button was sticking on TV and also found gunk on IR receiver window next to power button. Unplugged TV, cleaned both, sprayed power buttun with contact cleaner to free up. Let dry and powered up. Works fine. Sometimes its the simple stuff.
5 Suggested Answers
SOURCE: Volume go up to MAX, power button does not work
what is a tact switch and can i change it myself?
Posted on Mar 20, 2008
jojack2k5
  • 34 Answers
SOURCE: Toshiba TV Remote Control not working
REPLACE IR SENSOR INSIDE THE SET COMMON PROBLEM
Posted on Apr 12, 2009
stonephoenix
  • 563 Answers
SOURCE: The remote for my CT-820 Toshiba TV was working on
You'll have to contact Toshiba's part distributor in order to purchase a replacement remote. The company is Fox International and their number is 800-321-6993.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 06, 2009
  • 541 Answers
SOURCE: I have a Toshiba TV model 36A43 that won't power
It sounds like you have a switch problem at the front panel of the set. If a switch gets stuck internally the micro is trying to process the command and won't respond to any other commands. The only way to find out is to go into the set and desolder all the manual switches and see if the remote will work the set. It has a seperate detector for the remote. Thanks for using fixya. Good luck
Posted on Nov 11, 2009
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
Hi! My Toshiba 40RV525u TV has a problem, it turns off or on by itself. I checked the auto power off settings, the time is not set (it is 00:00). This happens very randomly. Now I just plug out in the...
My TV 40RV525U changing channels, menus itself for few months.
later, it turn on off by itself and unable to hold on a channel ( I use antenna)
What I did
Remove back cover.
DONE.
Jan 14, 2011 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 51H94 wont power. The light blinks green 3 times/sec
This problem was resolved by doing the following: turned power off to circuit; unplugged tv; removed back "grate" and vacuumed out dust; vacumed fan on right back side; spun fan manually a bit; jiggled fan connection near power cord; plugged back in and it worked. I suppose there was a loose fan connection, and the TV wouldn't power on without a functioning fan.
Aug 03, 2009 | Toshiba Televison & Video
I have a 32AF43 remote has stopped working
resolder the ir sender it sound like it the solder has broken free
Jun 23, 2009 | Toshiba 36AF42 36" TV
Powering up
Leave the box unplugged from the wall for an hour then try to power up again.
If it doesn't please post back.
Good luck
Jun 01, 2009 | Toshiba SD-H400
Apr 11, 2009 | Toshiba 36AF42 36" TV
Remote control range
It could be due to a few reasons, but we'll start with the easiest and the obvious. First I would check your batteries. Change them with some new ones. If that's not the problem, I would clean the IR transmitter on the remote and the IR receiver on the tv. Anything past that may require purchasing a replacement remote.
Jan 16, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
Echostar IR remote (Dish)
to set remote to tv
3)press pound sign
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
Toshiba 36HFX71 36" TV Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
