Question about LG Washing Machines
SOMETIMES WASHER DOES NOT OPERATES
I HAVE A TOP LOAD WASHER.THE PROBLEM IS THAT,SOMETIMES IT WORKS NORMALY BUT SOMETIMES IT DOES NOT OPERATES.I LEFT IT FOR 2 OR 3 DAYS,THEN IT RESTART OPERATE.IT DOES HAPPEN ONE DAY IT STOP COMPLETELY HALF ITS CYCLE AND I TRY MANAGING THE KEYS,NO RESPONSE AT ALL,PLEASE HELP ME TO SOLVE THIS PROBLEM.
I HAVE A KNOWLEDGE IN BASIC ELECTRONIC WHERE RECENTLY I FOLLOWED A COURSE.
THANKING YOU IN ADVANCE FOR YOUR KIND SUPPORT.
I"M SEARCHING FOR REPAIR MANUALS ON TOP LOAD WASHER.PLEASE HELP ME FOUND IT TO BUY.
  • Ahmed Jhumunn Oct 21, 2008
    SOLUTION IS HELPFUL BUT I WANT TO KNOW WHAT SHOULD I DO TO SOLVE THIS PROBLEM.
    THANKING YOU VERY MUCH Mr drcool1299.
    Scholar:
  • 121 Answers
It sounds like you have an interment problem with your control pc board. This controls the cycles and is located in the top panel. Can be perchest at an appliance parts store.
Posted on Oct 19, 2008
  • 958 Answers
That could be electronic controller. the problem with those controller are they are very well covered with epoxy. even the parts can not be tested for trouble shooting.
open it up and you will find out what i am saying.
tnx 4 using fixya,
drcool
  • francis rivero Oct 21, 2008
    you can open up the unit, check the electronics controller.
    now look for some sign of burnt epoxy or discoloration, this is a sign of over heating part. either a resistor or a transistor. check also the wiring harness that is attached to it. it could just be a simple case of loose wiring.
    if you found a suspected part, remove the epoxy by heating it slowly with a soldering iron. and as the soldered terminals appears, you can de solder the part to check and replace if necessary.
    tnx again and thank you for the rating,
    drcool
My Fisher and Paykel washing machine beeps every second and shows the following code 1&2 off, 3,4&5 on, 6,7&8 off. Have removed agitator and checked pump for blockages. Sometimes will do a full...
Each light has a specific number, so to work out the error code we need to know which side you are counting from i.e. left to right or right to left. Makes a huge difference.
Oct 08, 2017 | Fisher and Paykel GWL11 Top Load Washer
I have been given a Whirlpool AWM 312 by friends moving overseas and don't know how to operate it and would like to get a manual. My main problem is what drawer (front the left facing the machine) do I...
The manuals for most Whirlpool appliances are available here: http://www.whirlpool.com/custserv/index.jsp . Look for the full model number under the lid on the rim of the washer. AWM 312 is not a complete model number. Next is the washer a top loading or front loading machine? This is actually indicated in the model number - most Whirlpool models start WFW (front-load) or WTW (top-load). The exception is the compact washers (LCE4332PQ is the current model).
For the front-loading washers, the detergent goes into the largest compartment (usually the left-most part of the drawer). Top-loading washers that have a detergent compartment usually have it positioned at the top center back of the tub. Use HE detergent for high efficiency washers and do not use more detergent than recommended (using less is okay).
I hope this helps.
Mar 03, 2011 | Washing Machines
Washer will not operate error code LD We have unplugged washer moved clothes around and tried to just spin water out. All lights come on and sometimes the lid will lock and sometimes it want but washer...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Washer does not spin or agitate at all. Timer works.
Check your belt. It may have become loose.
On the top right and left of the front panel insert a putty knife about 3 inches in where the top meets the front panel.
This will release the front panel so that you can see the motor and belt operation.
Better still, a 5 month old machine call for factory authorized service.
Feb 24, 2009 | General Electric WBSR3140GWW Top Load...
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Kenmore washer just stopped
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, check/replace lid switch. Also try tightening the lid hinge screws on the left side. if these screws come loose, the machine will not operate
Jun 14, 2008 | Kenmore 24642 Top Load Washer
Kenmore washer top load
FAULTY LID SWITCH, LEFT TOP AND REPLACE IT
Nov 30, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
