Question about Philips ProScreen LC4600B&LC4700F Replacement Lamp - 482213410123 Projector Lamp
No Power to my CD RW device
Philips Model # CDD3610 /81 CD RW device in this computer tower (Gateway ATX Tower M#GP6-450) running Windows XP Home Edition Operating System.
Device has NO POWER whatsoever, is not detected in my Gateway BIOS, NOR in Windows Device Manager.
Device had quit running on its own many months ago. I have recently installed Windows XP Home BRAND NEW just recently.
Jim Crawford
fetford@yahoo.com
    President:
  • 1,996 Answers
Disconnect the power to the computer and ground yourself by touching the outside of the case at a screw. Open & remove the cover on the side of your computer and take a look at the back of the CD drive.
There should be two sets of cables attached to the back of the drive. One is a wide flat cable that attachs to the mother board. The other is a smaller set of 3-5 wires with usually a white or clear plastic connector that comes from the power supply (the box in back with a fan inside it). This latter is the power to the drive. Make sure it is firmly connected. If it's loose, seat it firmly. If it's not loose, check to see that the wide flat cable is seated firmly at both ends.
If these connections seem to be intact, you could try disconnecting them, then rebooting the computer, then shut down, unplug again and after grounding yourself, reconnect them. This will trigger the plug and play in xp to detect the cd drive and attempt to install it anew. If it works, you'll see a balloon window near the notification area that says new hardware found, shortly after you boot up and log into windows (with an administrator account).
If that doesn't work, I'd suggest that the drive itself may have died. You could probably install a new one yourself, but if you're uncomfortable with that, take it to a local shop and they'll be happy to sell you a used or new cd drive to fit your needs.
I hope this answers your question. If I can be of any further assistance, please feel free to follow up. And in any case, let us know how this sorts itself out.
Posted on Mar 26, 2009
Power button switch
Send a request to the following email address. Mention the exact model number like you did in your question and request a replacement front panel on/off switch. rma@raidmax.com
Nov 19, 2013 | RaidMax AURA ATX-927WB Black SECC Steel...
Have gateway that looks just like 510 H PENTIUM 2.4 but it is a celeron. Anyway I loaded xp pro onto it but it needs network driver so that I can get on internet
Do you have a network card installed in it? If so, run the ADD New Hardware Wizard from Control Panel to install the drivers automatically.
Have I solved your problem? If so, please rate this. ty.
Feb 26, 2010 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Gateway computer LX series need to recycle power before it will go into post.
The only reason I can see in a no POST issue is because of a defective hardware in your computer.
1. Try to remove all the cables at the back of your computer tower and power cycle it for 15 seconds.
2. Plug the power cord back in and the monitor cable only then start your computer.
3. Put the devices one-by-one to your computer tower until you see the faulty device.
4. If no faulty device detected after connecting all the connection at the back of your computer tower.
5. Try to open up your computer tower and reseat your Video card, memory, HD cables and CPU as well.
Let's investigate if the problem will reoccur.
Jan 01, 2010 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
I want to play mini cds in a standard slot drive in laptop.
You should notice in your cd tray a smaller cutout in the center. That is specifically for mini cds.
Jan 14, 2009 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Windows XP Home Edition - No Drivers.
vswright is right, you have to make a restore disk when you are happy that that system is running properly (this called system back up and restore) go to the HP support website (HP now own Compaq)
and enter the make and model of the pc and download the device drivers you need, if you experience any problems, get back to us
regards
Nov 22, 2008 | Computers & Internet
Lg tower pc
you need to go into bios at startup, press F2 Or Delete Or Esc on bootup. When you get into the System Bios. Change the boot device priority from HDD To CD/DVD To boot first.
Save/exit And when you reboot ( with windows XP in the Drive ) you,ll get options to format or re-install.
Mike @ Compurepair.
Mar 29, 2008 | LG GMA-4082N DVD±RW Burner
Bad motherboard.gateway atx tower
whatever socket that is 454 soket mobo i think or befor ethat so old look on ebay for one that can take your chip how do u know mobos bad no power or im open for chat anytime also thx nick helpap
Jan 06, 2008 | Gateway (4000597) Motherboard
Changing the desktop properties in windows xp home edition
it happen due to spyware that enable active desktop, there will be html wallpaper with fake links. if this the case try anti spyware to remove it even if u disable active desktop it will appier next time when you restart.
try CCleaner
or Spybot
Dec 06, 2007 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
182 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
