Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
R60 6o,ooo wont light at all glow plug does not get red but with a v.o.m. i get tone through the wires of the glow plug. is the board bad or is something locking me out?
  • 232 Answers
Your problem could be as simple as a blown fuse. Most R60's have a small buss fuse mounted on the Ignition Control Board. Replacement fuses are available at www.reddyparts.com . If the fuse checks OK then test to see if the control board is receiving power. If power is going in but not going out then, naturally the board is defective and must be replaced. An easy fix!
Posted on Oct 19, 2008
  • Jerry Magee
    Jerry Magee Oct 19, 2008
    ALSO, if your heater is equipped with a thermostat, troubleshoot the part to see if it is functional.
Glow plug light stays on, engine turns over but won't start
glow plugs dont last for ever
have them visually inspected
they need to heat up to spec or motor wont start
what motor or vehicle ?
May 31, 2016 | Cars & Trucks
Mercedes 300td wont start
It's likely a bad glow plug relay found on the left fender well. You may have bad glow plugs as well. You should hear a faint click when you turn the key to glow psn. . Open the hood and have someone glow it. The click should be abvious and the wires will run from the relay to the glow plugs. also obvious.
Oct 06, 2014 | 1998 Mercedes-Benz E-Class
My side by side hotpoint will not defrost itself..it's only 3 years old..just a simple water ice sbs
no defrost may be a bad p c ( main board ) or bad heater 9 most common ) and a defrost terminator . ( not to common ) .. mm
Aug 10, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Glow plug dosen't light truck won't start
PULL EACH GLOW PLUG OUT TAKE A PAIR OF JUMPER CABLES TO IT CLIP RED ON THE PART WERE THE WIRE HOOKS UP THEN GROUND TO THE SIDE IF LIGHTS UP GOOD IF NOT BAD (BECAREFUL ITS HOT) IF ALL IS OK YOU HAVE A BAD RELAY
Jan 29, 2010 | 1984 Ford F 350
My Goodman furnace wont light.
Open up the unit to get to the control board. Make a short jumper wire and disconnect the wires going to R and W terminals on the board. Connect the jumper to R and W. Depress the door safety switch. The circuit board should indicate a call for heat and the furnace should start. If it doesn't, look for a fuse that may have blown either on the circuit board or in the wiring. If the unit started by jumping the W and R but does not when you reconnect the thermostat, you either have a bad thermostat or a bad thermostat wire.
Dec 02, 2009 | Goodman GMS90703BXA Heater
I have a side by side and the refrigerator side will not cool. I have replaced heater element and also computor board. What else could be the cause
Gain access to the main control board , behind the refrig . Unplug the refrig . On the board , remove the blue plug , with 3 larger wires . The terminals on the plug , should be : wire1 , wire2 , space , wire3 . Using a short piece of insulated wire , with both ends stripped about 1 /4 " , insert 1 end into wire2 , and the other into wire3 . Plug refrig back in , and look in the freezer section at the bottom , behind the crisper , to see if a red heater glow occures . May take a minute or so . If no red glow , then the bimetal ( the round 1 " piece , with a blue and a pink wire going to it ) clipped on the top right of the coils , is bad ( since you already replaced the heater ) .
If you get a red glow , then the # 4 thermistor is bad . This is the 1 " white piece , with 2 white wires going to it , on the top left of the coils , which is just clipped on also . I would also recommend replaceing the # 5 thermistor , which is located at the bottom of the freezer , on the left , also with 2 white wires going to it . The number 4 thermistor , is the evaporator coil thermistor , and the number 5 thermistor , is the freezer temp thermistor .
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The back wall of my fridge is freezing up... I had a repair man replace two sensors and to no avail then I replaced the mother board and that did not work either... what now?
Unplug the refrigerator . Remove the motherboard cover . Remove the blue plug with large wires from the motherboard . Looking at the plug , you'll see wire1,wire2,space,wire3 . Using a short piece of wire with both ends striped , insert the ends into wire2 and wire3 . Plug refrig back in . Look in the freezer at the bottom of the rear wall , for a red glow . May take several min . If no red glow , replace the defrost heater AND the defrost thermostat (bimetal ) . If red glow , bad control board .
The defrost heater and bimetal , are behind the rear lower panel inside the freezer section . The heater is at the bottom of the coils , and the bimetal is clipped on at the top of the coils ( blue and pink wire ) .
Sep 06, 2009 | Refrigerators
Back wall freezes up on freezer side while fridge side is too warm. fridge temperature stays between 60 to 70 degrees
Is the freezer fan working ? If not , control board probably bad . Pull refrig out from wall and remove power . Remove the 8" X 10" panel and you will see the main control board . Remove the blue plug with 3 larger wires . The sequence is : wire1 , wire2 , space , wire3 . Using a short piece of wire with both ends stripped about 1/4 " , insert the wire into wire2 and wire3 . Plug refrig back in . Look in the freezer at the bottom rear for a red glow ( may take a minute or so ) . If you see a red glow , the main control board is bad ( the board you unplugged the wires from ) . If no red glow , then disconnect power to fridge , remove the jumper , and reinstall the blue plug and the panel .
Remove the food from the freezer section and remove the rear freezer panel inside the freezer . There you will see a round 1 " disk , clipped on top of the coils .Pt # WR60X10068 Defrost thermostat . At the bottom of the coils , you will see a heater . Pt # WR51X10042 Defrost heater . Replace both of these as the heater gets hot , and cuts off by the bimetal . he heater only has a screw on each side attaching it to the coils , and the bimetal just clips on . Easily repairable .
Aug 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
MODEL # GSS25KGMDWW.NOT DEFROSTING.HEATER AND TERMINATION THERMO IS GOOD. HOW DO I CHECK THE MAIN BOARD ON BACK TO SEE IF IT IS PUTTING FRIG. INTO DEFROST MODE?
On the back of the refrig , you'll see a panel about 8" X 10" . Disconnect power to the fridge . Remove this panel , and you'll see a main control board . At the bottom , there will be a blue plug with 3 larger wires going to it . Disconnect this plug from the board carefully . Looking at the end of the plug , you'll see wire1,wire2,space,wire3 . Get a short piece of insulated wire , with both ends stripped about 1/4 " . Insert one end into wire2 and the other into wire3 . Reconnect power to fridge . Check inside the freezer at the bottom , for a red glow . No red glow , heater or defrost t-stat(bimetal) is bad . If you get a red glow , either that main control board is bad or the #4 thermistor (1" white torpedo looking piece clipped onto the top of the coils)is bad (it tells the board the temperature of the coils ) or the #5 thermistor , located at the defrost drain . This tells the board , the freezer temperature . The way to check thermistors , is either a control board tester , or resistance test thru the wires at the top of the control board . I would go into this , but , not enough time , unless you submit a thread on how to check thermistors thru the main control board .
Aug 27, 2009 | GE GSS25LGM Side by Side Refrigerator
Wont power on
Needs Convergence amps replaced. Also fuses around this board are out. There should be small pico-fuses open around this board(replace)
Aug 26, 2007 | Hitachi 55FX48B 55" Rear Projection...
Heating & Cooling Logo
77 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
