Question about Indesit Dishwashers
I,ve not had this condenser long and the on off switch seems to be the problem as it keeps tripping the mains fuse. The button itself doesn't seem to click in but the machine is active
  • 47 Answers
Nothing is wrong with the dishwasher. all it is that the dishwasher is drawing to much current from your circut need to relocate it or find anther appliance that is on the same circut and relocate it
Posted on Oct 19, 2008
I have problem with a Bentley Continental GTC and that is that the driver information panel says 'Roof Fault' the error occured after not fully completing a roof opening cycle in one press of a...
If all else fails disconnect the battery for 30 min it will erase all codes on the vehicle for free instead of taking it to a service station and paying them to do it
Jun 28, 2013 | Cars & Trucks
How to reset my zanussi
Switch off the machine for a while. Check for moisture in the panel, check for any capacitor leak in the mains circuit. If you have a multimeter check the voltage to the controller section.
Also check the door switch, the inlet flow valve filter and the connectors.
If all these seems fine there are errors in the controller board section.
Mar 16, 2013 | Zanussi Washing Machines
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
May 12, 2012 | Indesit IS70C Electric Dryer
Lg air condition doesn't work when it is cold outside
Sounds like the crankcase heater. This is likely hooked to a temp sensor that is activated when it gets below a certain temp. There is likely a short in the heater and it trips the breaker. The heater keeps the refrigerant warm inside the compressor when compressor not running. Find a different technician.
May 19, 2017 | LG Heating & Cooling
Suddenly I have no power to my dishwasher. I checked my main house electrical fuses and they seem fine. Is their another fuse in the washer itself to check?
Do some more experiments...Check power is getting to the power point at the back of machine (maybe plug in a lamp or something if you don't have a multi-meter), check external cable for damage (while not plugged in). Is there any signs of power at all? Any lights that come on or beeps made? If your model doesn't have lights to begin with, it could be a problem in the trip switch in the door for example. There probably is an internal fuse... only problem is that if it did blow, it might have for a reason... keep investigating
Aug 12, 2011 | Maytag Dishwasher
White Knight condenser dryer trips the electirc
Hi i bought my dryer 4 years ago and within three months i had a technician to it3 three times, it had the same problem as yours all my fuses were tripping in the fuse box. eventually after 4 visits, the technician said there was a tiny hole in the back of the dryer which was letting condensation through and was dripping onto the motor. he put a small piece of rubber in the hole to make a stopper and it hasn't done it since. seems like a common problem but unfortunately only very few technicians seem to know how to solve the problem, thankfully it was still under guarantee at the time so got repaired, hope this helps and good look!!
Andrea
Dec 25, 2008 | Dryers
Dishwashers Logo
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
