Question about Toshiba 36HFX71 36" TV
Ir receiver not working Toshiba 36HFX71
TV remote control not working. Tested two remotes with camera and also one will control other devices just fine. Seems like IR receiver on TV is not working. Stopped suddenly. All other functions on the TV work fine.
Any ideas? I am very handy is this part available?
Thanks
Toshiba Dan
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Toshiba 32hfx71 / 36hfx71 remote control only sensing at one inch distance
Since the problem is common on two remotes, the source of your misery has to be inside your set, not with the remote. The receiver in the set may not be positioned as it should be since it is rare to have either end go 'a little bad.' They generally will fail totally instead. Any shop that services TVs will have a simple pen-like detector that will tell you if the remote is putting out enough signal to work as it should.
If your set has ever been repaired, the main board may not be sitting in the slots that act as supports.
You might try to hold the remote in several different positions; holding it below the IR window and pointing it upward, the same for each side and then above the window. If it seems to respond better from one or the other angle, then the receiver is not sitting square behind the window.
Posted on Oct 28, 2008
AJIN G
  • 6694 Answers
SOURCE: toshiba tv model32w2300A how repair? 0nly in the screen say do not put the power off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Jan 07, 2017
andygoacher2
  • 17 Answers
SOURCE: My Toshiba remote control se-r0077 sometimes works to control the DVD player and other times it doesn't. I've tried new batteries and the problem still persist s
One of the best ways to check if an infra-red remote controller is working properly is to look at it using a camera. (a webcam or phone camera will work) The camera will see the infra red radiation as visible light. If the LED lights up (on camera) consistently when buttons are pressed, then it may not be the remote at fault, but rather the receiver in the DVD player. Most of the time though, it IS the remote control at fault, and these are usually easy to get working again.
Couple of things to check are:
1) the battery terminals...
Batteries can leak and corrode the terminals in the battery compartments. Signs of this include rust, green coloured contacts, or a crystalline deposit. If you see any of this then clean the contacts using metal cleaner or some methylated spirit and cue-tips.
2) Broken wires connecting battery terminals to the circuit board...
The soldering in some remotes can be rather poor, and wires can sometimes come loose, especially if a remote has been dropped or bashed about a bit. Unscrew the remote and check everything is connected properly
3) Dirt under the buttons...
This can prevent a button from making contact with the circuit board properly. Unscrew the controller and separate the rubber button pads from the circuit board check for dirt both underneath the pads AND on the metal contacts on the circuit board. Clean as required with methylated spirit and cue-tips and then reassemble.
Hope that helps!
Posted on Jan 08, 2017
Remote doesn't work. have purchased after market units and they don't sync up either? What to do?
Return the tv universal remote where u bought it,get ur money back.If none of the tv univeral romote programming codes on the owner manual codes for ur tv make and model don't even work and don't have any responses for ur tv make and model functioning all.Try website like Remotes.com to buy the tv original remote or a very closed compatible clone one.
Sep 03, 2011 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Toshiba 26AV600T When turn off by remote control ( stand by lamp still illuminate) I can not turn on by remote ( ON/OFF in the same button ) Q: TV set OR remote is bad. Thank you /// Thongsuk. My Mail:...
Tries the tv manual control power button pushes a couple of times on/off,if tv it turn on and off with no problems.Yes.Than the tv remote have problems.Try Remotes.com to buy the original remote.
Jul 13, 2011 | Toshiba 26AV502U 26 in. LCD HDTV
My Toshiba flat screen won't turn on with the remote control. There's a red light showing but no reaction. I have checked the batteries and put in new ones, definitely the right way round. Is...
Can you turn the TV usin g the power switch on the TV?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
http://www.remotecontrolscenter.com
http://www.newremotecontrol.com/
http://www.replacementremotes.com
http://www.newtvremotes.com
http://www.everytvremote.com/
Jul 01, 2011 | Toshiba Televison & Video
Toshiba remote control CT90300 wot working at all desp;ite having inserted and checked new batteries, The TV is working fine when switched on manually. Had noticed for a few days that the volume conrol...
Let's find out if it is the remote or the remote IR receiver in the TV.
www.remotes.com
Mar 18, 2011 | Televison & Video
My sensor in the TV for the remote isn't working. Is there a way to reset it?
It may be the IR receiver inside, but look at he back to see if it has a smll jack for External IR jack on the back of the TV, IF it does, try inserting in and out using small headphone jack to activate the switch inside the jack a couple times. You also need to verify that the remote is seding IR signals.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 12, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Toshiba 36A50 no longer responds to remote controls.
The only common problem would be on the Toshiba Remote. Make sure you have the switch on the remote set to "TV' and not Audio, or Video. Beyond that, if you have a digital camera or a cell phone with a camera with a viewing display, point the remote at the camera and push any button. If it is sending IR, you will see the flashing from the remote on your camera/phone display.That will just confirm the remote is sending signals. The only other possibility is that your IR receiver on the TV is bad, This happens, but it's not very common. Hope this helps
Sep 30, 2010 | Toshiba 36A50 36" TV
Oct 28, 2008 | Toshiba 32HFX71 32" TV
IR Receiver
Are you serious?
In case you are serious, IR=infrared.
When you point your TVs remote control toward the TV and press a button, it is the IR receiver on the TV which receives the IR signal which is transmitted from the IR LED (Light Emitting Diode), which is the small bulb like part, on the front end of your remote control.
Any device using a IR remote control, must have an IR receiver to gather the siganl being transmitted. The IR siganl is a coded message of instructions for the device.
Dec 08, 2007 | Jazz DV-179 Digital Camera
Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
Remote Control stopped working
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
Otherwise the problem will be with the remote sensor or related components of the device.
Aug 27, 2006 | Toshiba SD-H400
Toshiba 36HFX71 36" TV Logo
136 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
