Tv went out while on (I was alsleep). Upon trying to turn it on, green light comes on, instantly goes back out (manually and remotely) I have replaced fuse. same problem. Need help!!
Sounds like the Horizontal Output Transistor shorted. TVs are dangerous to work on if you are not trained. The transistor can be checked easily with a dmm. If it is bad the flyback should probably be replaced too. If it is ok, you have a short somewhere else and need to isolate systems until the fuses quit blowing or hook it up to a variac and do checking to see where the short is. My bet is on the HOT. Again, if you are not qualified have a professional look at it. Good luck.
Watched TV today and turned it off mid afternoon. Just went to turn it back on & it will not come on. The blue like comes on from the red light when I turn it on, but goes back to red 5 seconds later and will not turn on. HELP !!!
