Question about Canon PC1061 Copier
Cannon PC1061 making dark copies
I've cleaned the rollers, but the copies are still coming out very dark. I've even adjusted the exposure setting to the lightest setting & I still am getting dark copies. Do I have to take it in to a repair shop to get it serviced?
    Scholar:
  • 62 Answers
OR you can do it yourself.
your problems seems to be Dirty Mirrors.
Your copiear has 6 mirrors that need to be clean up. 5 of them are kinda easy access. the other needs to be clean thru something thiner than your fingers. (you can see the mirror but no way you can reach it).
Now dont worry (not yet) about that 6th mirror since THEORICALLY it doesnt get dirty.
So try first to clean up the other mirrors. and see what happens.
They are located below the platen glass (remove it) and be careful with the lenses (do not touch them). clean everything that seems to reflect light Or images.
If nothing changes you may want to try out with a new cartdrige. Your drum may be done.
Posted on Jan 26, 2009
Switching on in morning first few copy come black after going through roller clean option copy become OK cannon ir2010
it is very normal problem in Indian Atmosphere (Reason- Moister on Primary Charging Roller PCR) do not replace anything. try to making copy without Tonner Cartridge.
Feb 25, 2015 | Cannon Office Equipment & Supplies
I have a new 580EXII mounted to my Canon 7D. I do not seem to getting the "double flash" (not sure what the technical term is) that I expect and pictures are coming out dark. I'm think...
Holly, I believe you are referring to the pre flash for the ETTL function. both flashes happen so so fast that it looks like one flash. If your pictures seem dark make sure your flash is set to ETTL (press the MODE button unlit ETTL is displayed) this way the flash output is automatic. If it is still too dark you can change the flash output by adjusting the FEL (flash exposure composition) by pressing the button in the center of the dial until +/- is displayed the turn the wheel to select a + exposure (you can adjust this in 1/3 stop increments) then press the center button again. This can be found on pg 14 of the manual
Hope this helps.
May 24, 2011 | Canon Speedlite 580EX II (1946B002)
Our copies and starting to come out dirty and
Dark copies in that machine means the drum it's getting old. If adjusting the exposure to light makes the copies better, then the drum is the culprit.
Apr 28, 2010 | Kyocera KM-1510 Copier
COPY PRINT OVERLAP AND DARK
need to replace the drum unit.
Jan 20, 2010 | Canon PC1061 Copier
Cannon 6 RE PC gives black copies
does the lamp under the platen glass turns on when copying? if not you might need a new exposure lamp...but if you get an image but its very dark, if you are mechanically inclined you can clean the mirrors and lens and the bottom of the platen glass because after many years of use dust will make the optics dirty and cause the copies to be very dark. hope this helps.
Dec 31, 2009 | Canon Office Equipment & Supplies
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
l For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
Jul 27, 2009 | Sharp Office Equipment & Supplies
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
Adjustment program
Try cleaning the Auto Exposure sensor, or disabling the AE feature in standard settings. Some copiers have exposure calibration in standard settings too. Increasing the lamp intensity may cause further premature wear down the process line. (What machine have you got?)
Aug 27, 2007 | Gestetner - DSm660 Digital Imaging System...
Canon 6025
Your problem is most likely caused by dirty optics. Place a sheet of paper on the glass & make 1 copy with the lid up. Look under the glass at the mirrors on the scanner & see if there is any dust on them. If so,turn the copier off & unplug it from the wall, remove the glass & wipe off the mirrors with a DRY cotton rag. There are 3 mirrors on the scanner assy. There is also three mirrors under the lens cover that should also be cleaned. After cleaning the optics, make a test copy.If your copies are still to dark, press the additional functions key & select exposure adjustment. You can lighten/darken all copies by changing this setting. If you have any problems or questions my email is bspier@carlsonsupplies.com Good Luck!!
May 29, 2007 | Canon NP 6551 Black and White Copier
Canon PC1061 Copier Logo
315 people viewed this question
old marine
old marine
