Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
Cutting out I have a p500-2 and it is bridged for some reason when I hit my brakes the amp seems to fturn off. sound is great when it is working but really pisses me off when I stop at a red light. send help please...
    Problem Solver:
  • 6 Answers
Hmm.. this sounds to me like you have your amp connected through your fuse box.. if that is the case, you most likely have it fused in with your brake lights.. you definitely need to have that amp running a direct line with inline fuse to your battery, directly.
Posted on Oct 20, 2008
Hit the start button and nothing happens 2008 750 brute force
Check your starter solenoid. You can trace it by following the power wire from the battery to the small solenoid block that contains a 30 amp fuse. You can bridge the posts on the solenoid by using needle nose pliers or whatever else you may have. If it starts up or you hear the starter run, you have a bad starter solenoid.
Feb 02, 2016 | kawasaki 2008 Brute Force 750 NRA OUTDOORS
I have an Epiphone Les Paul Custom Silverburst, and it's pretty new and has worked great until now. It seems my bridge pickup lost tone and volume for some reason. My volume and tone knobs are cranked...
Need more info: 1- does the volume control still change the level? 2-Does tone control still change the tone? 3- What happens when in the center position on pickup select switch? Put pickup switch in center position (both pickups active). Then take a coin and tap on the pickups. Does bridge pickup sound lower? Lastly remove rear electronics cover and inspect all wiring for something loose or disconnected.
Aug 26, 2011 | Epiphone Les Paul Special II Guitar...
Have a QEP 24" bridge
blade might be to tight, loosen the nut that holds the blade,if that dont work,blades gotta be hitting something,if its a new blade measure it up to your old one to check size,make sure its a wet cutting blade,some continuous rim blades are made for hard material like granite,or dry cutting , good luck
Feb 17, 2011 | Saws
My subs cut out everytime I hit a bump.
I would say the wiring, in particular the earthing for it, also check any "Compression" fixtures.and check ALL joints etc. To be sure give the actual Amp a gentle tap, and see if that brings on the fault.
Feb 21, 2010 | Rockford Fosgate Punch 401S Car Audio...
Hello. I have one (1) XS-L1035 being powered by a JBL gts 180X 2/1 channel amp. The sub works fine if i power two(2) subs thru 2 channels BUT if I try to bridge the power to one sub the amp cuts out. Is it...
It sounds like the problem is with the amp. try using the other sub in bridged mode and see if it still turns it off. If it still turns off then its definitely the amp. In 2 channel mode you are using each channel at 4 ohms right? and in bridged mode to 1 speaker it should be throwing a ton of power on a 4 ohm load as well,it should work fine bro -its gotta be the amp
Jan 30, 2010 | Sony XS-L1035 Car Subwoofer
Amps on woofers are fine just won't hit
your probably making your amp run to low ohms if its a 2 channel amp bridged to one channel you can probably only run it at four ohms
Also seeing as your subs are 2ohm dvc you can't wire them individually to 2ohm and use each channel separately. So i'd recommend buying a 2ohm stable monoblock or running it at four ohms. a 1400 watt amp'll still pound at 4ohms and it'll extend your amp's life span
Aug 29, 2009 | Pioneer GM-7200M Car Audio Amplifier
One channel of the amplifier seems to cut out
I see now how it could have happened to both amps. Yes, this triple speaker combo will cause this problem.
Next time if you want to run speakers like that, instead of parallelling them, series them.
That way the load is balanced between the speakers.
Here is a great primer, dont worry about the calculations and mumbo jumbo, the pictures should tell you what you need to know to get it done.
also when you talk about bridge, that is usually done on the amp rather than the speaker. For example I could have a 4 channel amp, and bridge it to 2 by combining the channels, BEWARE not just parrallell again, there will be a specific order for each different amp and it will be marked.
You can also bridge a two channel amp to make one Single channel amp with almost double the power, but again only to one channel, now that its bridged.
Hope that helps once again. I'm going to look up that amp, if you want more specifics.
Jan 09, 2009 | Onkyo Audio Players & Recorders
Mtx blue thunder 752 pro
When you bridge amp they some time double in power output into a certain load. If the actual load of your speakers are lower than the required bridged load the out put of the amp will proportionally try to increase again. You have to match your loads to the specs of your amp. Use your manual to see what is required, then use ohms law, for adding resistors in series/parallel to make your speaker load match. For more info please reply.
Nov 21, 2008 | Car Audio & Video
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
79 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
