Sticking dials on washing machine
Hi, i have the above mentioned washing machine and my girlfriend or one of her friends (probably during one of their ladies nights in) spilt something down the front of the washing machine and now the dials are sticking and its difficult to get it to stay on 1 programme and sometimes to move at all. I was wondering if there is anyway to remove the dials *without breaking them* to clean and remove the sticky source?
any help would be greatly appreciated
  • jamie longland Oct 19, 2008
    sorry, i forgot to actually write the type of washing machine its a zanussi zwf1221w
    hope that helps more than just saying waching machine
  • 17 Answers
SOURCE: hotpoint wma54 washing machine
Being fairly mechanically adept - I tried this on my old Hotpoint WMA31 -- it took around 90 mins to get the drum out (virtually everything had to come out) and 1- mins to split it in two - then another 30 mins to knock the bearings out. I then ruined one new bearing trying to knock rather than pull it in and had to order a second set - then whatever I tried I could not get the drum fully back on the spindle (which was rather pitted) so ended up scrapping it !
As an aid to putting it back together I took 32 digital photos of different stages of getting the drum out so that is a measure of complexity...
Posted on Nov 25, 2007
  • 1554 Answers
SOURCE: Frigidaire FWTr445rfs1 front loader - door closed but buzzes during washing
by the way it too fixya over 14 hrs to relay that message
Posted on Apr 16, 2008
  • 20 Answers
SOURCE: Squeaky, noisy washing machine
Belts are an easy change. You access from the back of the machine. 3 or 4 screws take off the plate whihc will expose the belt. BE SURE TO UNPLUG 1st! so you don't get scocked
Posted on Jul 13, 2008
SOURCE: Baumatic MEGA WDSS washing machine
go onto type baumatic megawdss washing machine, if this does not bring anything up scroll down until you see it in the listings. type in the code it asks for (this will be supplied underneath, its just to stop cumputers auto logging) and then download then manual. good luck
Posted on Dec 29, 2008
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
The spin dry of the above mentioned washing machine spin dry not working properly cuts off what parts are required to fix this ?.
If a machine is out of balance when spinning it will shut down---there's an unbalance switch that controls this---also on some machines if not properly set level or feet not touching the floor causing the machine to rock---it will shut down---the remedy for that is to redistribute the clothes then is should resume spinning----another issue could be the timer----out of sequence or jumping ahead during that cycle---has the timer/control ever been wet as this will cause some issues---this is my thoughts on this--good luck
Mar 16, 2015 | Washing Machines
My front loader washing machine euromaid WM5 makes a terrible noise during spin cycle I think something like a screw is caught behind the barrel how can I access it ????
Hi! It's probably a bra wire if u have a woman in your life. They quite often get stuck around the heating element near the bottom of the drum. Get a bright light and stick your head in to see through the holes and see if you can pull it out! Hope this helps.
Feb 02, 2013 | Washing Machines
I need the users guide for the above mentioned model of washing machine
Unfortunately you do not say 'above' what the make and model is......but it doesn't matter anyway ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Mar 24, 2011 | Washing Machines
Maytag top load washing machine model LAT9306AGE.. the timer doesn't spring back out when needed to during cycles
the timer on all maytag's ( top load turn clock wise/ push in to stop/ pull to start . the spring back ??? the timer shaft may be sticking and is hard to turn . remove face cap and clip pull dial and lube with a light oil or spray lube / reinstall and this moy help .. mm
Dec 02, 2009 | Washing Machines
Suddenly off during filling
I called a friend who used to have a Maytag store and is an electrician, who said it was probably the lid switch assembly, and we checked it, inside the panel back, could not get it to work, so today he replaced it and it works fine! That little plastic part controls all the electrical and operating actions of the whole machine.
Jan 09, 2009 | Maytag Washing Machines
Washing Machine won't spin
Could be worn carbon brushes, or possibly defective shock absorbers
Mar 26, 2017 | Tecnik TKL9290 Front Load Washer / Dryer
Washer dryer sticks on j cycle does not spin or drain
check no foreign object stuck in pump impellor and that it turns freely. if that is ok then check continuity thro drain pump. if no muiltimeter, try connecting drain pump to mains direct to see it works
Aug 21, 2008 | Zanussi W1242W Front Load Washer
Asko 12605 overheating the wash water
(even not taking in hot water when filling before the wash stage which seems good)
The washer fills with cold water then heats it up 3 degrees a min. Your problem does sound like a faulty thermostat. Especailly if the glass door does get hot even if it is on 85f.
May 29, 2008 | Asko Washing Machines
Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se for spares.
Best regards, Dag Gulbrandsen, Norway
Apr 02, 2008 | Asko Washing Machines
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
