Sony Grand WEGA KDF-42WE655 42 in. Rear Projection HDTV Television
Problem for Sony Grand WEGA KDF-42WE655 42 in. Rear Projection HDTV...
Sony 42" grand wega LCD
By abbyt on Jun 19, 2006
I have pink spots on my screen. when you look at the surface of the screen, there are no scratches or any other type of damage. the pink spots appear on every channel and every mode (DVD, satellite, etc ) they are blotchy and all over the screen, and I am not sure but they seem to be getting worse. any ideas?
Same Problem
Mar 01, 2009
-   DO NOT buy Sony...They have a known problem with these TV's and they simply are not standing behind the product.. -   Guest
Oct 03, 2008
-   I also have Blue spots and a blue halo around the corners of my 42" grand wega. My TV is only 4 yrs old. -   visert
Sep 10, 2008
-   EVERYONE CALL SONY- SONY HAS EXTENDED ALL OF OUR WARRANTIES. i have this same problem with my 60" wega. i called sony and they explained to me that the problem was the optical light box. it cost a grip to fix even for them...so instead of fixing the problem they offered me the best true flats they had at way less than the actually price. i bought a 46" bravia for less than 550 including tax. i still have my 60" but until i get it fixed on my own this 46" will definitely do. i hope this helps you all
-   archiecando
Aug 25, 2008
-   i HAVE THE SAME PROBLEM. pINK BLOTCHY SPOTS ON MY SONY TV. [LEASE LET ME KNOW WHAT THE PROBLEM IS-   ROOTZ142
Aug 12, 2008
-   Pink Spots caused by dust-   coppertone11
Best Solution
posted on Jun 03, 2008
Very Helpful)
Owenator
Rank: Apprentice
Rating: 96%, 6 votes
I just vacuumed out my 42 wega and it looks 100% better. Not for the faint of heart but it was free and only took me 2 hours.
http://repairs.sunnyoasis.com/sonylcdtv/
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jan 10, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
We bought the extended warranty with our TV, the company came out and replaced the optic block and no more pink spots. Tech would not offer any info on my so many people have troubles, told me it was probably dust but would not happen again, why not? everyone has dust in their home and I dust quite freq.
When I called they told me it was a problem with Sony.
Solution #3
posted on Mar 31, 2007
Helpful)
tony91
Rank: Guru
Rating: 86%, 74 votes
you have dust inside your optical block.
you can have a expert try to remove the block, and blow it out with air .
if that do's not work then the , optical block can be replace .
optical block cost around $550 to $800 + LABOR
Comments:
Apr 05, 2007
- one dot of dust in optical block = large circle
I have fixed many of these
sony wont be truthful that thay have a problum.
I beleve there is someoneworking on a class acttion law suite on this.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Nov 24, 2006
Helpful)
TalentExtras
Rank: Apprentice
Rating: 88%, 6 votes
NO remedy....many WEGA owners have this SAME problem...do not take my word...google "Pink Spots Sony WEGA"
PINK SPOTS ARE FROM DUST COLLECTING INSIDE THE SCREEN
Not covered under warranty either...Sony claims that is an enviornmental issue. We all all SOL sorry to say...plus Sony denies receiving simular complaints...seems we call Sony they just don't document or are being untruthful.
FYI...I live large in upscale clean home. In my opinion...this is NOT NORMAL for a 2000.00 Projection TV.
Was this helpful?
Yes
No
Solution #5
posted on May 01, 2008
Helpful)
tanran
Rank: Apprentice
Rating: 83%, 6 votes
Call (888) 649-7669, tell them you have spots, they'll give you a local shop number to call and they will replace your optical unit (Optical Drive) at no cost to you, end of story ^^
Was this helpful?
Yes
No
Solution #6
posted on Jun 22, 2006
Somewhat Helpful)
hardrocko
Rank: Guru
Rating: 85%, 924 votes
Sounds like you are describing a slight misconvergence. Go to the setup menu, select convergence and do a complete convergence setup. If this doesn't solve the problem you probably have a bad digital convergence box and will need a technician to replace it.
Was this helpful?
Yes
No
Solution #7
posted on Dec 13, 2007
Somewhat Helpful)
arozisaroz
Rank: Apprentice
to JudiRoddis-your problem may be covered under the Sony updated warranty info. On their website they are offering to pay for replacement on units with the blue screen problem.
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDF42WE655&news_id=206
Was this helpful?
Yes
No
Solution #8
posted on Mar 23, 2008
Somewhat Helpful)
Luvlee
Rank: Guru
Rating: 89%, 56 votes
The spots you are seeing is dirt collecting inside your TV mostly in the LCD cube. The LCD cube is what gives your Soney that great picture. It is easy to clean with just an air hose but be careful with the LCD cube because it is very fragile and easily damaged.
Comments:
Apr 12, 2008
- I gave the correct information about these pink spots being dust on the LCD cube (also called the optical block) and the information was rated inappropriate! I clean and repair Sony LCD cubes (optical block). Please do your homework before rating!
Was this helpful?
Yes
No
Solution #9
posted on Sep 14, 2007
Somewhat Helpful)
PeterKiryluk
Rank: Guide
Rating: 90%, 18 votes
If its a LCD screen you may have liquid inbetween the layers of the screen. Thats only a possibility if you had the unit near some kind of water or windex mayhave gotten in it. Only way to get rid of it is to leave it in a warm place for a long time. or take it apart and dry it.
Was this helpful?
Yes
No
Solution #10
posted on Apr 11, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem. Went by the dealer I bought it from, explained the problem. He said its a common problem and that Sony extended the warranty on this part. He ordered the part and received it the next day, it took one day to repair. At no cost to me. I believe its called the optical light box. Picked the set up today and the picture is perfect.
Solution #11
posted on Dec 08, 2009
Very Helpful)
lar2cha
Rank: Apprentice
Rating: 100%, 1 votes
I have a 5 yr old Sony Grand Wega 42 projection also. It has developed a blue glow about 2 inches wide on the bottom of screen and a larger blue color on the lower right corner of screen. And when the set is turned off, they're a dozen blue dots appearing on the screen. I'ved changed the light bulb 1 yr ago and I was wondering if removing the bulb could I get to the area where the dust is located and vacuum of wipe it off! Any ideas, can't get any from sony! Picture quality is great otherwise. lar2cha@bellsouth.net
Was this helpful?
Yes
No
Solution #12
posted on Oct 14, 2009
Very Helpful)
hellbentzomb
Rank: Apprentice
This tv is a piece of junk! I've had the optical box replaced once due to a blue haze and now it's doing it again with a giant blue spot on the screen and "stars" on the other side. I called Sony and they told me I am SOL. Don't buy Sony!
Was this helpful?
Yes
No
Solution #13
posted on Nov 28, 2007
Very Helpful)
ima_rm2000
Rank: Guru
Rating: 88%, 171 votes
if you put the set on an unused input and darken the room. do the spots look like round snowballs? if so you have dust in the optics, a technician should be able to clean it..if there are jagged lines in the picture then the lcd screen is bad ant the optical block needs to be replaced..what is the exact model number of the set?
Was this helpful?
Yes
No
Solution #14
posted on Jul 03, 2009
Not Rated)
nernie1969
Rank: Apprentice
Rating: 0%, 0 votes
Sony does know about this issue and understand the problem. I called sony for tech help, and right away they told me it was the optical block. They offered to sell me a brand new Bravia LCD 46" for $225.00 plus tax and they will take care of shipping. I took their offer and will not look back. They know that this TV has ventilation issues and are trying to make it right by making the customer happy.
Was this helpful?
Yes
No
Solution #15
posted on May 22, 2009
Not Rated)
zim zim
Rank: Apprentice
Rating: 0%, 0 votes
to every owning a rear projection tv some of you these color blotches this is very common first it is and it is not your fault.its is your fault for not reading maintenance manual then the company or the seller dont tell you that this is a high maintenance device there are filters and vents on these units thei need to be cleaned every week. a small amount of dust is enough for a melt down.lcd's are very sencetive to cold and heat this is liquid folks freeze and it will expand heat it it will do the same or dry up so when you throw the projection tv in the play room put someone in charge of cleaning the filters and vents and it you got these color problem its to late need to change the lcd's. i've done it its very easy find the part is not because those a-hole's the mfrg wont sell the parts so sorry for your lost. i have these projection
that i paid almost nothing i maintaine them and they work beautiful .if your's is in good condition and have one color problem find the same unit with other issues like no power and buy it cheap and have some tech guy change the lcd for you.if your in the boston area i might be able to help.
Was this helpful?
Yes
No
Solution #16
posted on Aug 12, 2008
Not Rated)
coppertone11
Rank: Apprentice
Rating: 0%, 0 votes
I think it's safe to say that we all have the same common problem with the pink spots. I too was told it would cost about $1200 with labor to replace the optical block. As a FREE solution, I would like to get in there myself and clean the optical block, lens, and mirror with a soft cloth to remove the dust. Does anyone know the proper instructions for removing the front panel to get in there? I have taken apart all of the screws on front, but it's not coming off, and I'm afraid that some wires are still connecting.
Was this helpful?
Yes
No
Solution #17
posted on Jul 12, 2008
Not Rated)
dwars927
Rank: Apprentice
Rating: 0%, 0 votes
My 4 YO 50" $ 2,800 Wega is exibiting both spots AND the creeping blob. Called SONY support. They told me to unplug TV and replug . No good. They sent out a SONY repair guy. They now want $1,200 to fix this piece of junk!! I was refused a fix saying is too late. I am filing complaint with NY Attorney General and suggest all here do the same in their states. This is FRAUD. I can get a new 46" flatscreen for $1,600 with updated tech.
Was this helpful?
Yes
No
Solution #18
posted on May 17, 2008
Not Rated)
scorpion_sag
Rank: Apprentice
Rating: 0%, 0 votes
I bought my wega 42 in 2006, they tell me at sony its magnetic. Likely from the peakers. They are wrong. And no dealer, or shop I have contacted has said anything about replacing anything for free, the only thng that is availble for these units, is a software upgrade to fix a power problem.
Was this helpful?
Yes
No
Solution #19
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Called sony @ (888) 649-7669. explained the problem, they told me there is an extanded warranty on optical blocks and they are aware of the issue and gave me a number to call and have someone come out and look at it...
we'll see
Solution #20
posted on Mar 16, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i have a 42inch waga and it has a giant yellow spot and blue specs dotting the entire bottom of the screen..
what is going to be done about and how do we go about fixing i.. thx
Solution #21
posted on Dec 01, 2007
Not Rated)
gray fox
Rank: Apprentice
Rating: 0%, 0 votes
it's not worth the aggravation. I am going to trash the unit, inform others not to buy Sony, and buy a new TV from another manufacturer. you would expect after paying $2500.00 for a TV that you would at least get 10 years out of it. or at least customer service, which at Sony is nonexistent.
Comments:
Apr 12, 2008
- I agree, I am referring all my friends to buy Samsung. I have put signs up, and reported by word that sony, I cannot even capitalize their name any more, is nothing but junk!!!!
Was this helpful?
Yes
No
Solution #22
posted on Aug 29, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
how bought dust on lcd projecting it bigger
I have exact same problem and am looking for fix im shure its dust!
Popular Solutions for Sony Grand WEGA KDF-42WE655 42
Questions and Unsolved Problems for Sony Grand WEGA KDF-42WE655 42
Do you recommend Sony Grand WEGA KDF-42WE655 42 in. Rear Projection HDTV Television?
Answer
Answer
My Sony KDF-42WE655 won't turn on by remote or power button no light is flashing
Answer
My Sony Grand Wega KDF-E42A10 recently has had the color a little off. I have tried to adjust it but... (More)
32 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 11, 2008
yellow rainbow on the screen
Comment by Guest, posted on Jun 08, 2008
My sony is less than 3 years old , I can't even watch a hockey !
Comment by scorpion_sag, posted on May 15, 2008
Have exact same issue, bought Grand wega 42', years later spots arrive, talk to sony, they say maybe the speakers are too close. And unplugged unit for a couple hours. Did.nt work, warrenty is out. And I got ripped off in this deal. The sony receiver is another issue. Bu other than that I dont klnow hwat to do.
Comment by sherridan, posted on May 09, 2008
I have pink spots on my kdf \42 also.
Comment by Guest, posted on Apr 30, 2008
I have the same exact problem on my sony wega 50" set. It's driving me crazy! Could it be dirt on the lamp or bulb?
Comment by carnut56, posted on Apr 28, 2008
Set defaults to 4:3 aspect ratio every time I turn it off. I have followed the manual instructions: click menu, scroll to video, set 4:3 default to off......all to no avail. HELP!!!
Comment by thrill92, posted on Apr 28, 2008
i have spots also just noticed over the past few months. Purchased in march of 05. What are our options? I do have an extended warranty through the furn store.
Comment by Guest, posted on Apr 26, 2008
We have pink spots on our tv as well-sony wega
Comment by bookwalk, posted on Apr 09, 2008
Purchased this unit in February 2005. Just last week, saw a bluish purple haze along the bottom just to the right of center. Called Sony--Reps don't seem to know much--talked to Supervisor--this is supposed to be covered under the Extended Recall through December 2008, but they could not answer this question: Is the replacement optical block of the same design and so will it go out in another 2-3 years? If so, then what--we are stuck?
Sears is due to come for evaluation tomorrow and I am going to video tape the whole process, so that, in 3 years, maybe we can just do it ourselves???
Comment by Guest, posted on Apr 06, 2008
kdf-42we655 -pinkish/purple fingerprints on screen. REplaced the bulb already before finding this information. $100 later ....
I'm going to call sony and report it.
Sony customer service 800-222-7669.
To be continued.....
Comment by berude, posted on Apr 01, 2008
Have like pink clouds even with a black and white movie, it is slowly getting worse. Too bad it gets such a great HD picture. Sony said to call a Tech as my warranty ran out. It will be about 1000. to get it repaired.
Comment by milkman873, posted on Mar 29, 2008
I can tell you all right now, its not "dirty optics". It is the inside of the first of two layers of the screen. When I got my 42", it was a display model and the spots were noticed immedtiately. It was under warranty, so Sony replaced the screen. 3 years later, new spots...no warranty, so I decided to open'r up and take a look. I DO NOT recommend this...the layers of the two screens are placed together in a clean room....unless your house is in a bubble..you will get a dog hair or two because of static. So anyways...I used a dry cloth to wipe the inside of the first layer (which is the back of the side facing out)...and I used a dry cloth on the inside of the second layer. Keep in mind..I was not able to see any of the spots holding up either piece to a light source. After cleaning the inside of both pieces..I wet cleaned (water on wash cloth) the back of the second layer and windexed the mirror...which was disgusting. After ALL this work and 3 hours later, the spots were now pinkish purple....so I either made it worse or I was making it better but didnt do enough. I am calling Sony on Monday and complaining about the absolute junk of a screen they put in such an excellent television. Hope this helps out.
Comment by Guest, posted on Mar 18, 2008
Same problem as others. Pink spots starting small then growing in size and number.
Comment by D35J, posted on Mar 10, 2008
I have the same issue pinkish spots mainly in the middle of the screen. Just replaced lamp and then really noticed. talked with our local sony authorized repair center they told me it would cost $150 to clean out dirt in the optics.
Comment by dharmapoop, posted on Feb 29, 2008
Hey all, I have the "pink fingerprints" problem that so many seem to have on my kdf-50we655. Had the tech out yesterday to look at my set. He told me it was dust on the optic block and cleaning it ($350) often made it worse in his experience. He told me optic block replacement would be around $1150. I asked him about the "blue star" problem that sony is now covering the cost of and he said "oh yeah that's your set isn't it?." He then called in my pink spot problem and added some "blue spots"to my problem and it's getting fixed for me for just the $100 service call fee which I am ok with. hope this helps someone. we shouldn't be stuck in the middle of having to buy a new tv after 3 years because of a known design flaw.
Comment by gspange, posted on Feb 26, 2008
I have the same problem. Does replacing the bulb (which is recommended after 3 years) take care of the pink spot problem? When I watch an ice hockey game and it's very noticeable. I also had the pink area problems on my Sony trinitron tube type TV.
Comment by autiger30, posted on Feb 23, 2008
I also have pink spots. they are starting to run together and be a blob. Just had to replace the bulb in November.
Comment by geonetro, posted on Feb 22, 2008
I have the same problem. I also have blue dots along with the pink. I own the KF60WE610 60in tv. It started out with one pink dot and now they are everywhere. I called the service center and they don't think that Sony will cover this problem yet. Please let me know if anyone hears more about this problem
geo58@charter.net
Comment by Guest, posted on Jan 27, 2008
I have the KDF-50we655 model and two pink dots were noticeable at first. Later, there were a bunch of pink dots everywhere. Now there are pink yellow and blue dots all over the screen. I thought maybe the bulbs are going bad and need to be replaced, but after thinking about it i didnt want to spend money and the problem not be fixed. So now I just finished a search on yahoo and found this site where it seems everyone is having the same problems. Anyway, what can I do to get this fixed perminently? I did not buy the extended warrenty, but the first dots definitely did show up before a year of use. So any help would be very useful. If you can email me at Redds1324@hotmail.com
Comment by Guest, posted on Jan 09, 2008
I have the 50 inch model, bought March 2005. The pink spots started in the summer and got worse over time. I now have yellow and blue spots starting. I called Sony who gave me a number of a technician in my area to call to have them assess the problem. The company sent a report to Sony. I got a call from Sony advising the report indicates it is environmental due to dust or smoke from the fire place. Should note I do not have a wood fireplace as the one he would have seen is electric. Sony advised that this would not be covered under the extended warranty, however are offering me a new TV kdl52w3000 for a cost price of 1000.00 (sells for around 3000.00). I asked them why they would do this if was not covered under warranty and they advised "just good will". I advised them that if it was dust it still relates to the optic block as it is their flaw design to not have this covered, protected from dust (new models are so dust does not get in). Everyone has dust in their house. They advised me to contact the technician again. I did this and I have to take another picture of the screen with a white background and a black background.........I will keep you posted as to what happens.
Comment by Guest, posted on Dec 27, 2007
We had the same problem with pink and green spots, called Sony and they are sending out a repair rep to evaluate. If it is the optical block thye will replace no chage. We will see. Thanks for the link for the recall...very helpful!
Comment by Guest, posted on Dec 12, 2007
check this site out they are sending out technicians to fix the problem no cost to you
http://esupport.sony.com/US/perl/news-item.pl?news_id=206
Comment by lew77, posted on Dec 02, 2007
Pink squiggly lines in the bottom right hand corner. Started small and has increasd in size( like a squiggly cloud). We have tried turning the TV off and on, and unplugging the antenna. We also unhooked the TV from a reciever and unplugged the stereo and gaming system so that no other electronics are connected.
Comment by gray fox, posted on Dec 01, 2007
I have pink spots in the middle of my screen, that seems to be getting worse. I called Sony customer support. They are unwilling to take responsability for this problem, all I get is a runaround. they claim that it is optic block. one person said they would cover it, another said they won't. noone at their customer service know's what they are doing. any help would be appreciated. I will never call or buy or recommend Sony again.
Comment by nepm, posted on Nov 27, 2007
We had same problem, called our extended warranty company, they say it is a recall from
Sony problem, they made the call for us and
it is scheduled to be fixed. we hope
Comment by felix1965, posted on Nov 18, 2007
I have had my 50" Grand Wega for a little over two years, my pink spots started about six months ago just a few in the center, now they are scattered evenly and it seems that more appear weekly.....They are very annoying and extremly visible on light or white backgrounds. Has anyone had any luck getting Sony to respond? I have seen other blogs where this seems to be a growing problem.
Comment by JudiRoddis, posted on Nov 14, 2007
Have pink polka dots in the middle of the screen AND now the entire left side is a BEAUTIFUL cobalt blue. HELP!!!!
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
