Ic 746 problem
I have an IC746 After a lightning storm the set went completely dead. As per articles in the internet about dead ic 746 I replaced ic151 and the set canme back to life.But now I find that only 1.8 to 7 Mhz and VHF work ok. But 10 to 50 Mhz does not work due to the ATU not tuning. The receiver side is ok. What else shud have burnt??
  • 979 Answers
SOURCE: Tv will not turn on after lightning storm
Defective HV transformer. (Likely lost it during the storm)...accordianman
Posted on Mar 21, 2008
SOURCE: Sony KV-35S42 35" keep blowing MX0841 and .1 fuse resistor
Normalmente cuando falla la fuente se dañan los transistores convertidores, la resistencia 607 de 0.1 ohmios los condensadores C609, C610 de 0.47 mf. C611, C612 de 0.22 mf.
En nuestro caso basto con cambiar el MX0841 y R607, ya que el daño se debió a una sobrecorriente provocada por la salida horizontal, esta fuente e mas robusta que la de otros modelos ya que accidentalmente se provoco un corto en la salida del B+134 y simplemente solo se daño el MX0841 y la resistencia R607, se cambiaron y la fuente volvió a funcionar perfecto
Posted on Dec 04, 2008
SOURCE: Lightning affected Lcd tv
Panasonic 32"LCD Mod,TX32LXD70A
Posted on Jan 03, 2009
  • 320 Answers
SOURCE: Some bands OK some not. No transmit, no readout on some.
its the problem of the frequency range its getting blocked  at particular location.these can be solved by two options 1)first try changing the location of the unit from one corner to another corner.that should help to catch the frequency again if its getting blocked at particular location.this happens many times.but if changing the locan does not make any difference.then  2) get checked that the antenna of the unit is not catching the required frequency for the change the antenna also connect this external antenna  as mentioned 50 ω (it comes wioth SMA Connector) that helps in catchinf the frequency. you will get this at radio shack website. this will help. ----------------------------- also in the unit there is a component which controls the frequency called microprocessor if that goes weak the unit slowly slowly stops receving the accurate signals and only the noise the micro processor in located internally in the left side.its a green and black colour mini chip circuit board.many times opening the unit and removing and cleaning the microprocessor and refitting it solves the problem but this is 50 --- 50 chance. this all has to be checked what mentioned. thank you for using fixya.
Posted on Mar 31, 2009
  • 541 Answers
SOURCE: Unable to receive emails on my POP/IMAP account, but i can send emails (i am on MTN nigeria's Blackberry internet services) firewall is not blocking, its showing 3g blackberry signs as well.
As i understand that you are not able to receive emails from the organization's email id,
-So first check if the inbox in the organization's email id is more than 900 emails,if so than delete or move the mails to other folder other than inbox.
-Check the memory in the blackberry handset also.
-If still not working then login to website ( and then delete the organization's email account and then recreate the organization's email account and then click on service book and then click on send service book...And then you will be receiving the service book on the handset and then save it and then you will be able to receive the emails from organization's email account also.
Posted on May 26, 2009
E321vl no power. could this mean bad logic board?
The downside of a product getting a power surge is it will never be just right. It is not worth the cost to repair it. Consider buying a new TV instead. Suggest a Smart TV.
Mar 24, 2015 | Vizio Power Supply Input Main Board Unit...
Lightning storm
More than likely the module/chip got fried by a voltage/lightning spike.
It's cheaper to replace small appliances than to repair them.
Suggest buy a new one.
Nov 02, 2017 | Coffee Makers & Espresso Machines
Zenith Z15LCD1 Completely dead set after a lightning storm. Did not have it connected to surge protector. Does it have a fuse for protection?
They have many fuseable links. I would suspect the mains input fuse feeding the on/off switch and power supply primary because if a power surge arrives there are filters that absorb the extra energy and yake out the fuse.
Hope that helps.
Dec 29, 2010 | Zenith Z15LCD1 Television
Unable to flash focus, red curved lines at the top of screen, manual convergance will not work, problem started after a lightning storm with power surge
Ur tv now,totally have dead parts,on the tv convergence board.That,why ur flash foucus or manual covergence alignment R,G,B colors line will not matches up.The convergence board parts 2 STK convergence ICS and some or all it resistors,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 29, 2010 | Sony KP-51WS510 51" Rear Projection...
My tv went dead during a lightning storm. I heard
The sound could have come from one of your power capacitors. You could tell if one of them is no longer operational by looking at them; they will be burned, or blistered, or will be bulging. If this is a CRT type of TV ensure that you only look inside if you are fully aware of how to deal with the lethal voltages that are stored on the inside of the unit.
Aug 09, 2009 | JVC AV-32850 TV
My laptop could not connect to internet through dial-up modem
it might be your MODEM is defective due to lightning storm apperance, you should try another MODEM to connect on the internet.
Jul 21, 2009 | Computers & Internet
Av-48p776 rear projection jvc. power surge from a lightning storm
You will need to replace the convergence chips located inside the set. Typically a repair shop will charge 150-250 to fix it. Good luck
May 16, 2009 | Samsung HC-P4752W 47" Rear Projection...
Double shadows
requires a service call to be realigned ,your convergence ic's have lost their settings from the eeprom ic(memory),look in your menu settings to see if you have auto-focus if there activate it and if the ic;s are still ok it should fix it.
Nov 08, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Computers & Internet Logo
330 people viewed this question
David Payne
David Payne
