Question about Raymarine ST60 A22012-P GPS Receiver
Raymarine ST50 The plastic vane is broken on my ST 50 wind vane. Can you recommend where I could get replacement parts for this discontinued unit. Shiraz
Http://www.defender.com/product.jsp?path=-1|344|295761|301233|320702|746011&id=823240
Posted on Nov 10, 2008
I have put a st60 ttransducer on a st50 gauge can the speed be calibrated
Posted on Nov 24, 2008
I have a A22012 ST60 wind vane I need an new transducer what part number should I look for for replacement
Hi Greg!
What you're looking for is an E22078.
Here is a link from binnacle.ca, but I'm sure you can find them cheaper if you look around.
Hope this helps.
-Steve
RAYMARINE ST60 PLUS WIND TRANSDUCER MASTHEAD E22078
Jan 23, 2015 | Boating
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
How can one test a ST40 wind instrument ?
According to the Raymarine forum, aside from making sure that the spade lug connections are good and clean, there isn't a field test for the ST40. The recommended remedy is for you to send the complete unit to Raymarine for evaluation. Here's the link to that forum.
Sorry I couldn't be the bearer of better news.
-Steve
http://raymarine.ning.com/forum/topics/st-40-wind-troubleshooting
May 11, 2014 | Raymarine St40 Wind Rotavector E22047
Hi,two of the three cups on the wind sensor have broken off and i am now looking to see if the piece with the cups can be replace. will the unit record with one cup?thanksronald rosandichrrosandich1
Hello Ronald
No it won't accurately record Wind Speed because it is out of balance and lacking two parts of its motive power.
Here is a link to a new wind vane. Or you could superglue the bowl of a plastic spoon to it. Use Superglue Gel.
Please don't post personal contact details to FIXYA. We have 7 million visitors a year and some of them will try and scam you or phone you are 3:00am for a chat!
Andrew - Fixya Moderator
tx 23u wind sensor for la crosse 915 mhz weather stations eBay
lacrosse ws 2813u it wind sensor parts Google Search
Jan 21, 2018 | Lacrosse La Crosse WS-2813U-IT Pro...
Autohelm st50 wind
Go to Raymarine.com to find the usermanual for these units. They should be helpful.
May 06, 2013 | Boating
Display only showing dashes ----- I have voltages on the 5 core cable from transducer to back of display .... what are correct values for these?
Try to identify if the fault is in the masthead unit or the display by using a known good unit ,or masthead or display.
Then have it repaired.
Feb 28, 2011 | Raymarine St60 Wind Vane Ducer E22078
Remote on my Raymarine ST 4000 stopped working - how do i troubleshoot problem?
If the remote is the wire type ,check continuity of the wires in the cable ,specially at the bending places where the cable comes out of the connector and the control unit.,Cut away internally broken part of the cable,and solder again respecting the coulours ,or change the whole cable respecting the connections.
Jun 06, 2010 | Raymarine St 4000 Wheel Drive E12093
St60 Wind Vane Ducer E22078: Where is the best place to get a replacement paddl...
Go on www.raymarine.com and search for a dealer in your area and they will be able to help you. The wind service kit sells for less than $30.
May 17, 2010 | Raymarine St60 Wind Vane Ducer E22078
Autohelm mast Wind speed unit. Bottom bearing worn out. Can this be replaced, or where can I get a full replacement unit. Len
The part number for the lower pod is Q002. I am willing to bet that Raymarine will not have any more of these. The new ST60+ version will read faster than what the wind is actually.
May 15, 2010 | Boating
I have a E22078 Wind Vane. How do I check the wiring continuity at the cockpit without climbing the mast? Can I use a multimeter to read impedance up to the wind instrument?
You can read the motor/generator windings with a volt ohm meater. Is it dc or ac? You should be able to read some voltage as long as it is turning? If it is a dc generator it will read dc voltage at the slightest of wind speed. If it is an ac generator it may have to be above 5 mph to get a reading. No reading could mean a broken wire.
Sep 10, 2009 | Raymarine St60 Wind Vane Ducer E22078
Raymarine ST60 A22012-P GPS Receiver Logo
1,246 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
