Question about Mitsubishi VS-45607 45" Rear Projection Television
Need pin code
I have lost my remote and the tv won't turn on until I enter the pin code which I don't have. This is a model vs5004r. Also, how do I get a manual for this tv? thanks, john
  • osoblanco Nov 14, 2007
    I can^t get the pin code of my mitsubishi big screen tv vs5004r
  • lautoka Jan 01, 2008
    YES
Didja think about calling Mitsubishi? 8005537278...duh!
Posted on Aug 17, 2007
  • 1,476 Answers
I would get a generic remote and program it for your set. If you mean that you don't know the security pin which you created for the set you could have big problems. If you are talking about the factory pin, that is usually in the operation manual or you can contact the company. Generally the factory pins are simple like 1,2,3,4.
Posted on Jun 22, 2006
SOURCE:
Vivo tv won't turn on lost the remote and the
These are the universal remote control codes to Vivo TV. 0004 0005 0009. Check this link to know more codes and proceedings to other brands of remote controls, and buy one remote control that has setup codes with your TV. The above said codes are for GE remote with Vivo TV.
Jan 23, 2013 | Televison & Video
Universal remote (GE 24116) that i purchased to replace the lost remove control for my sanyo 42 inch tv won't work. the arrow buttons don't work in the menu which is the only reason I bought the...
Hi, You need a code to match with your TV remote. The codes for the Ge universal remote for Sanyo are 0049 0097 0110 0004 0268 0012 0108 0180. You will have to try each code seperately untill you get one that works. Good luck.
Sep 09, 2011 | Sanyo 42 in. LCD TV
Can't remember how to set up tv lost instructions need steps to enter code for tv also need code for rca tv.
Hi! Since you did not indicate the brand and model number of the remote control you are using, I will just give you the basic steps in searching for the code and programming a universal remote control.
  1. Manually turn ON your TV.
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the TV button. The TV button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the TV turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jun 13, 2010 | Televison & Video
I have a GE universal television remote, and have lost the code. I need to know how to program my MAGNAVOX TV.
Here are the codes,004,008,009,062,068,069,074,075,076,077,089,133,141,163,165,226,288,456,...Turn TV on, press and hold CODE SEARCH until the light come on, press TV ,the light will remain on, enter one of the three digit codes,the light will go off, if not, try another code until it does, press POWER, the TV should turn off....hope this was helpful....
Apr 25, 2010 | Universal Remote Control GE174Universal...
Lost my manual of my Jumbo Universal Remote. I would like to know the 3-digit code to activate my JVC TV, Model I'Art Pro
Here are the codes, 013,054,055,060,065,067,089. Turn the TV on, aim remote at TV, press and hold the CODE SEARCH button until the light turns red, Press TV button, the light will blink once and remain on, enter one of the three -digit codes, the light will go off, if the light flashes instead of going off, you will need to try another code until you find one that does, aim the remote at the TV, press POWER button, the TV should turn off.........hope this was helpful....
Apr 17, 2010 | Televison & Video
Lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
If you want a hard copy with codes for all TVs.
Aug 29, 2008 | RCA Universal Remote Control
Sky remote tune to samsung
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Mitsubishi personal code entry
mitsubishi vs5004r need code(10 digit)
May 28, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Jizzz i´m desperate!!!!
jenson 300 series Sony tv codes 497,491,475,459,406 or the code you have
hold the program or setup button untill it blinks. select the tv function and enter the code you have or one i listed above then enter
Or if your remote is this 300c series your code would be 0000
you would press down and release the device"mode key"tv,vcr,ect
the red light will blink once.press and hold down the setup key untill red light blinks twice then release.enter the code the led light will blink once on each digit execpt the last one will blink twice to confirm valid code ****mode 1 is for the tv on this remote.
hope this helps
Mar 18, 2008 | Jensen JER-323 Remote Control
Remote
this is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Jun 06, 2007 | GE HO97685 Remote Control
Mitsubishi VS-45607 45" Rear Projection Television Logo
180 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
