Question about Maytag Atlantis MDG6400AW Gas Dryer
Maytag dryer MD-3500 D-18
I have the fins that have fallen off in my dryer. I'm need to know how to get to the drum so I can replace the part.
    New Friend:
  • 12 Answers
The Top will flip to the Back, It has clip's on each side in the front, U might have to pry a lil with a flat-tip screw driver. That will expose the Drum... Hope this Helps...
Posted on Oct 26, 2008
Maytag 3000 series dryer, coins stuck in dryer fin
open the top of the dryer. slide the belt down to the power unit. of course you shoudl always unplug the unit first before removing the cover. carefully lift up ont he drum and they shoudl fall out. carefull y palce the drum back and the belt. replace the cover and plug in to see if that works.
Dec 04, 2009 | Televison & Video
How do I access the drum to replace the screws on one of the agitator fins in my Neptune Dryer MD 7500?
four door screws hinges and other side
top botom both side
take off the door
take off the white cowel around the door
you should se two top dogs remove the bolts and the top will lift open
Sep 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag neptune dryer has three tumbler arms and one is loose. I can see set screws but do not know how to get to them.
Unplug Unit.
Refer to pages 5-2 and 5-3 of the manual below (Should be similar to yours) to see how to expose the drum by lifting the top of the machine. Then turn drum very slowly and only until the screw holes for the missing fins are within your reach. Most of these dryers have two sizes of fins make sure you order the right one if you need to replace them.
Good Luck
Download this file : Maytag Dryer
Sep 07, 2009 | Maytag Dryers
Dryer fins coming loose
Unplug Unit.
Refer to pages 5-2 and 5-3 of the manual below to see how to expose the drum by lifting the top of the machine. Then turn drum very slowly and only until the screw holes for the missing fins are within your reach. Most of these dryers have two sizes of fins make sure you order the right one if you need to replace them.
Good Luck
Sep 07, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Loose Tumbler Fin In dryer
most maytag dryers have push type clips that hold the top to the front. look between the top and front with a light and find them about 3-4 inches from the outer edges. once you get the top up then there will be screws that hold the drum baffles to the drum. just put a new screw in them and all will be ok. no need to replace them, just use new screws.
Dec 31, 2008 | Maytag HYE3658AY Electric Dryer
Replacing the a drum "fin"
you should be able to Open the top of the Dryer, from front to back, U might need to pry the front corners up with a flat tip screw driver. It should hinge to the back, to expose the Tub... Hope this Helps U...
Sep 20, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag atlantis
Red silicone glue will not hold the "fin" under operation. You will have to access the outside of the drum to reattach the fin Avoid removing the drum unless you have the equipment to re-install the bushing that holds the drum. Make sure you disconnect the power and gas.
Aug 31, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
We have a maytag neptune dryer md-6 and the dryer squeeks and squeels while drying close. Do I need to replace the belt or the drum wheels? Are all three?
i would replace the belt usually over time the belt streaches due to the weight of the clothes. the screaching ou are hearing is probably the belt going aound the drum instead of turning the drum.
Aug 15, 2008 | Dryers
Maytag Atlantis MDG6400AW Gas Dryer Logo
386 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
