Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Cleaning our oven
Answer to your question to me -
The door and sides of the oven are very hot too. You can't keep your hand on it. What do you think?
  • 750 Answers
UH- OH
That's not good.
It seems like a bad heat senor or thermostat.
Do you have a oven thermometer
to test the temp?
Is it Gas or electric.
You know, this may cause damage to other sensitive parts in your oven if you use it running too hot.
I believe you now need hands on service to be there and see this for an in person diagnoses.
Huuum
Posted on Oct 19, 2008
I have the S201X how do I clean this oven/ micro combination. Does it have a self clean option?
From page 59 of the user manual:
Instructions for the user:
11. CLEANING AND MAINTENANCE
The oven must be periodically cleaned to maintain its working characteristics unaltered. Inadequate cleaning could jeopardise its appearance and above all its functioning.
Before performing any operations requiring access to powered parts, switch off the power supply to the appliance.
Do not use a steam jet for cleaning the inside of the oven.
11.1 Cleaning stainless steel
To keep stainless steel in good condition it should be cleaned regularly after use. Let it cool first.
11.2 Ordinary Daily Cleaning
To clean and preserve the stainless steel surfaces, always use only specific products that do not contain abrasives or chlorine-based acids.
How to use: pour the product on a damp cloth and wipe the surface, rinse thoroughly and dry with a soft cloth or deerskin.
11.3 Food stains or residues
Do not use metallic sponges or sharp scrapers: they will damage the surface.
Use normal non-abrasive products and a wooden or plastic tool if necessary. Rinse thoroughly and dry with a soft cloth or deerskin.
Do not allow residues of sugary foods (such as jam) to set inside the oven. If left to set for too long, they might damage the enamel lining of the oven.
11.4 Cleaning the oven
For best oven upkeep clean regularly after having allowed to cool.
Take out all removable parts.
-Clean the oven grill and side guides with hot water and non-abrasive detergent. Rinse and dry.
-For easier cleaning, the door can be removed:
11.5 Removing the door
11.5.1 removing doors with mobile hinges
Lift the levers B until they touch the hinges A and take hold of the two sides of the doors with both hand close to the hinges. Raise the door to an angle of about 45 degrees and remove it.
To reassemble, fit the hinges A into their grooves, then lower the door into place and release the levers B.
Oct 21, 2014 | Ovens
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
About 2 hours into the self cleaning cycle, F2 locked oven started flashing and the clear button would not stop it, even after repeated tries.
This means the oven has overheated and the controller is keeping the door locked either because it is still hot or it "thinks" it's still hot. There is a discussion of this at: fixyourboard.com/techzone/ovens/f1_error/f1_error.html
that will help you understand it.
Aug 30, 2010 | GE JKP15 Electric Single Oven
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning oven help
There is nothing wrong with cleaning a self-cleaning oven. Now, I don't have experience with your speicific oven, but I do have experience with other self-cleaning ovens. The self-clean function simply heats the oven up really hot. The actual temperature varies but the oven will get hotter than the hottest temperature setting. What happens is that when it get that hot it actually burns up spilled food and crumbs. sometimes in mine I even see small flames. The oven usually requires you to lock it as well since the temperature will be so high. Eventually you have to clean out the burnt "ashes" which are basically the stuff you get on food if you burn it. So the answer to what happens if you clean the oven is that you get a clean oven, nothing else. It won't hurt the oven at all. As a matter of fact even if you use the self-cleaning feature you will eventually have to clean out the "burnt crumbs" and such by hand anyway. So self-cleaning oven are designed to be cleaned by hand as well. And you won't hurt it by doing so even if you did it every day.
Jun 19, 2009 | GE Profile JTP56 Electric Double Oven
Self-cleaning leaves a brown stain on the white part on my oven
Perhaps the door gasket is not sealing well enough. In self clean mode the oven get very hot and vaporizes the fat off the sides. With a leak I think some of the fat is redepositing on on the outside where the leak is. You may need a new door seal.
Jan 30, 2009 | GE 30" Self-Cleaning Freestanding Electric...
HI I HAVE A SMEG OVEN MODEL NUMBER SA995XR I NEED THE INSTRUCTRION MANUAL JUST TO SEE HOW TO WORK THE SELF CLEANING OPTION THANKS
Hi I have just installed this oven SA995XR-5 yesterday and have the manual. It doesn't say anywhere it is self-cleaning, just good old elbow grease. Below is what is in the manual.
*I have a question for you. Does the cooling fan in your oven go all the time or does it stop some time after the oven has been turned off (which is what the manual indicates it is supposed to do)?
7.Cleaning and Maintenance
Before performing any operations requiring access to powere parts, switch off the power supply to the machine.
7.1 Cleaning stainless steel
To keep Stainless stell in good condition it should be cleaned regularly after use. Let it cool first.
7.1.1 Ordinary Daily Cleaning
To clean and preserve the stainless steel surfaces always use only specific products that do not contain abrasives or chlorine-based acids.
7.1.2 Food stains or residues
Do not use metallic sponges or shapr scrapers: they will damage the surface.
Use normal non-abrasive products for steel and a wooden or plastic tool if necessary.
Do not allow residues of suraty foods (suc as jam) to set inside the oven. If left ot set for too long, they might damage the enamel lining of the oven.
7.2 Cleaning of the oven
To best oven upkeep clean regularly after having allowed to cool, Take out all removable parts
  • Clean the oven grill and side guides with hot water and non-abrasiev detergent, Rinse and dry.
  • The oven should be operated at the maximum temperature for about 15/20 minuytes after using specific products, to eliminate the residue deposited inside the oven.
  • For easier cleaning, the door can be removed.(8.2)
7.3 Door Glass
The door glass should always be kept clean. Use absorbent kitchen paper to clean. In case of tough spots, clean with a damp sponge using regular detergent.
8.2 Removing
Hold the door on both sides with both hands near hinges (A - there is a diagram showing this is the top hinge) and raise levers (B - this lever is a little arm attached to bottom hinge. Flick it up until it catches into groove on upper hinge. Its quite uncomplicated). Lift up the door forming an angle of about 45 degrees and remove. To refit, slide the hinges A in the grooves, drop door and release levers B.
8.3 Oven door seal
To permit thorough cleaning of the oven, the seal may be removed. Before the seal, take off the door as described above. Once the door has been taken off, left the tabs at the corners as shown in the figure.
After cleaning, refit the seal with the longer side horizontal and insert the tabs into the appropriate holes starting from the top ones.
Jan 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
My rf367 range gets so hot during the self cleaning cycle that the top of the range is to hot to touch and the fan on my otr microwave comes on.
Normal operation. If in doubt place a high temp theromoter on range top to see if it exceeds 600-900 degrees
The basic idea is "burn baby, burn!" Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
Dec 14, 2008 | Whirlpool Kitchen Ranges
Oven door
tough but you need to open the door all the way stick a small screw in the hole on the side of the hinge that is still on then partially close the door this will alow for you to remove the door and then you can push open with your hand the other hinge and stick a screw in the hole on the side this will keep the hinge from closing on you then reinstall the door
May 31, 2008 | Refrigerators
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
47 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
