Question about Sharp Microwave Ovens
The turntable on our microwave has stopped turning, R-510HK. Where can I take this unit to be repaired. Or is it cheaper to buy a new one?
  • 84 Answers
Problem: Fans or turntables that do not work.
Possible causes:
1. Gummed up lubrication or bad motor bearing(s).
2. Loose or broken belt.
3. Bad motor.
4. Bad thermostat.
5. Bad connections
Posted on Oct 19, 2008
My microwave oven works, but the turntable stopped turning. How can I repair this?
turntables are turned by a rubber belt from a small motor
have an appliance service center check it out and get a quote
Dec 24, 2015 | LG Microwave Ovens
Microwave has not got a hub for turntable
buy one of the wind up ones that last time I looked were still available on places like EBAY.
It might considering the cost of a new unit be cheaper and better to measure it and replace it?
Jun 14, 2012 | Magic Chef MCD1611ST Microwave Oven
Turntable stopped working
usually its cheaper to go buy a new one than to replace the motor for the turntable
Mar 31, 2010 | Sharp R-520D 1200 Watts Microwave Oven
I have a Maytag mmv4205baw Microwave oven. It
the unit that creates the microwaves called the "magnetron" has gone bad, or the circuits powering the magnetron have gone bad. there really isnt a cheap way to fix it, and not a undangerous way to fix it yourself. if your really like the microwave and dont want to part with it, you can try finding a repair shop that will fix microwaves, but they will probably tell you it would be cheaper to buy a new one. sorry
Jan 15, 2010 | Magic Chef CMV1000B Microwave Oven
THeood is not getting heated and the turntable is
the unit inside the microwave that heats called the "magnetron" has gone bad or the circuits that power the magnetron and turntable have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days, and electronics repair people are not cheap. hope this helps
Jan 14, 2010 | Whirlpool MH6150XMS Microwave Oven
I'm asking about a problem my parents have with their Sharp Carousel microwave. When using the oven, it stops after about a minute, then when the door is opened, the turntable starts revolving and the fan...
If this is a countertop microwave and is not an expensive unit, it will not be cost effective to pay someone to repair it. Best thing is to just buy a new microwave especially if it is very old. The cost of the repairs could easily be more than a new unit and sometimes you pay to have it repaired an then something else goes wrong. With the condition you describe I would not use this unit until it is repaired or replaced with a new one.
Dec 11, 2009 | Sharp Microwave Ovens
Delonghi EM821AAN-800watt The turn table has stopped spinning
Make sure the turntable guide is lined up properly and there is no debris caught in it. Examine the turn table bushing the tray sits on and make sure it is not worn or broken. Make sure the turntable is sitting down in the groove correctly. Lastly it may be the drive motor itself is bad. This is the small motor that turns the carousel. This motor is very difficult to replace and unless you are qualified you should not attempt this repair and leave it to a professional. This motor will cost from $40 to $75 plus the cost of having it replaced. You may want to consider buying a new microwave if this unit is over 5 years old. You could end up spending more to repair this one than a new one costs. Of course you can use it without the carousel.
Dec 02, 2009 | DeLonghi MW 605 Convection/Microwave Oven
NO HEAT
Circuit board is bad. Cheaper to buy new microwave.
Sep 19, 2009 | Amana AMV1162 Microwave Oven
LG Countertop Microwave why stopped rotating?
Microwave turntables are belt driven from a small motor.
Usually it is the belt that needs replacement.
Unplug, and remove the outer case to inspect the belt. If it is still tight and attatched, the chances are it needs a new motor - often it's cheaper to buy a new unit.
Sep 04, 2008 | LG Microwave Ovens
The turntable in the microwave does not rotate.
First you need to see if it is the motor that is bad. Usually you find the relay or switch that powers the motor and see if you have voltage.
Microwaves are better left to professionals. A novice could hurt themselves working on a microwave. I would suggest getting a repair man to fix it or buy a new microwave (whichever works out cheaper for you)
May 20, 2008 | Panasonic NN-T774SF Microwave Oven
Microwave Ovens Logo
76 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
