Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
LCD displays "download standby" and does not respond to any key entry
When I turned my MF6530 this am, it startsup but immediately displays "Download Standby" and will not respond to any keys. I turned it off and unplugged it for about 30 mins thinking it my need to reset, no change. What up?
  • rs0001 Oct 19, 2008
    Yes. I turned off the power switch. Then I held down the reset button and turned the power switch back on while continuing to hold down the reset button. The machine re-initialized and began to function normally. Thanks a lot.
    Brigadier General:
  • Canon Master
  • 3,614 Answers
Try to reset the unit. this will erase the previous settings you have made..
Posted on Oct 19, 2008
  • 1 more comment
  • micromaster
    micromaster Oct 19, 2008
    does the unit was connected on the pc..?
    do reinstalling the previous driver. completely uninstall and install again the driver
    let me know
  • micromaster
    ok.. that was good to know.. just remember ' there's always a fix when you reset'
    regards.
  • Gene Zheng
    Gene Zheng Oct 22, 2014
    How to reset the printer for Canon ImageCLASS MF 6530? Not resetting computer.
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
Canon imageclass download standby
You have to reinstall the firmware of the machine. You need a special service tool program
Aug 18, 2014 | Canon imageCLASS MF6530 Monochrome Laser...
Canon mf6530 shows "download connected."
you will need a service suport tool to rewrite the software on this machine.
It is necesary to contact a CANON tech to perform this operation, if you try to do it yourself you might damage it more.
Jun 06, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Canon MF6530 display says Download Standy
OK here is the deal: Either you can fix it easily by yourself or you can't. The manufacturer's suggestion is that you first turn power switch off. Then unplug the machine and wait for 5 minutes. Then plug it in and power it on. If that doesn't work try it a couple of more times and hopefully the machine will reset itself. There are variations of this method on line that incoude pressing a series of buttons in a certain order while the machine is powered off, but these are little more than electronic voodoo. If the manufacturer's recommendations fail it means that one of your circuit boards is gone and needs replacement. The good news is that if you saved your sales receipt and it's less than 3 years old, it's all covered under warranty. Happy Trails.
Jun 09, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
No color on Samsung LCD TV
this will reset all settings with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on with a menu DO NOT CHANGE ANY OTHER SETTINGS only use down navagation key to move to were it displays reset then press RIGHT NAVAGATION key the tv will reset press standby to exit menu and then retune tv
hope this helps
Nov 27, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
CANON COPIER IMAGECLASS MF6500
It needs a new image processor, hope its still under warranty. The part retail is around $400.00 I just ordered one for someone today!
Jun 15, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
DOWNLOADING STANDBY
  • Unplug machine.
  • Press 1, then 9.
  • Plug machine back in.
  • Press 1, then 9 (again).
Machine should then initialize and be ready for service.
Apr 14, 2009 | Canon Laserbase MF6530 All-In-One Printer
Canon imageclass MF6530
try ( add.function & #) service mode and then find clear all
Feb 26, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon mf6530
you must update the firmware
Nov 26, 2008 | Office Equipment & Supplies
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
925 people viewed this question
old marine
old marine
