posted by jjenbb on Jun 19, 2006
When I hold down the select button to flip through my options there is no option 6, which happens to be the color option. I'm not sure if mine is screwed up or if I need to do something for the option to become available... Without me having to reset the entire system... :( if anyone knows how to fix this problem I would REALLY appreciate it... THNX A MILL!!!
Comment by jjenbb, posted on Jun 21, 2006
The problem though is that there is no 6 button.. that's the weird part :(
Solution #1
I've attached a picture from the manual explaining the procedure.
The only thing left to do is to turn the volume dial to toggle between the different colors for each source.
Now to the point - there is no mention of a lock to this feature. If you go through the procedure as it is put down, you should be alright, if there really isn't any problem with the device.
You mentioned that you press the select button to flip through the options - according to the manual, the select button is only for bringing up one of the PSM items(press select for 2 sec), then you need to press the 6 button.
Here's the link to the page in the manual: http://www.fixya.com/user-guide/p187263,...
Good luck
Good luck
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for JVC KD-DV5000 Car DVD Player
Email this problem
Email this problem
Can you Help with these Car Video Players problems?
jvc cq-vd6503u indash dvd
My truck has been sitting for 9... Answer This...
It tries to play the DvD for a...
It will try to play for a... Answer This...
Car DVD Player JVC KD-DV5000
When inserting DVD into player... Answer This...
Repair Service
Find Car Video Player Repairman Near You:
