Question about Sony Handycam DCR-TRV38 Mini DV Digital Camcorder
Battery symbol blinking when put on charging.
When I connect the handycam on power to charge the battery, battery symbol starts blinking and keeps doing so even after waiting for around 1/2 hr.. It did not charge the battery at all.
What's the problem? Is the battery dead and not usable anymore? The Handycam has not been used since last couple of months. I bought it 4 years back and battery has been doing good. I am not a big user of the handycam. 2 months break in recording is normal for me.
  • 320 Answers
It does sound like the battery needs to be replaced, but it also could be an internal charging problem with the camcorder. I would try a new battery first, since it's the easiest and cheapest option
Posted on Oct 19, 2008
My sony handycam DCR-TRV340E is not charging at all, dont know if its to do with the battery or the AC power adaptor
First, check that the camera switch is in the off (charging) position.
If this is OK, Check the battery output connections for voltage: use a multimeter.
To check the charger, put a load resistor across the output terminals (about 1000 ti 2000 ohms) and again, using a multimeter, check there is a charging voltage. Alternatively, if the camera operates OK with the charger attached and switched on the charger is OK, AND, the problem is then in the charging circuit from camera to battery. If the battery checks OK as in the beginning, then you will need a Sony repair man who needs to know all the results from your testing above.
May 27, 2014 | Sony Handycam DCR-TRV340E Digital...
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
I am putting fully charged battery but it is blinking red for charging the battery
I had this problem. If you have the original Nikon charger, insert the battery and press the calibration button. I dont know how, but it charged the battery fully.
Sep 25, 2012 | Canon PowerShot A470 Digital Camera
Hai there.... yesterday i bought new battery for my acer aspire 4520. Why the orange light keep blinking when the battery were charge???als0 there is no show the charge symbol on my screen??? I really...
when orange light is on it means it is charging and to know whether your system is charging just look at battery symbol where you will find a wire symbol on battery which show it is charging and when charge is complete orange light turns blue
Feb 15, 2011 | Acer Aspire One PC Notebook
My Samasung NV3 is not charging and not swtiching on.
My suggestion is to open the battery door on your camera and remove the battery for 60 seconds. Then put the battery back in and close the battery door. Then try charging it and powering it on
May 30, 2009 | Samsung NV3 Digital Camera
Power problem
Seeing as you notice that your battery life is half, this most likely means your battery is no longer able to hold a charge, or a full charge. It could also mean the battery is defective.
If your laptop is still under warranty, the manufacturer may replace it. If not, you'll have to buy a new battery, unless you always keep it plugged in anyways.
Mar 23, 2009 | Dell Inspiron 600M Notebook
Ccd-trv37 trouble with recharging battery
I think, battery is not being charged in camera.
  1. Plug the charger in AC out let.
  2. hook up with camera, check camera wroks with charger,
  3. set camera power button in OFF / Standby position,
  4. attach battery to camera and check any Charge-Light lit?
  5. If yes, leave it on charge up to 4-5 hours for new battery.
Aug 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Rokr e6
did that, both chargers work, fully charged both batteries. But when i plug the chargers into e6 it does not say charging battery and the battery symbol does not blink
Feb 16, 2008 | Motorola Mobility ROKR E6 Smartphone
Battry Mode not working
If where you put the batteries in are corroded you can use a small file or sand paper to clean them up so you can get better connections hope this helps Merry Christmas
Dec 03, 2017 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony Handycam DCR-TRV38 Mini DV Digital Camcorder Logo
228 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
