Brake lights will not come on when pedel is pressed. the high mount brake light does work. switch , bulbs and fuse are good
SOURCE: where is the reverse switch for 1995 oldsmobile cutless supreme
The back up lights are controlled by the neutral safety switch. That is usuall mounted to the top of the transmission. It also has the shift cable attached above it so that will have to come off. Also when you put the new switch in it will need to be adjusted to insure tha car starts in park and nuetral.
SOURCE: no brake lights when i push the pedal
Its the signal light switch on the lever.
THe signal switch has all connections relating to the brake lights!
solution play around with the lever and see or get someone to see the brake lights work with the brake pedal down.
My car does the same thing! when i move the lever towards activaiting the high beams the brake lights work.
just gently push on the lever to see the lights go on.
you have to replace the switch and requires removing the steering wheel without setting off the airbag.
SOURCE: Brake lights & Hazzard lights
As for the brake lights push brake pedal down while pushing on and wiggling the hazard switch.If the brake lights come on then replace the multi-function switch.
