Question about Trekstor Computers & Internet
Laptop unable to detect Trekstor HDD
My Toshiba laptop cannot detect my Trekstor hard disc. I've tried using disk management to map a new drive alphabet to the the hard disc but failed because it cannot detect the HDD at all.
  • 849 Answers
Check the jumpers of HD, they must be set on master
Posted on Oct 27, 2008
CAN AND CAN'T CONNECT IMATION TO MY PC!My laptop does not detect my Imation Grand Entertainer HDD Multimedia Player when I connect it to the USB portal. I took it and my laptop back to the shop a
This problem is caused by hard drive only. your hard disk is not working properly so open the cover and remove circuit board then you can see the hard disk attached with circuit board .please remove the HDD and connect if you have spare HDD(2.5 inch HDD also you can use) please connect and see it will work.my grand entertainer is working with 2.5 sata HDD now
Dec 03, 2012 | Computers & Internet
Trekstor external hard drive (DSMNU-S-JM-a) is on (blue light) but the device no longer shows up on the computer. Can't be accessed.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
External Hard Drive Recovery Software
Sep 11, 2012 | Trekstor DataStation maxi m.u SATA 3.5"...
My gdhdu is not being detected by my laptop at all, as a new device.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
Sep 30, 2011 | Computers & Internet
I am using a toshiba portege m400 and try to upgrade harddisk to 250 gb while installiing windows 7 hard disk is not detected.
maybe its not compatible to the laptop the hard disk that you purchase try replacing it with lower capacity hard drive then reinstall the windows 7 again
Aug 07, 2011 | SIB 250GB 2.5" SATA HDD Hard Disk Drive...
I have a Toshiba (MK4004GAH) 40 GB Hard Drive which was taken out from a Old Toshiba Laptop. I bought a 1.8" IDE casing with USB and connected to my new laptop....however, it fails to detect the HDD....
You have to make sure that you have connected the HDD in the right way. Please open it and ensure that you placed the disk rightly into the casing with each pin tapping the rightful hole, see the casing's small manual. Note also that the laptop has to detect the casing as well, so cross check the casing to ensure that its working.
Dec 03, 2010 | Toshiba (MK4004GAH) 40 GB Hard Drive
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          When I turn the laptop on (L350) the screen starts with the "Toshiba leading innovation" page then is blank- dark grey. It does not respond to any keys including F2/F12
          The laptop can not detect the hard drive please remove the hard drive and then reseat it if the problem persist then replace the hard drive.
          Feb 07, 2010 | Toshiba Satellite Pro L350-S1001V Notebook
          New HDD not recognising on laptop
          what size capacity is the new hard drive - and what is the bios on your laptop able to recognise ?
          is it an upto date laptop ?
          some old bios's unable to see newer larger drives....
          try updating the bios of your laptop
          or use a hdd prep programme
          Oct 11, 2009 | Computers & Internet
          New hdd for laptop from Nippon Labs
          Yes you can format this drive from your XP machine, or in vista (or xp for that matter) right click on my computer and then left click on manage.
          When the computer management screen comes up highlight "Disk Management" on the left side. This will then display your drives in the right side. From here you can right click on the drive and create partitions, format etc.
          You will need ghost or some other cloning software if you want to image the old drive to the new one. However if you have restore disks for the computer you should also be able to just install the OS on the new drive.
          Hope this helps
          Apr 24, 2009 | Computers & Internet
          System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
          it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
          otherwise use dm (disk manager) for detection and partition.
          Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
          Computers & Internet Logo
          468 people viewed this question
          Top Trekstor Computers & Internet Experts
          Marcin
          vojvodabudva
          Mohamed Ismail
          Mohamed Ismail
          Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
